Just a reminder that we have two sets of important issues that I'd still
appreciate help on.
The first is for Foreman 1.8.3, which may well be the last in the series
unless there are further important regressions or security issues.
Those can be found at: http://bit.ly/1MfBtQm
Marek - I know you've been triaging some network issues, are there any
more you'd like to add to that list?
The second is for Foreman 1.9.0, which is a nice, short list at the
moment with just two unfixed issues. So far it looks like we won't have
a further release candidate, and can potentially release 1.9.0 in the
next couple of weeks.
That's here: http://bit.ly/1FyhCnI
Cheers,
Dominic Cleal
Red Hat Engineering
Hello
I think there's no regression introduced in 1.8 branch related to networking.
It would be nice to fix some issues [1][2] in interface parsing but as far as
I can tell they are present at least since 1.7.
[1] Bug #10805: VLAN interface attached to bond is wrongly created as Bond - Foreman
[2] Bug #11034: network/interfaces validation checks the removed interfaces - Foreman
> appreciate help on.
> Cheers,
Marek
> appreciate help on.
Unfortunately I don't think there's been any take-up of these issues, so
I'll try again with a few keywords to help people find tickets they may
be able to help with.
Authorisation and ActiveRecord related issue
Bug #10819: PGError: ERROR: missing FROM-clause entry for table "hosts_reports" LINE 1 - Foreman
Hostnames and domains issue when unattended: false
Bug #11143: Domain removed from the hostname on host edit in !unattended mode - Foreman
Editing hosts with "invalid" network interfaces
Bug #10931: Editing of host with docker broken - Foreman
Error from smart class parameter matchers
Bug #11112: Matcher for unlisted attribute fails with "comparison of Array with Array failed" - Foreman
This list is growing, and not getting shorter.
API parameter docs and responses missing ptables/taxonomies (easy)
Bug #11175: organization and location for partition tables (ptable) not returned in json - Foreman
select2 not working with compute profiles (important)
Bug #11171: Select2 does not work with compute profiles - Foreman
Debian package failures on foreman-installer
Bug #11152: a2x: ERROR: "xsltproc" ... returned non-zero exit status 5 during Debian package build - Packaging - Foreman
Warning message about already initialised constants
Bug #11122: Already initialized constant exception after service startup - Foreman
Taxonomy/authorisation issue (PR open)
Bug #11187: Taxonomy selectors are empty even for users with assign permissions - Foreman
Help with regressions caused by features and bug fixes you wrote during
the last cycle is appreciated especially and will make me more likely to
trust your patches in future!
On 20/07/15 14:09, Dominic Cleal wrote:
Dominic Cleal
Red Hat Engineering
