All,
After upgrading to 1.10.1 Activation Keys would not work anymore:
hammer activation-key list --organization-label test
[Foreman] Password for admin:
undefined method `subscription' for nil:NilClass
In the log:
==> foreman/production.log <==
2016-02-02 14:33:12 [app] [I] Rendered
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-2.4.0/app/views/katello/api/v2/activation_keys/index.json.rabl
within katello/api/v2/layouts/collection (240.6ms)
2016-02-02 14:33:12 [app] [E] NoMethodError: undefined method
subscription' for nil:NilClass > /opt/theforeman/tfm/root/usr/share/gems/gems/katello-2.4.0/app/models/katello/activation_key.rb:100:in
block in products'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-2.4.0/app/models/katello/activation_key.rb:99:in
each' > /opt/theforeman/tfm/root/usr/share/gems/gems/katello-2.4.0/app/models/katello/activation_key.rb:99:in
products'
/opt/theforeman/tfm/root/usr/share/gems/gems/rabl-0.11.6/lib/rabl/helpers.rb:14:in
data_object' > /opt/theforeman/tfm/root/usr/share/gems/gems/rabl-0.11.6/lib/rabl/builder.rb:169:in
child'
/opt/theforeman/tfm/root/usr/share/gems/gems/rabl-0.11.6/lib/rabl/builder.rb:114:in
block in compile_settings' > /opt/theforeman/tfm/root/usr/share/gems/gems/rabl-0.11.6/lib/rabl/builder.rb:113:in
each'
compile_settings' > /opt/theforeman/tfm/root/usr/share/gems/gems/rabl-0.11.6/lib/rabl/builder.rb:34:in
engines'
/opt/theforeman/tfm/root/usr/share/gems/gems/rabl-0.11.6/lib/rabl/builder.rb:119:in
merge_engines_into_result' > /opt/theforeman/tfm/root/usr/share/gems/gems/rabl-0.11.6/lib/rabl/builder.rb:55:in
block in to_hash'
/opt/theforeman/tfm/root/usr/share/gems/gems/rabl-0.11.6/lib/rabl/builder.rb:248:in
cache_results' > /opt/theforeman/tfm/root/usr/share/gems/gems/rabl-0.11.6/lib/rabl/builder.rb:49:in
to_hash'
/opt/theforeman/tfm/root/usr/share/gems/gems/rabl-0.11.6/lib/rabl/engine.rb:86:in
to_hash' > /opt/theforeman/tfm/root/usr/share/gems/gems/rabl-0.11.6/lib/rabl/engine.rb:48:in
block in render'
/opt/theforeman/tfm/root/usr/share/gems/gems/rabl-0.11.6/lib/rabl/engine.rb:382:in
cache_results' > /opt/theforeman/tfm/root/usr/share/gems/gems/rabl-0.11.6/lib/rabl/engine.rb:47:in
render'
/opt/theforeman/tfm/root/usr/share/gems/gems/rabl-0.11.6/lib/rabl/builder.rb:127:in
block in merge_engines_into_result' > /opt/theforeman/tfm/root/usr/share/gems/gems/rabl-0.11.6/lib/rabl/builder.rb:119:in
each'
block in to_hash'
to_hash'
/opt/theforeman/tfm/root/usr/share/gems/gems/rabl-0.11.6/lib/rabl/multi_builder.rb:27:in
map' > /opt/theforeman/tfm/root/usr/share/gems/gems/rabl-0.11.6/lib/rabl/multi_builder.rb:27:in
to_a'
/opt/theforeman/tfm/root/usr/share/gems/gems/rabl-0.11.6/lib/rabl/engine.rb:88:in
block in render'
render'
/opt/theforeman/tfm/root/usr/share/gems/gems/rabl-0.11.6/lib/rabl/builder.rb:124:in
block (2 levels) in merge_engines_into_result' > /opt/theforeman/tfm/root/usr/share/gems/gems/rabl-0.11.6/lib/rabl/builder.rb:123:in
each'
each'
block in to_hash'
to_hash'
block in render'
render'
each'
block in to_hash'
to_hash'
to_hash' > /opt/theforeman/tfm/root/usr/share/gems/gems/rabl-0.11.6/lib/rabl/engine.rb:101:in
to_dumpable'
/opt/theforeman/tfm/root/usr/share/gems/gems/rabl-0.11.6/lib/rabl/engine.rb:110:in
to_json' > /opt/theforeman/tfm/root/usr/share/gems/gems/rabl-0.11.6/lib/rabl/engine.rb:48:in
block in render'
render'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-2.4.0/app/views/katello/api/v2/activation_keys/index.json.rabl:1:in
_58d8e235be94ab895e64df0f4b3660a3' > /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_view/template.rb:145:in
block in render'
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/notifications.rb:125:in
instrument' > /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_view/template.rb:143:in
render'
/opt/theforeman/tfm/root/usr/share/gems/gems/deface-1.0.1/lib/deface/action_view_extensions.rb:41:in
render' > /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_view/renderer/template_renderer.rb:47:in
block (2 levels) in render_template'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_view/renderer/abstract_renderer.rb:38:in
block in instrument' > /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/notifications.rb:123:in
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/notifications/instrumenter.rb:20:in
instrument'
instrument' > /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_view/renderer/template_renderer.rb:46:in
block in render_template'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_view/renderer/template_renderer.rb:54:in
render_with_layout' > /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_view/renderer/template_renderer.rb:45:in
render_template'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_view/renderer/template_renderer.rb:18:in
render' > /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_view/renderer/renderer.rb:36:in
render_template'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_view/renderer/renderer.rb:17:in
render' > /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/abstract_controller/rendering.rb:110:in
_render_template'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/streaming.rb:225:in
_render_template' > /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/abstract_controller/rendering.rb:103:in
render_to_body'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/renderers.rb:28:in
render_to_body' > /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/compatibility.rb:50:in
render_to_body'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/abstract_controller/rendering.rb:88:in
render' > /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/rendering.rb:16:in
render'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/instrumentation.rb:40:in
block (2 levels) in render' > /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/core_ext/benchmark.rb:5:in
block in ms'
> /opt/rh/ruby193/root/usr/share/ruby/benchmark.rb:295:in realtime' > /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/core_ext/benchmark.rb:5:in
ms'
block in render' > /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/instrumentation.rb:83:in
cleanup_view_runtime'
/opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/railties/controller_runtime.rb:24:in
cleanup_view_runtime' > /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/instrumentation.rb:39:in
render'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-2.4.0/app/lib/katello/api/v2/rendering.rb:48:in
respond_with_template' > /opt/theforeman/tfm/root/usr/share/gems/gems/katello-2.4.0/app/lib/katello/api/v2/rendering.rb:63:in
respond_with_template_collection'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-2.4.0/app/lib/katello/api/v2/rendering.rb:76:in
try_specific_collection_template' > /opt/theforeman/tfm/root/usr/share/gems/gems/katello-2.4.0/app/lib/katello/api/v2/rendering.rb:11:in
respond_for_index'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-2.4.0/app/controllers/katello/concerns/api/api_controller.rb:74:in
respond' > /opt/theforeman/tfm/root/usr/share/gems/gems/katello-2.4.0/app/controllers/katello/api/v2/activation_keys_controller.rb:26:in
index'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/implicit_render.rb:4:in
send_action' > /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/abstract_controller/base.rb:167:in
process_action'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/rendering.rb:10:in
process_action' > /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/abstract_controller/callbacks.rb:18:in
block in process_action'
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:573:in
block (5 levels) in _run__1877034146516499879__process_action__4131650904809277017__callbacks' > /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:215:in
block in _conditional_callback_around_11840'
> /usr/share/foreman/app/controllers/api/v2/base_controller.rb:151:in
disable_json_root' > /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:214:in
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:517:in
block (4 levels) in _run__1877034146516499879__process_action__4131650904809277017__callbacks' > /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:215:in
block in _conditional_callback_around_11839'
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:326:in
around' > /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:310:in
_callback_around_4111'
_conditional_callback_around_11839' > /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:505:in
block (3 levels) in
block in _conditional_callback_around_11838' > /usr/share/foreman/app/controllers/concerns/application_shared.rb:13:in
set_timezone'
_conditional_callback_around_11838' > /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:504:in
block (2 levels) in
block in _conditional_callback_around_11837' > /usr/share/foreman/app/models/concerns/foreman/thread_session.rb:32:in
clear_thread'
_conditional_callback_around_11837' > /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:448:in
block in
block in _conditional_callback_around_11836' > /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:326:in
around'
_callback_around_13' > /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:214:in
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:414:in
_run__1877034146516499879__process_action__4131650904809277017__callbacks' > /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:405:in
__run_callback'
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:385:in
_run_process_action_callbacks' > /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:81:in
run_callbacks'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/abstract_controller/callbacks.rb:17:in
process_action' > /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/rescue.rb:29:in
process_action'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/instrumentation.rb:30:in
block in process_action' > /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/notifications.rb:123:in
instrument'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/instrumentation.rb:29:in
process_action' > /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/params_wrapper.rb:207:in
process_action'
/opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/railties/controller_runtime.rb:18:in
process_action' > /opt/theforeman/tfm/root/usr/share/gems/gems/katello-2.4.0/app/controllers/katello/concerns/api/api_controller.rb:39:in
process_action'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/abstract_controller/base.rb:121:in
process' > /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/abstract_controller/rendering.rb:45:in
process'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal.rb:203:in
dispatch' > /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/rack_delegation.rb:14:in
dispatch'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal.rb:246:in
block in action' > /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/routing/route_set.rb:73:in
call'
dispatch' > /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/routing/route_set.rb:36:in
call'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/routing/mapper.rb:42:in
call' > /opt/rh/ruby193/root/usr/share/gems/gems/journey-1.0.4/lib/journey/router.rb:68:in
block in call'
/opt/rh/ruby193/root/usr/share/gems/gems/journey-1.0.4/lib/journey/router.rb:56:in
each' > /opt/rh/ruby193/root/usr/share/gems/gems/journey-1.0.4/lib/journey/router.rb:56:in
call'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/routing/route_set.rb:600:in
call' > /opt/rh/ruby193/root/usr/share/gems/gems/railties-3.2.8/lib/rails/engine.rb:479:in
call'
/opt/rh/ruby193/root/usr/share/gems/gems/railties-3.2.8/lib/rails/railtie/configurable.rb:30:in
method_missing' > /opt/rh/ruby193/root/usr/share/gems/gems/journey-1.0.4/lib/journey/router.rb:68:in
block in call'
call'
