Hello there!
I'm having an isolated issue on one of the Foreman (separate) instances,
where I can't deploy Libvirt VMs into compute resources anymore.
A standard procedure (through UI):
New Host
put a hostname for a new VM
pick a compute resource to deploy on
At this point I see that "Interfaces" tab goes red and if I go to it, I see
this message:
Error loading interfaces information: Internal Server Error
My production.log show me this:
2016-10-19 16:31:19 5e8f4434 [app] [I] Started POST "/hosts/interfaces" for
10.153.47.145 at 2016-10-19 16:31:19 -0700
2016-10-19 16:31:19 5e8f4434 [app] [I] Processing by
HostsController#interfaces as /
2016-10-19 16:31:19 5e8f4434 [app] [I] Parameters: {"utf8"=>"✓",
"authenticity_token"=>"VBTeVRN/84DLh57lDE+A5zZrn62aGfoZ4+UcKqzhKJ4pAcEYI8P9MDsE3VnRCkrT9kJ0rpBJTrHHGu6jWB+VlA==",
"host"=>{"salt_module_ids"=>[""], "name"=>"kim-magwire",
"hostgroup_id"=>"", "compute_resource_id"=>"13", "compute_profile_id"=>"",
"environment_id"=>"", "puppet_proxy_id"=>"", "salt_environment_id"=>"",
"salt_proxy_id"=>"", "managed"=>"true", "progress_report_id"=>"[FILTERED]",
"type"=>"Host::Managed", "interfaces_attributes"=>{"0"=>{"_destroy"=>"0",
"type"=>"Nic::Managed", "mac"=>"", "identifier"=>"", "name"=>"kim-magwire",
"domain_id"=>"", "ip"=>"", "ip6"=>"", "managed"=>"1", "primary"=>"1",
"provision"=>"1", "execution"=>"1", "virtual"=>"0", "tag"=>"",
"attached_to"=>""}}, "compute_attributes"=>{"cpus"=>"1",
"memory"=>"805306368", "start"=>"1",
"volumes_attributes"=>{"0"=>{"_delete"=>"", "pool_name"=>"default",
"capacity"=>"10G", "allocation"=>"0G", "format_type"=>"raw"}}},
"architecture_id"=>"", "provision_method"=>"build", "build"=>"1",
"disk"=>"", "root_pass"=>"[FILTERED]", "is_owned_by"=>"1-Users",
"enabled"=>"1", "model_id"=>"", "comment"=>"", "overwrite"=>"false"},
"capabilities"=>"build image", "provider"=>"Libvirt",
"fakepassword"=>"[FILTERED]", "bare_metal_capabilities"=>"build"}
2016-10-19 16:31:19 5e8f4434 [app] [W] Action failed
> ActiveRecord::UnknownAttributeError: unknown attribute
'provision_method' for Host::Managed.
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/attribute_assignment.rb:59:in
rescue in _assign_attribute' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/attribute_assignment.rb:54:in
_assign_attribute'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/attribute_assignment.rb:41:in
block in assign_attributes' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_controller/metal/strong_parameters.rb:185:in
each_pair'
each_pair' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/attribute_assignment.rb:35:in
assign_attributes'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/core.rb:566:in
init_attributes' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/core.rb:281:in
initialize'
> /usr/share/foreman/app/models/host/base.rb:70:in initialize' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/routing/url_for.rb:104:in
initialize'
> /usr/share/foreman/app/models/host/managed.rb:49:in initialize' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/inheritance.rb:61:in
new'
new' > /usr/share/foreman/app/models/concerns/foreman/sti.rb:22:in
new_with_cast'
> /usr/share/foreman/app/models/host.rb:14:in method_missing' > /usr/share/foreman/app/controllers/hosts_controller.rb:155:in
interfaces'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_controller/metal/implicit_render.rb:4:in
send_action' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/abstract_controller/base.rb:198:in
process_action'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_controller/metal/rendering.rb:10:in
process_action' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/abstract_controller/callbacks.rb:20:in
block in process_action'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:117:in
call' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:117:in
call'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:555:in
block (2 levels) in compile' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:505:in
call'
call' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:498:in
block (2 levels) in around'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:313:in
call' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:313:in
block (2 levels) in halting'
/opt/theforeman/tfm/root/usr/share/gems/gems/rails-observers-0.1.2/lib/rails/observers/action_controller/caching/sweeping.rb:73:in
`around'
<snip>
Originally I started having this issue while on version 1.7.1. Since this
is the long time overdue for an upgrade, I've decided to go through the
pain of jumping from 1.7.1 to 1.13.0 (one major release at the time) now
and was hoping that whatever it was preventing things from properly working
would be fixed with DB migrations and such.
But as you can see, even in 1.13.0 I still have the same problem. The
output above is from 1.13.0. Here's what I was getting on 1.7.1 while
trying to create a VM through API:
Started POST "/hosts" for 10.64.63.205 at 2016-09-21 18:52:31 -0700
Processing by HostsController#create as /
"authenticity_token"=>"m0XQ3dQE02YElmWptLiurEBe/yv6a8g26Bb9bWpd0xk=",
"host"=>{"name"=>"test", "hostgroup_id"=>"", "compute_resource_id"=>"5",
"compute_profile_id"=>"2", "environment_id"=>"8", "puppet_proxy_id"=>"",
"salt_environment_id"=>"", "salt_proxy_id"=>"", "salt_module_ids"=>[""],
"type"=>"Host::Managed", "compute_attributes"=>{"cpus"=>"4",
"memory"=>"17179869184", "nics_attributes"=>{"new_nics"=>{"type"=>"bridge",
"_delete"=>"", "bridge"=>"", "model"=>"virtio"}, "0"=>{"type"=>"bridge",
"_delete"=>"", "bridge"=>"br0", "model"=>"virtio"}},
"volumes_attributes"=>{"new_volumes"=>{"pool_name"=>"default",
"capacity"=>"10G", "allocation"=>"0G", "format_type"=>"raw",
"_delete"=>""}, "0"=>{"pool_name"=>"default", "capacity"=>"50G",
"allocation"=>"0G", "format_type"=>"qcow2", "_delete"=>""}}, "start"=>"1",
"image_id"=>"/data/images/ubuntu-14.04.2-dhcp.qcow2"}, "domain_id"=>"5",
"realm_id"=>"", "mac"=>"", "ip"=>"1.1.1.1",
"interfaces_attributes"=>{"new_interfaces"=>{"_destroy"=>"false",
"type"=>"Nic::Managed", "mac"=>"", "identifier"=>"", "name"=>"",
"domain_id"=>"", "ip"=>"", "managed"=>"1", "virtual"=>"0", "tag"=>"",
"attached_to"=>""}}, "architecture_id"=>"1", "operatingsystem_id"=>"9",
"provision_method"=>"image", "build"=>"1", "disk"=>"",
"root_pass"=>"[FILTERED]", "is_owned_by"=>"6-Users", "enabled"=>"1",
"capabilities"=>"build image", "provider"=>"Libvirt"}
Operation FAILED: unknown attribute: provision_method
Rendered common/500.html.erb (183.1ms)
Completed 500 Internal Server Error in 198ms (Views: 185.3ms |
ActiveRecord: 1.6ms)
The same API call against 1.13.0:
2016-10-19 15:56:59 65e3b7a2 [app] [I] Started POST "/api/v2/hosts/" for
10.188.5.22 at 2016-10-19 15:56:59 -0700
2016-10-19 15:56:59 65e3b7a2 [app] [I] Processing by
Api::V2::HostsController#create as JSON
2016-10-19 15:56:59 65e3b7a2 [app] [I] Parameters:
{"host"=>{"operatingsystem_id"=>"6", "environment_id"=>"8",
"ip"=>"10.132.211.12", "provision_method"=>"image", "image_id"=>"29",
"domain_id"=>"5", "compute_resource_id"=>"11", "name"=>"lvs01test",
"enabled"=>"1", "hostgroup_id"=>"74",
"compute_attributes"=>{"volumes_attributes"=>{"0"=>{"allocation"=>"0G",
"pool_name"=>"default", "format_type"=>"qcow2", "capacity"=>"50G",
"_delete"=>""}}, "start"=>"0", "cpus"=>"4",
"image_id"=>"/data/images/ubuntu-14.04.2-dhcp.qcow2",
"nics_attributes"=>{"0"=>{"_delete"=>"", "model"=>"virtio",
"type"=>"bridge", "bridge"=>"br0"}}, "memory"=>"17179869184"},
"architecture_id"=>"1", "build"=>"1", "compute_profile_id"=>"2"},
"provider"=>"Libvirt", "apiv"=>"v2"}
2016-10-19 15:56:59 65e3b7a2 [app] [I] Authorized user admin(Admin User)
2016-10-19 15:56:59 65e3b7a2 [app] [W] Action failed
`rescue in _assign_attribute'
`_assign_attribute'
`block in assign_attributes'
`each_pair'
`each_pair'
`assign_attributes'
<snip>
As I mentioned, I have other 5 1.7.1 instances where this still works
perfectly fine. I suspect someone has mocked around with Foreman DB on a
troubled instances, I just can't figure out what it is. And Foreman
upgrades could not fix that either
What are my options here? Anyone had such problem and, if so, how was it
solved?
Thanks!
