Upgraded to foreman 3.5 from 3.4 and Katello 4.75 from 4.6. Now my media installation of Rocky 9.1 installs Rocky 9.2
Continue to install Rocky 9.1 with my original Kickstarts, OS and Installation Media.
Redhat 8.8
During the installation a “dnf update” upgraded the kernel and I went from Redhat 8.7 to 8.8.
I thought maybe one of the dnf group installs in the kickstart might be upgrading the kernel during provisioning so I disabled all group package installations temporarily, but I still ended up with Rocky 9.2.
I’ll dig further into this tomorrow, but I thought maybe someone has seen this before and can point me in the right direction. My installation media is still pointing at my cached local repo which I mirrored off of rocky repos. Unless Rocky slipped a 9.2 into my 9.1 repo I’m not sure where this is coming from. I know centos will move older repos to a different URL when the latest comes out, but I’m not sure if Rocky does the same. In centos it goes from dl. to vault. in the URL.
Thanks.
Anyone? I see that 9.2 released in the last week. So I’m not sure if this is a Foreman problem, or a Rocky repository problem.
I’ve checked everything I can think of and spent over a day racking my brain. Operating system and installation media are definitely correct. No matter what I try 9.2 always installs. I also saw that 8.8 installs for a 8.7 provisioning template I just made a couple of weeks ago and 8.8 also just came out.
This is driving me nuts.
Hey again
Just to mention it here also again, it must be connected to what exactly is provided in the repo
parameter in the kickstart file, that gets rendered.
Do you have the update parameter set? If so I think the kickstart will update Rocky 9.1 to Rocky 9.2 by using “dnf update” during the kickstart process.
I originally thought it might be updating after installation, but since there were no other kernels on the system after installation I ruled that out. If it’s updating then I would assume it would clean up old kernels.
I had a quick look and didn’t see a parameter “update”. If that exists where do I find it?
It defaults to true, set a host parameter manually to override:
Type: Boolean
Value: false
