I don't have any problems with provisioning, but if I want to review the
provision template from Foreman web-interface I get the following error.
Host -> Templates -> provision template -> Review
Web-interface shows: "We're sorry, but something went wrong. We've been
notified about this issue and we'll take a look at it shortly."
In the log file /var/log/foreman/production.log I see:
Operation FAILED: undefined method `layout' for nil:NilClass
Completed 500 Internal Server Error in 12ms
ArgumentError (There was no default layout for UnattendedController in
#<ActionView::PathSet:0x0000000ad60380
@paths=[/usr/share/foreman/app/views,
/opt/rh/ruby193/root/usr/share/gems/gems/foreman_salt-1.1.1/app/views,
/opt/rh/ruby193/root/usr/share/gems/gems/foreman_docker-1.2.4/app/views,
/opt/rh/ruby193/root/usr/share/gems/gems/apipie-rails-0.2.6/app/views]>):
app/controllers/application_controller.rb:307:in generic_exception' lib/middleware/catch_json_parse_errors.rb:9:incall'
It's happening only with provision template and only with "Review". I can
edit all templates and review PXE, user data and finish template under host
page.
Perhaps check the host has a partition table assigned under the
Operating System tab, and re-save the host to be sure. "layout" is
related to partition tables.
> OperationFAILED:undefinedmethod `layout' for nil:NilClass
Foreman doesn't accept Salt keys automatically. I had to specify my domains
in autosign file.
Foreman_docker plugin causes me some troubles as well. I cannot create
Docker compute resource. The error in log file is:
CR_ID IS null
String does not start with the prefix 'encrypted-', so ForemanDocker::Docker docker.com was not decrypted
I don't know if it can be related, but I don't think I had a problem before
with reviewing provision template.
Provisioning on Bare Metal and VMWare and integration with Puppet works
fine.
Thanks a lot in advance.
> Dominic Cleal
> Red Hat Engineering
