Approved Puppet module not supported in Foreman
Official augeas puppet module from doesn’t work in Foreman
See the module in Puppet Classes in Foreman webui
Ubuntu 18.04
If I’m not mistaken, this module doesn’t provide any classes, just type definitions - so not sure what exactly you’re expecting to see in the puppet classes page?
Thank you for your reply, i think i don’t understand the role of this module.
I don’t understand type definition and there roles in this module
Best regards
With type definition you get the possibility to define resources, so in this case the module " augeasproviders_grub" enables you to define resources like kernel_parameter, grub_config, grub_user and grub_menuentry.
To define this resources you will need to write your own puppet code or take a module which does this, but without a class structure around this module there is nothing Foreman can present to you in the frontend or your puppet as ENC.
The same problem exists if a module does not provide a class but a defined type which is nearly the same but written in Puppet syntax instead of Ruby.
Thank you very much for these detailed precisions, I understand much better the role of each elements.
Regards
