Hi! I'm having a problem with the Active Directory connection, the test is
working but the user also gives me invalid user and password, I have
searched all the docs but I don't find help, where can I search for help? I
have a question about this, foreman search all across the AD for the user?
or only at the baseDN? Where are the logs of the active directory
connection?
Thanks in advance
Hi there
The configuration for active directory in foreman must be the same as
katello i user the following
Account
DOMAIN\username
Base DN CN=Users,DC=example,DC=COM
Groups base DN CN=Users,DC=example,DC=com
Login name attribute userPrincipalName
First name attribute givenName
Surname attribute sn
Email address attribute mail mail
Let me know if you have any issues
Kind Regards
Mario Gamboa
> I have a question about this, foreman search all across the AD for the
> user? or only at the baseDN? Where are the logs of the active directory
> connection?
> Thanks in advance
It was so simple! It works now!!! I was using as Login name attribute the
SAMAccount field.
Thanks
El sábado, 27 de mayo de 2017, 3:37:58 (UTC+2), Mario Gamboa escribió:
> Hi there
> Account
> DOMAIN\username
> Kind Regards
> Mario Gamboa
>> is working but the user also gives me invalid user and password, I have
>> connection?
>> Thanks in advance
