OK Kinda confused.
I have a hand full of environments (25 or so) and the get assigned to
various host groups based on platform etc. bla bla further not interesting.
I have 3 "core" host groups , one that sets base tools and configs like for
postfix etc., then one that sets security related items , and then one that
adds default users snmp etc. all these work int he environment master. so
far so good , all these work over that I have platform groups like our DNS
platform (env. dnsplatform), it has 3 sub groups dns dev (env. dnsdev) ,
DNS Caching (env. dnscaching) etc. you get the idea.
No all the way to the DNS platform host group inheritance works fine , but
all above that …not so much. The puppet run does see the inherited
classes but not their smart variable which consequently aren't transferred.
the odd thing is the failed puppet runs also never make it to foreman so
all is green in foreman …
A bit abotu my Puppet to add , as stated I have about 25 environments ,
most dont have any classes / modules associated with them but a couple like
the DNS Platform do.
The issue I see is that pupept does see the parametered classes but foreman
not , how do I fix this
thanks,
J.
Minor addition to show the difference per host the yaml file same parent
host group mind you. You will see it dropped the parameters :S
puppet run errors out with, which is logic as the parameter doesn't get
passed :
dnscaching [root@cache11.fra ~]# puppet agent -tv
Info: Retrieving plugin
Error: Could not retrieve catalog from remote server: Error 400 on SERVER:
Must pass location to Class[Default-security] on node cache11.fra.ns
classes:
default-all-hosts:
dellcommunity: value
default-security:
community: somevalue
contact: some email
git:
git-user:
hosts:
win-admin-users:
parameters:
puppetmaster:
hostgroup: SysEng-Defaults/Security/Core/DNS Platform
root_pw:
puppet_ca: 172.16.1.53
foreman_env: dnscachingint
owner_name: Admin User
owner_email:
dellcommunity:
domainname: ns
enable-puppetlabs-repo: 'true'
locationdc: fra
environment: dnscachingint
dnsserver: '1'
community: dns4allmon
classes:
default-all-hosts:
default-security:
git:
git-user:
hosts:
quagga-cache:
sudoers-cache:
unbound-cache:
win-admin-users:
parameters:
puppetmaster:
hostgroup: SysEng-Defaults/Security/Core/DNS Platform/DNS Caching
root_pw:
puppet_ca:
owner_email: email
domainname: ns
enable-puppetlabs-repo: 'true’
locationdc: fra
dnsserver: '1’
anycast_ipaddress: ipv4
anycast_ipaddress6: ipv6
anycast_ipaddress_2: ipv4
extern: '1’
quagga_bgp_neighbor: ipv4
quagga_bgp_neighbor6: ipv6
On Sunday, April 13, 2014 12:27:43 PM UTC+2, Jelle B. wrote:
OK Kinda confused.
I have 3 “core” host groups , one that sets base tools and configs like
for postfix etc., then one that sets security related items , and then one
that adds default users snmp etc. all these work int he environment master.
so far so good , all these work over that I have platform groups like our
DNS platform (env. dnsplatform), it has 3 sub groups dns dev (env. dnsdev)
, DNS Caching (env. dnscaching) etc. you get the idea.
classes but not their smart variable which consequently aren’t transferred.
foreman not , how do I fix this
thanks,
J.
