Reminder of the outstanding 1.10 and 1.11 blocker issues as I've not
seen any activity on them this week - but develop is becoming
increasingly unstable, which is going to make 1.11.0-RC1 difficult.
The 1.10.1 issues are important to make a patch release in the next week
or so, please help fix this new release's regressions.
Unassigned 1.10.1 issues
Smart proxy DHCP lease/config parsing errors on some entries
Bug #13062: smart-proxy throws an error when the field for fixed-address does not match a valid IP. - Smart Proxy - Foreman -
undefined method persisted? during CR form rendering
Bug #13053: undefined method `persisted?' for #<Hash:0x007f2481f21258> - Foreman -
Compute profiles not inheriting from group on New Host form
Bug #13004: Compute Profiles not Inheriting from nested host group - Foreman -
Installer not configuring OMAPI keys in DHCP config file
Bug #12989: OMAPI key data passed to foreman-installer does not end up in dhcp.yml - Installer - Foreman -
VMware provisioning from template not using new disk
Bug #12487: Provisioning with Templates causes new VM to use Template Disk - Foreman -
Template audit not showing diffs (CSS/JS issue)
Bug #12271: Audit of template change has an empty diff - Foreman
Open 1.10.1 PRs:
Bug #12859: "Suggest new" link for IP address on interface model window doesn't work - Foreman (suggest IPs)
Bug #12566: New Host API changed host_parameters_attributes behavior - Foreman (parameters API)
Bug #12959: Host search based on fact value using LIKE clause does'nt work - Foreman (facts searching)
Bug #12954: Foreman puppet report status does not work without a puppet proxy - Foreman (host config status)
Please check the latest issues list at:
http://projects.theforeman.org/projects/foreman/issues?query_id=87
Unassigned 1.11.0 issues
Rails 4.1.latest update required for security issues
Feature #12873: Update Rails to 4.1.latest - Foreman -
Plugin i18n extraction support broken
Bug #13033: plugin:gettext rake task doesn't load with gettext_i18n_rails_js 1.x - Foreman -
Excessive DB queries when retrieving API docs
Bug #12621: Excessive TemplateKind DB queries when retrieving API docs - Foreman -
undefined find_by_ip method during CR provisioning
Bug #13084: undefined method `find_by_ip' during validation of IP retrieved from compute resource - Foreman -
Lots of issues already relating to the merge of #4629 (Patternfly)
yesterday, see Feature #4629: Add Patternfly support in foreman - Foreman and the main list.
http://projects.theforeman.org/projects/foreman/issues?query_id=81
