Please keep helping with issues affecting 1.10 and 1.11, and do refresh
the links to the latest issues as they're updated frequently.
Some already have PRs open, some of which are waiting on the contributor
- please check and update these.
Unassigned 1.10.2 issues
undefined method persisted? during CR form rendering
Bug #13053: undefined method `persisted?' for #<Hash:0x007f2481f21258> - Foreman -
VMware provisioning from template not using new disk
Bug #12487: Provisioning with Templates causes new VM to use Template Disk - Foreman -
Exception editing role filters with Rails associations
Bug #13515: Foreman exception triggered when editing a role filter or adding a new one - Foreman -
Installer DB creation relies on en_US.utf8 locale
Bug #13496: foreman-installer error when locale is not en_US.utf8 - Installer - Foreman -
Overriding truncated parameters overrides all
Bug #13369: Long parameter names are truncated and overriden together - Foreman -
Rails needs updating to 3.2.22.1
Bug #13372: Update Rails to 3.2.22.1 - Foreman
Please check the latest issues list at:
http://projects.theforeman.org/projects/foreman/issues?query_id=87
Unassigned 1.11.0 issues
Dashboard grid issues
Bug #13352: Dashboard widget rows are loaded in reverse order - Foreman
Bug #13353: Cannot move dashboard widgets to far right columns - Foreman -
Poor documentation link text (only partially fixed)
Bug #13311: More "Learn more about this on the documentation" should be "in the documentation" - Foreman -
locale:pack failing to parse facets code
Bug #13567: locale:pack failure in facets/managed_host_extensions.rb - Foreman -
jquery upgrade tasks
Refactor #12935: Check js code against jQuery upgrade guide and release notes - Foreman
http://projects.theforeman.org/projects/foreman/issues?query_id=81
