Hey,
I’ve spent the whole day debugging this:
> DiscoveryRule.first.hosts.first
undefined local variable or method `implicit_order_column' for #<ActiveRecord::Associations::CollectionProxy []>
Backtrace for 'Action failed' error (ActionView::Template::Error): undefined local variable or method `implicit_order_column' for #<ActiveRecord::Associations::CollectionProxy []>
| /home/lzap/.rbenv/versions/2.6.3/lib/ruby/gems/2.6.0/gems/activerecord-6.0.2.1/lib/active_record/relation/delegation.rb:108:in `method_missing'
| /home/lzap/.rbenv/versions/2.6.3/lib/ruby/gems/2.6.0/gems/activerecord-6.0.2.1/lib/active_record/relation/finder_methods.rb:554:in `ordered_relation'
| /home/lzap/.rbenv/versions/2.6.3/lib/ruby/gems/2.6.0/gems/activerecord-6.0.2.1/lib/active_record/relation/finder_methods.rb:520:in `find_nth_with_limit'
| /home/lzap/.rbenv/versions/2.6.3/lib/ruby/gems/2.6.0/gems/activerecord-6.0.2.1/lib/active_record/associations/collection_proxy.rb:1107:in `find_nth_with_limit'
| /home/lzap/.rbenv/versions/2.6.3/lib/ruby/gems/2.6.0/gems/activerecord-6.0.2.1/lib/active_record/relation/finder_methods.rb:513:in `find_nth'
| /home/lzap/.rbenv/versions/2.6.3/lib/ruby/gems/2.6.0/gems/activerecord-6.0.2.1/lib/active_record/relation/finder_methods.rb:120:in `first'
| /home/lzap/.rbenv/versions/2.6.3/lib/ruby/gems/2.6.0/gems/rabl-0.14.2/lib/rabl/helpers.rb:41:in `data_name'
| /home/lzap/.rbenv/versions/2.6.3/lib/ruby/gems/2.6.0/gems/rabl-0.14.2/lib/rabl/builder.rb:173:in `child'
| /home/lzap/.rbenv/versions/2.6.3/lib/ruby/gems/2.6.0/gems/rabl-0.14.2/lib/rabl/builder.rb:116:in `block in compile_settings'
| /home/lzap/.rbenv/versions/2.6.3/lib/ruby/gems/2.6.0/gems/rabl-0.14.2/lib/rabl/builder.rb:115:in `each'
| /home/lzap/.rbenv/versions/2.6.3/lib/ruby/gems/2.6.0/gems/rabl-0.14.2/lib/rabl/builder.rb:115:in `compile_settings'
| /home/lzap/.rbenv/versions/2.6.3/lib/ruby/gems/2.6.0/gems/rabl-0.14.2/lib/rabl/builder.rb:36:in `engines'
| /home/lzap/.rbenv/versions/2.6.3/lib/ruby/gems/2.6.0/gems/rabl-0.14.2/lib/rabl/builder.rb:121:in `merge_engines_into_result'
| /home/lzap/.rbenv/versions/2.6.3/lib/ruby/gems/2.6.0/gems/rabl-0.14.2/lib/rabl/builder.rb:57:in `block in to_hash'
| /home/lzap/.rbenv/versions/2.6.3/lib/ruby/gems/2.6.0/gems/rabl-0.14.2/lib/rabl/builder.rb:252:in `cache_results'
| /home/lzap/.rbenv/versions/2.6.3/lib/ruby/gems/2.6.0/gems/rabl-0.14.2/lib/rabl/builder.rb:51:in `to_hash'
| /home/lzap/.rbenv/versions/2.6.3/lib/ruby/gems/2.6.0/gems/rabl-0.14.2/lib/rabl/engine.rb:90:in `to_hash'
| /home/lzap/.rbenv/versions/2.6.3/lib/ruby/gems/2.6.0/gems/rabl-0.14.2/lib/rabl/engine.rb:50:in `block in render'
| /home/lzap/.rbenv/versions/2.6.3/lib/ruby/gems/2.6.0/gems/rabl-0.14.2/lib/rabl/engine.rb:385:in `cache_results'
| /home/lzap/.rbenv/versions/2.6.3/lib/ruby/gems/2.6.0/gems/rabl-0.14.2/lib/rabl/engine.rb:49:in `render'
| /home/lzap/work/foreman/config/initializers/rabl_init.rb:49:in `render'
| /home/lzap/.rbenv/versions/2.6.3/lib/ruby/gems/2.6.0/gems/rabl-0.14.2/lib/rabl/builder.rb:129:in `block in merge_engines_into_result'
| /home/lzap/.rbenv/versions/2.6.3/lib/ruby/gems/2.6.0/gems/rabl-0.14.2/lib/rabl/builder.rb:121:in `each'
| /home/lzap/.rbenv/versions/2.6.3/lib/ruby/gems/2.6.0/gems/rabl-0.14.2/lib/rabl/multi_builder.rb:27:in `map'
| /home/lzap/.rbenv/versions/2.6.3/lib/ruby/gems/2.6.0/gems/rabl-0.14.2/lib/rabl/multi_builder.rb:27:in `to_a'
| /home/lzap/.rbenv/versions/2.6.3/lib/ruby/gems/2.6.0/gems/rabl-0.14.2/lib/rabl/engine.rb:92:in `to_hash'
| /home/lzap/.rbenv/versions/2.6.3/lib/ruby/gems/2.6.0/gems/rabl-0.14.2/lib/rabl/engine.rb:103:in `to_dumpable'
| /home/lzap/.rbenv/versions/2.6.3/lib/ruby/gems/2.6.0/gems/rabl-0.14.2/lib/rabl/engine.rb:112:in `to_json'
| /home/lzap/work/foreman_discovery/app/views/api/v2/discovery_rules/index.json.rabl:3:in `_0c11c3c03ea8ac65e99adfb1b2e500c2'
Rails 6 added new model class attribute implicit_order_column
where you can specify default:
class User < ApplicationRecord
self.implicit_order_column = "updated_at"
end
Problem is, there is some misbehavior with this when used with DiscoveredHost. Probably STI has something to do with this, but I’ve been unable to simulate this in pure Rails. It must be some monkey patching or order of dependencies loaded.
Now the funny part, when I put PRY to the place in RABL where it calls the first
method - wait for it - it works just fine!
if object_name.nil? && data.respond_to?(:first)
-- #require "pry"; binding.pry
first = data.first
object_name = data_name(first).to_s.pluralize if first.present?
end
When I comment it out, it shows the error again. Someone more clever than me help me with this.
