Auto-Provisioning Discovered Bare-metal Host via PXE Issue
That's good news Lukas. Thank you.
··· On Wednesday, April 19, 2017 at 6:22:06 AM UTC-5, Lukas Zapletal wrote: > > Ok I finally reproduced. > > When domain is blank, autoprovisioning fails for no apparent reason, > logs are empty, something fails during orchestration and hosts are > getting discovered again (which fails since managed host already > exists). > > http://projects.theforeman.org/issues/19313 > > I will do my best to fix it this week, but I am on travel the week > after, crossing my fingers. > > LZ > > On Thu, Apr 13, 2017 at 4:28 PM, Garreat <jmie...@fgtsa.com > > wrote: > > I experience this issue. > > After clicking 'auto-provisioning' on a discovered host, the host entry > is > > created, the host reboots - but only to enter Foreman Discovery Image > PXE > > loop. > > My TFTP proxy is in healthy status as I can recreate PXE default no > prob. > > > > Now answering your checklist: > > - host is managed - yes - OK > > - provision method is "build" and not "image" - how to check this? I > can't > > see the 'build mode' checkbox for the newly created host > > - host has operating system set - yes (inherited from host group) - OK > > - host has pxe loader flag present (not set to blank or None) - how to > check > > this? > > - host has one provisioning NIC with valid MAC address - yes it does - > OK > > - a subnet is associated with the provisioning NIC - it is, but it's a > > subnet different than the one declared in machine's host group > > - the subnet has TFTP feature turned on - it does, and it's the same > TFTP > > proxy as in the subnet that I wanted > > > > Also, the 'domain' is blank for the fresh created host. > > The OS assigned to this host group has a valid PXElinux template > selected. > > > > Assume I'm not making any manual changes: > > - 'Build host' does nothing > > - 'Rebuild config' creates a PXE mac-template on TFTP immediatly > > > > facter -j output attached > > > > Thanks / Regards / Greetings > > > > W dniu wtorek, 11 kwietnia 2017 10:28:17 UTC+2 użytkownik Lukas Zapletal > > napisał: > >> > >> TFTP orchestration is not being triggered. It can be only performed > >> when all of these conditions are met: > >> > >> - host is managed > >> - provision method is "build" and not "image" > >> - host has operating system set > >> - host has pxe loader flag present (not set to blank or None) > >> - host has one provisioning NIC with valid MAC address > >> - a subnet is associated with the provisioning NIC > >> - the subnet has TFTP feature turned on > >> > >> Visit a host which failed provisioning and do this checklist please. > >> > >> LZ > >> > >> > > > > > > -- > Later, > Lukas @lzap Zapletal >
Here's the SQL debug log from 'successful' auto-provision (no PXE file
appears).
Please find attached.
Thanks/Regards
foreman_auto-prov_sql_log (5.87 KB)
exists).
Bug #19313: Auto-provisioning does not orchestrate TFTP - Discovery - Foreman
LZ
After clicking ‘auto-provisioning’ on a discovered host, the host entry
is
created, the host reboots - but only to enter Foreman Discovery Image PXE
loop.
My TFTP proxy is in healthy status as I can recreate PXE default no prob.
  • host is managed - yes - OK
  • provision method is “build” and not “image” - how to check this? I
    can’t
    see the ‘build mode’ checkbox for the newly created host
  • host has operating system set - yes (inherited from host group) - OK
  • host has pxe loader flag present (not set to blank or None) - how to
    check
    this?
  • host has one provisioning NIC with valid MAC address - yes it does - OK
  • a subnet is associated with the provisioning NIC - it is, but it’s a
    subnet different than the one declared in machine’s host group
  • the subnet has TFTP feature turned on - it does, and it’s the same TFTP
Also, the ‘domain’ is blank for the fresh created host.
selected.
Assume I’m not making any manual changes:
  • ‘Build host’ does nothing
  • ‘Rebuild config’ creates a PXE mac-template on TFTP immediatly
  • host is managed
LZ
Later,
Jacek Mierzwa | Systems Integration Engineer
Platform Management Division
And here is Foreman app debug-level log from 'successful' auto-provision
(no PXE file appears).
foreman_auto-prov_app_log (2.72 KB)
··· On Wed, Apr 19, 2017 at 2:13 PM, Jacek Mierzwa wrote:
Here’s the SQL debug log from ‘successful’ auto-provision (no PXE file
appears).
Thanks/Regards
exists).
LZ
is
PXE
loop.
prob.
    can’t
    check
    this?
    OK
    TFTP
selected.
  • host is managed
LZ
Later,
Same as previous, with enabled Foreman SQL logger. Please see attached.
W dniu środa, 19 kwietnia 2017 14:51:06 UTC+2 użytkownik Garreat napisał:
foreman_auto-prov_sql-logger (4.68 KB)
··· > > And here is Foreman app debug-level log from 'successful' auto-provision > (no PXE file appears). > > On Wed, Apr 19, 2017 at 2:13 PM, Jacek Mierzwa wrote: > >> Here's the SQL debug log from 'successful' auto-provision (no PXE file >> appears). >> Please find attached. >> >> Thanks/Regards >> >> On Wed, Apr 19, 2017 at 1:21 PM, Lukas Zapletal wrote: >> >>> Ok I finally reproduced. >>> >>> When domain is blank, autoprovisioning fails for no apparent reason, >>> logs are empty, something fails during orchestration and hosts are >>> getting discovered again (which fails since managed host already >>> exists). >>> >>> http://projects.theforeman.org/issues/19313 >>> >>> I will do my best to fix it this week, but I am on travel the week >>> after, crossing my fingers. >>> >>> LZ >>> >>> On Thu, Apr 13, 2017 at 4:28 PM, Garreat wrote: >>> > I experience this issue. >>> > After clicking 'auto-provisioning' on a discovered host, the host >>> entry is >>> > created, the host reboots - but only to enter Foreman Discovery Image >>> PXE >>> > loop. >>> > My TFTP proxy is in healthy status as I can recreate PXE default no >>> prob. >>> > >>> > Now answering your checklist: >>> > - host is managed - yes - OK >>> > - provision method is "build" and not "image" - how to check this? I >>> can't >>> > see the 'build mode' checkbox for the newly created host >>> > - host has operating system set - yes (inherited from host group) - OK >>> > - host has pxe loader flag present (not set to blank or None) - how to >>> check >>> > this? >>> > - host has one provisioning NIC with valid MAC address - yes it does - >>> OK >>> > - a subnet is associated with the provisioning NIC - it is, but it's a >>> > subnet different than the one declared in machine's host group >>> > - the subnet has TFTP feature turned on - it does, and it's the same >>> TFTP >>> > proxy as in the subnet that I wanted >>> > >>> > Also, the 'domain' is blank for the fresh created host. >>> > The OS assigned to this host group has a valid PXElinux template >>> selected. >>> > >>> > Assume I'm not making any manual changes: >>> > - 'Build host' does nothing >>> > - 'Rebuild config' creates a PXE mac-template on TFTP immediatly >>> > >>> > facter -j output attached >>> > >>> > Thanks / Regards / Greetings >>> > >>> > W dniu wtorek, 11 kwietnia 2017 10:28:17 UTC+2 użytkownik Lukas >>> Zapletal >>> > napisał: >>> >> >>> >> TFTP orchestration is not being triggered. It can be only performed >>> >> when all of these conditions are met: >>> >> >>> >> - host is managed >>> >> - provision method is "build" and not "image" >>> >> - host has operating system set >>> >> - host has pxe loader flag present (not set to blank or None) >>> >> - host has one provisioning NIC with valid MAC address >>> >> - a subnet is associated with the provisioning NIC >>> >> - the subnet has TFTP feature turned on >>> >> >>> >> Visit a host which failed provisioning and do this checklist please. >>> >> >>> >> LZ >>> >> >>> >> >>> > >>> >>> >>> >>> -- >>> Later, >>> Lukas @lzap Zapletal >>> >> >> >> >> -- >> >> *Jacek Mierzwa* | Systems Integration Engineer >> >> Platform Management Division >> >> >> >> > > > -- > > *Jacek Mierzwa* | Systems Integration Engineer > > Platform Management Division > > > >
Jacek, I apologize but what I meant was:
http://projects.theforeman.org/projects/foreman/wiki/Troubleshooting#Enable-detailed-SQL-logger-for-orchestration-messages
Chad, it looks like setting (a fake) domain did not help to Jacek, can you
try it? Did it help in your case? Associate Subnet with a Domain and then
set it in the Hostgroup.
LZ
··· On Wed, Apr 19, 2017 at 2:51 PM, Jacek Mierzwa wrote:
And here is Foreman app debug-level log from ‘successful’ auto-provision
appears).
Thanks/Regards
exists).
LZ
entry is
PXE
loop.
prob.
    can’t
    check
    this?
    OK
    TFTP
selected.
Zapletal
  • host is managed
LZ
Later,
Later,
I'm not sure I follow what your asking for Lukas.
··· On Wednesday, April 19, 2017 at 8:50:21 AM UTC-5, Lukas Zapletal wrote: > > Jacek, I apologize but what I meant was: > > > http://projects.theforeman.org/projects/foreman/wiki/Troubleshooting#Enable-detailed-SQL-logger-for-orchestration-messages > > Chad, it looks like setting (a fake) domain did not help to Jacek, can you > try it? Did it help in your case? Associate Subnet with a Domain and then > set it in the Hostgroup. > > LZ > > On Wed, Apr 19, 2017 at 2:51 PM, Jacek Mierzwa > wrote: > >> And here is Foreman app debug-level log from 'successful' auto-provision >> (no PXE file appears). >> >> On Wed, Apr 19, 2017 at 2:13 PM, Jacek Mierzwa > > wrote: >> >>> Here's the SQL debug log from 'successful' auto-provision (no PXE file >>> appears). >>> Please find attached. >>> >>> Thanks/Regards >>> >>> On Wed, Apr 19, 2017 at 1:21 PM, Lukas Zapletal >> > wrote: >>> >>>> Ok I finally reproduced. >>>> >>>> When domain is blank, autoprovisioning fails for no apparent reason, >>>> logs are empty, something fails during orchestration and hosts are >>>> getting discovered again (which fails since managed host already >>>> exists). >>>> >>>> http://projects.theforeman.org/issues/19313 >>>> >>>> I will do my best to fix it this week, but I am on travel the week >>>> after, crossing my fingers. >>>> >>>> LZ >>>> >>>> On Thu, Apr 13, 2017 at 4:28 PM, Garreat >>> > wrote: >>>> > I experience this issue. >>>> > After clicking 'auto-provisioning' on a discovered host, the host >>>> entry is >>>> > created, the host reboots - but only to enter Foreman Discovery Image >>>> PXE >>>> > loop. >>>> > My TFTP proxy is in healthy status as I can recreate PXE default no >>>> prob. >>>> > >>>> > Now answering your checklist: >>>> > - host is managed - yes - OK >>>> > - provision method is "build" and not "image" - how to check this? I >>>> can't >>>> > see the 'build mode' checkbox for the newly created host >>>> > - host has operating system set - yes (inherited from host group) - OK >>>> > - host has pxe loader flag present (not set to blank or None) - how >>>> to check >>>> > this? >>>> > - host has one provisioning NIC with valid MAC address - yes it does >>>> - OK >>>> > - a subnet is associated with the provisioning NIC - it is, but it's a >>>> > subnet different than the one declared in machine's host group >>>> > - the subnet has TFTP feature turned on - it does, and it's the same >>>> TFTP >>>> > proxy as in the subnet that I wanted >>>> > >>>> > Also, the 'domain' is blank for the fresh created host. >>>> > The OS assigned to this host group has a valid PXElinux template >>>> selected. >>>> > >>>> > Assume I'm not making any manual changes: >>>> > - 'Build host' does nothing >>>> > - 'Rebuild config' creates a PXE mac-template on TFTP immediatly >>>> > >>>> > facter -j output attached >>>> > >>>> > Thanks / Regards / Greetings >>>> > >>>> > W dniu wtorek, 11 kwietnia 2017 10:28:17 UTC+2 użytkownik Lukas >>>> Zapletal >>>> > napisał: >>>> >> >>>> >> TFTP orchestration is not being triggered. It can be only performed >>>> >> when all of these conditions are met: >>>> >> >>>> >> - host is managed >>>> >> - provision method is "build" and not "image" >>>> >> - host has operating system set >>>> >> - host has pxe loader flag present (not set to blank or None) >>>> >> - host has one provisioning NIC with valid MAC address >>>> >> - a subnet is associated with the provisioning NIC >>>> >> - the subnet has TFTP feature turned on >>>> >> >>>> >> Visit a host which failed provisioning and do this checklist please. >>>> >> >>>> >> LZ >>>> >> >>>> >> >>>> > >>>> >>>> >>>> >>>> -- >>>> Later, >>>> Lukas @lzap Zapletal >>>> >>> >>> >>> >>> -- >>> >>> *Jacek Mierzwa* | Systems Integration Engineer >>> >>> Platform Management Division >>> >>> >>> >>> >> >> >> -- >> >> *Jacek Mierzwa* | Systems Integration Engineer >> >> Platform Management Division >> >> >> >> > > > -- > Later, > Lukas @lzap Zapletal >
Ok thanks, I can see that either TFTP nor DHCP steps are not getting
orchestrated at all. I suspect that this returns false:
Maybe if you are able to break up the tftp_ready? method into multiple
lines and do some debug logger outputs of all individual statements in
there to see which does not trigger TFTP orchestration.
Strange is we should see DHCP orchestration but that does not happen as
well. Are NICs created correctly? Is there a subnet set?
Unfortunately I have engagement at customer site for whole week, I will
carry on the week after. We need to solve this.
··· On Wed, Apr 19, 2017 at 4:58 PM, Chad Schroeder < chads.finishing.strong@gmail.com> wrote:
I’m not sure I follow what your asking for Lukas.
you try it? Did it help in your case? Associate Subnet with a Domain and
then set it in the Hostgroup.
LZ
appears).
Thanks/Regards
exists).
LZ
entry is
Image PXE
loop.
prob.
    can’t
    OK
    to check
    this?
  • OK
    a
    TFTP
selected.
Zapletal
  • host is managed
LZ
Later,
Later,
Later,
Lukas, just for the record, I don't use DHCP orchestration at all.
I have a smart-proxy DHCP instance, but it's not assigned to the subnet.
Reason behind this: Feature #2800: Ability to push DHCP settings to two servers - Foreman .
The auto-provisioned host has NICs correctly created and a subnet assigned
to the prov interface.
Just the domain left blank – that was mentioned before.
I will play with tftp.rb next week. I have a dockerized setup, so
traditional debugging includes additional steps.
Thanks for your effort and have a nice weekend!
foreman/app at develop · theforeman/foreman · GitHub
models/concerns/orchestration/tftp.rb#L21
On Wed, Apr 19, 2017 at 4:58 PM, Chad Schroeder < > chads.finishing.strong@gmail.com> wrote:
LZ
auto-provision (no PXE file appears).
appears).
Thanks/Regards
On Wed, Apr 19, 2017 at 1:21 PM, Lukas Zapletal lz...@redhat.com >>>>> wrote:
exists).
LZ
entry is
Image PXE
loop.
prob.
    I can’t
    OK
    to check
    this?
    does - OK
    it’s a
    same TFTP
selected.
Zapletal
  • host is managed
please.
LZ
Later,
Later,
Later,
Lukas,
Hope this helps:
On initial discovery, the results of tftp_ready? are:
host.nil: false
host.managed: false
Clicking "Auto Provision" on the discovered host in the "Discovered Hosts"
menu:
host.nil: false
host.managed: false
Clicking "Edit" on the host in "All Hosts" menu and then clicking submit:
host.nil: false
host.managed: true
managed: true
provision: true
host: mac00224d4fb56a.sub.domain.net
host.operatingsystem: CentOS 7.3.1611
host.pxe_loader.present: true
pxe_build?: true
SETTINGS[:unattended]: true
Chad
··· On Friday, April 21, 2017 at 8:13:18 AM UTC-5, Lukas Zapletal wrote: > > Ok thanks, I can see that either TFTP nor DHCP steps are not getting > orchestrated at all. I suspect that this returns false: > > > https://github.com/theforeman/foreman/blob/develop/app/models/concerns/orchestration/tftp.rb#L21 > > Maybe if you are able to break up the tftp_ready? method into multiple > lines and do some debug logger outputs of all individual statements in > there to see which does not trigger TFTP orchestration. > > Strange is we should see DHCP orchestration but that does not happen as > well. Are NICs created correctly? Is there a subnet set? > > Unfortunately I have engagement at customer site for whole week, I will > carry on the week after. We need to solve this. > > On Wed, Apr 19, 2017 at 4:58 PM, Chad Schroeder > wrote: > >> I'm not sure I follow what your asking for Lukas. >> >> On Wednesday, April 19, 2017 at 8:50:21 AM UTC-5, Lukas Zapletal wrote: >>> >>> Jacek, I apologize but what I meant was: >>> >>> >>> http://projects.theforeman.org/projects/foreman/wiki/Troubleshooting#Enable-detailed-SQL-logger-for-orchestration-messages >>> >>> Chad, it looks like setting (a fake) domain did not help to Jacek, can >>> you try it? Did it help in your case? Associate Subnet with a Domain and >>> then set it in the Hostgroup. >>> >>> LZ >>> >>> On Wed, Apr 19, 2017 at 2:51 PM, Jacek Mierzwa >>> wrote: >>> >>>> And here is Foreman app debug-level log from 'successful' >>>> auto-provision (no PXE file appears). >>>> >>>> On Wed, Apr 19, 2017 at 2:13 PM, Jacek Mierzwa >>>> wrote: >>>> >>>>> Here's the SQL debug log from 'successful' auto-provision (no PXE file >>>>> appears). >>>>> Please find attached. >>>>> >>>>> Thanks/Regards >>>>> >>>>> On Wed, Apr 19, 2017 at 1:21 PM, Lukas Zapletal >>>>> wrote: >>>>> >>>>>> Ok I finally reproduced. >>>>>> >>>>>> When domain is blank, autoprovisioning fails for no apparent reason, >>>>>> logs are empty, something fails during orchestration and hosts are >>>>>> getting discovered again (which fails since managed host already >>>>>> exists). >>>>>> >>>>>> http://projects.theforeman.org/issues/19313 >>>>>> >>>>>> I will do my best to fix it this week, but I am on travel the week >>>>>> after, crossing my fingers. >>>>>> >>>>>> LZ >>>>>> >>>>>> On Thu, Apr 13, 2017 at 4:28 PM, Garreat wrote: >>>>>> > I experience this issue. >>>>>> > After clicking 'auto-provisioning' on a discovered host, the host >>>>>> entry is >>>>>> > created, the host reboots - but only to enter Foreman Discovery >>>>>> Image PXE >>>>>> > loop. >>>>>> > My TFTP proxy is in healthy status as I can recreate PXE default no >>>>>> prob. >>>>>> > >>>>>> > Now answering your checklist: >>>>>> > - host is managed - yes - OK >>>>>> > - provision method is "build" and not "image" - how to check this? >>>>>> I can't >>>>>> > see the 'build mode' checkbox for the newly created host >>>>>> > - host has operating system set - yes (inherited from host group) - >>>>>> OK >>>>>> > - host has pxe loader flag present (not set to blank or None) - how >>>>>> to check >>>>>> > this? >>>>>> > - host has one provisioning NIC with valid MAC address - yes it >>>>>> does - OK >>>>>> > - a subnet is associated with the provisioning NIC - it is, but >>>>>> it's a >>>>>> > subnet different than the one declared in machine's host group >>>>>> > - the subnet has TFTP feature turned on - it does, and it's the >>>>>> same TFTP >>>>>> > proxy as in the subnet that I wanted >>>>>> > >>>>>> > Also, the 'domain' is blank for the fresh created host. >>>>>> > The OS assigned to this host group has a valid PXElinux template >>>>>> selected. >>>>>> > >>>>>> > Assume I'm not making any manual changes: >>>>>> > - 'Build host' does nothing >>>>>> > - 'Rebuild config' creates a PXE mac-template on TFTP immediatly >>>>>> > >>>>>> > facter -j output attached >>>>>> > >>>>>> > Thanks / Regards / Greetings >>>>>> > >>>>>> > W dniu wtorek, 11 kwietnia 2017 10:28:17 UTC+2 użytkownik Lukas >>>>>> Zapletal >>>>>> > napisał: >>>>>> >> >>>>>> >> TFTP orchestration is not being triggered. It can be only performed >>>>>> >> when all of these conditions are met: >>>>>> >> >>>>>> >> - host is managed >>>>>> >> - provision method is "build" and not "image" >>>>>> >> - host has operating system set >>>>>> >> - host has pxe loader flag present (not set to blank or None) >>>>>> >> - host has one provisioning NIC with valid MAC address >>>>>> >> - a subnet is associated with the provisioning NIC >>>>>> >> - the subnet has TFTP feature turned on >>>>>> >> >>>>>> >> Visit a host which failed provisioning and do this checklist >>>>>> please. >>>>>> >> >>>>>> >> LZ >>>>>> >> >>>>>> >> >>>>>> > >>>>>> >>>>>> >>>>>> >>>>>> -- >>>>>> Later, >>>>>> Lukas @lzap Zapletal >>>>>> >>>>> >>>>> >>>>> >>>>> -- >>>>> >>>>> *Jacek Mierzwa* | Systems Integration Engineer >>>>> >>>>> Platform Management Division >>>>> >>>>> >>>>> >>>>> >>>> >>>> >>>> -- >>>> >>>> *Jacek Mierzwa* | Systems Integration Engineer >>>> >>>> Platform Management Division >>>> >>>> >>>> >>>> >>> >>> >>> -- >>> Later, >>> Lukas @lzap Zapletal >>> >> > > > -- > Later, > Lukas @lzap Zapletal >
I have tested auto-provisioning in 1.15 RC1.
Now it also matters if hostname pattern is used in discovery rule.
No hostname in discovery rule:
  • auto-provision does NOT create PXE file
  • manually select 'Build' on auto-provisioned host = PXE file created!
  • manually select 'Rebuild config' on auto-privisioned host = nothing
Hostname pattern used in discovery rule:
  • manually select 'Build' on auto-provisioned host = no PXE file + hostname
    reverted to default (macXXXXXXXXXX)
  • manually select 'Rebuild config' on auto-privisioned host = no PXE file +
    hostname reverted to default (macXXXXXXXXXX)
  • after the hostname is reverted to default:
    • manually select 'Build' on host = no PXE file
    • manually select 'Rebuild config' on host = PXE file created!
I think this goes beyond tftp.rb :S
··· On Tue, Apr 25, 2017 at 6:40 PM, Chad Schroeder < chads.finishing.strong@gmail.com> wrote:
Lukas,
Hope this helps:
host.nil: false
host.managed: false
Clicking “Auto Provision” on the discovered host in the “Discovered Hosts”
menu:
host.nil: false
host.managed: false
Clicking “Edit” on the host in “All Hosts” menu and then clicking submit:
host.nil: false
host.managed: true
managed: true
provision: true
pxe_build?: true
Chad
On Wed, Apr 19, 2017 at 4:58 PM, Chad Schroeder <chads.finis...@gmail.com >> > wrote:
LZ
On Wed, Apr 19, 2017 at 2:13 PM, Jacek Mierzwa jmie...@lbisa.com >>>>> wrote:
file appears).
Thanks/Regards
On Wed, Apr 19, 2017 at 1:21 PM, Lukas Zapletal lz...@redhat.com >>>>>> wrote:
exists).
LZ
entry is
Image PXE
loop.
no prob.
    I can’t
  • OK
    how to check
    this?
    does - OK
    it’s a
    same TFTP
selected.
Zapletal
performed
  • host is managed
please.
LZ
Later,
Later,
Later,
Jacek, for 1.15 there is another bug for autoprovisioning that has been
fixed in RC2:
Try with RC2 please. Anyway, one questions for all of you - how does
Foreman recognize your NICs after host is discovered?
Can you make screenshot of recognized NICs in the UI (discovered host
detail page)? Interested in which interface is set as primary/provisioning.
Also which subnet has been detected? Does it match primary/provisioning
NIC? Is TFTP associated with this subnet?
What version of the FDI (image) do you use? If this is a regression can you
try with older version?
Initially I thought it's caused by domain but that was wrong assumption.
  • manually select ‘Build’ on auto-provisioned host = PXE file created!
  • manually select ‘Rebuild config’ on auto-privisioned host = nothing
  • manually select ‘Build’ on auto-provisioned host = no PXE file +
  • manually select ‘Rebuild config’ on auto-privisioned host = no PXE file
  • hostname reverted to default (macXXXXXXXXXX)
    • manually select ‘Build’ on host = no PXE file
    • manually select ‘Rebuild config’ on host = PXE file created!
On Tue, Apr 25, 2017 at 6:40 PM, Chad Schroeder < > chads.finishing.strong@gmail.com> wrote:
Lukas,
Hope this helps:
host.nil: false
host.managed: false
Hosts” menu:
host.nil: false
host.managed: false
host.nil: false
host.managed: true
managed: true
provision: true
pxe_build?: true
Chad
On Wed, Apr 19, 2017 at 4:58 PM, Chad Schroeder < >>> chads.finis...@gmail.com> wrote:
LZ
On Wed, Apr 19, 2017 at 2:51 PM, Jacek Mierzwa jmie...@lbisa.com >>>>> wrote:
On Wed, Apr 19, 2017 at 2:13 PM, Jacek Mierzwa jmie...@lbisa.com >>>>>> wrote:
file appears).
Thanks/Regards
On Wed, Apr 19, 2017 at 1:21 PM, Lukas Zapletal lz...@redhat.com >>>>>>> wrote:
exists).
LZ
entry is
Image PXE
loop.
no prob.
    this? I can’t
  • OK
    how to check
    this?
    does - OK
    it’s a
    same TFTP
selected.
Zapletal
performed
  • host is managed
please.
LZ
Later,
Later,
Later,
Later,
Nah I cannot reproduce it in my libvirt environment, I guess this has
something to do with IPMI. Could you try to add "ipmi_*" facts into ignored
facts so IPMI NIC is not created during discovery? Does it help?
fixed in RC2:
Bug #19409: Auto provision does not work after taxonomy fix - Discovery - Foreman
you try with older version?
Initially I thought it’s caused by domain but that was wrong assumption.
On Tue, Apr 25, 2017 at 6:40 PM, Chad Schroeder < >> chads.finishing.strong@gmail.com> wrote:
Lukas,
Hope this helps:
host.nil: false
host.managed: false
Hosts” menu:
host.nil: false
host.managed: false
host.nil: false
host.managed: true
managed: true
provision: true
pxe_build?: true
Chad
On Wed, Apr 19, 2017 at 4:58 PM, Chad Schroeder < >>>> chads.finis...@gmail.com> wrote:
can you try it? Did it help in your case? Associate Subnet with a Domain
and then set it in the Hostgroup.
LZ
On Wed, Apr 19, 2017 at 2:51 PM, Jacek Mierzwa jmie...@lbisa.com >>>>>> wrote:
On Wed, Apr 19, 2017 at 2:13 PM, Jacek Mierzwa jmie...@lbisa.com >>>>>>> wrote:
file appears).
Thanks/Regards
On Wed, Apr 19, 2017 at 1:21 PM, Lukas Zapletal lz...@redhat.com >>>>>>>> wrote:
reason,
exists).
LZ
host entry is
Image PXE
loop.
no prob.
    this? I can’t
    group) - OK
    how to check
    this?
    does - OK
    it’s a
    same TFTP
selected.
Zapletal
performed
  • host is managed
please.
LZ
Later,
Later,
Later,
Later,
Later,
Just tested on 1.15 RC2. Current state:
    hostname NOT reverted to default (macXXXXXXXXXX) <— only change here
    (bolded)
Per your screenshot request:
something to do with IPMI. Could you try to add “ipmi_*” facts into ignored
fixed in RC2:
    file + hostname reverted to default (macXXXXXXXXXX)
On Tue, Apr 25, 2017 at 6:40 PM, Chad Schroeder < >>> chads.finishing.strong@gmail.com> wrote:
Lukas,
Hope this helps:
host.nil: false
host.managed: false
Hosts” menu:
host.nil: false
host.managed: false
submit:
host.nil: false
host.managed: true
managed: true
provision: true
pxe_build?: true
Chad
as well. Are NICs created correctly? Is there a subnet set?
will carry on the week after. We need to solve this.
On Wed, Apr 19, 2017 at 4:58 PM, Chad Schroeder < >>>>> chads.finis...@gmail.com> wrote:
On Wednesday, April 19, 2017 at 8:50:21 AM UTC-5, Lukas Zapletal >>>>>> wrote:
LZ
On Wed, Apr 19, 2017 at 2:51 PM, Jacek Mierzwa jmie...@lbisa.com >>>>>>> wrote:
On Wed, Apr 19, 2017 at 2:13 PM, Jacek Mierzwa jmie...@lbisa.com >>>>>>>> wrote:
file appears).
Thanks/Regards
On Wed, Apr 19, 2017 at 1:21 PM, Lukas Zapletal lz...@redhat.com >>>>>>>>> wrote:
reason,
exists).
LZ
host entry is
Image PXE
loop.
default no prob.
    this? I can’t
    group) - OK
    how to check
    this?
    does - OK
    it’s a
    same TFTP
template selected.
Zapletal
performed
  • host is managed
please.
LZ
Later,
Later,
Later,
Later,
Later,
Any progress to report Lukas?
··· On Wednesday, May 3, 2017 at 4:07:46 AM UTC-5, Lukas Zapletal wrote: > > Nah I cannot reproduce it in my libvirt environment, I guess this has > something to do with IPMI. Could you try to add "ipmi_*" facts into ignored > facts so IPMI NIC is not created during discovery? Does it help? > > On Wed, May 3, 2017 at 10:54 AM, Lukas Zapletal > wrote: > >> Jacek, for 1.15 there is another bug for autoprovisioning that has been >> fixed in RC2: >> >> http://projects.theforeman.org/issues/19409 >> >> Try with RC2 please. Anyway, one questions for all of you - how does >> Foreman recognize your NICs after host is discovered? >> >> Can you make screenshot of recognized NICs in the UI (discovered host >> detail page)? Interested in which interface is set as primary/provisioning. >> >> Also which subnet has been detected? Does it match primary/provisioning >> NIC? Is TFTP associated with this subnet? >> >> What version of the FDI (image) do you use? If this is a regression can >> you try with older version? >> >> Initially I thought it's caused by domain but that was wrong assumption. >> >> On Fri, Apr 28, 2017 at 12:27 PM, Jacek Mierzwa > > wrote: >> >>> I have tested auto-provisioning in 1.15 RC1. >>> Now it also matters if hostname pattern is used in discovery rule. >>> >>> No hostname in discovery rule: >>> - auto-provision does NOT create PXE file >>> - manually select 'Build' on auto-provisioned host = PXE file created! >>> - manually select 'Rebuild config' on auto-privisioned host = nothing >>> >>> Hostname pattern used in discovery rule: >>> - auto-provision does NOT create PXE file >>> - manually select 'Build' on auto-provisioned host = no PXE file + >>> hostname reverted to default (macXXXXXXXXXX) >>> - manually select 'Rebuild config' on auto-privisioned host = no PXE >>> file + hostname reverted to default (macXXXXXXXXXX) >>> - after the hostname is reverted to default: >>> - manually select 'Build' on host = no PXE file >>> - manually select 'Rebuild config' on host = PXE file created! >>> >>> >>> I think this goes beyond tftp.rb :S >>> >>> On Tue, Apr 25, 2017 at 6:40 PM, Chad Schroeder < >>> chads.finis...@gmail.com > wrote: >>> >>>> Lukas, >>>> >>>> Hope this helps: >>>> >>>> On initial discovery, the results of tftp_ready? are: >>>> host.nil: false >>>> host.managed: false >>>> >>>> Clicking "Auto Provision" on the discovered host in the "Discovered >>>> Hosts" menu: >>>> host.nil: false >>>> host.managed: false >>>> >>>> Clicking "Edit" on the host in "All Hosts" menu and then clicking >>>> submit: >>>> host.nil: false >>>> host.managed: true >>>> managed: true >>>> provision: true >>>> host: mac00224d4fb56a.sub.domain.net >>>> host.operatingsystem: CentOS 7.3.1611 >>>> host.pxe_loader.present: true >>>> pxe_build?: true >>>> SETTINGS[:unattended]: true >>>> >>>> Chad >>>> >>>> On Friday, April 21, 2017 at 8:13:18 AM UTC-5, Lukas Zapletal wrote: >>>>> >>>>> Ok thanks, I can see that either TFTP nor DHCP steps are not getting >>>>> orchestrated at all. I suspect that this returns false: >>>>> >>>>> >>>>> https://github.com/theforeman/foreman/blob/develop/app/models/concerns/orchestration/tftp.rb#L21 >>>>> >>>>> Maybe if you are able to break up the tftp_ready? method into multiple >>>>> lines and do some debug logger outputs of all individual statements in >>>>> there to see which does not trigger TFTP orchestration. >>>>> >>>>> Strange is we should see DHCP orchestration but that does not happen >>>>> as well. Are NICs created correctly? Is there a subnet set? >>>>> >>>>> Unfortunately I have engagement at customer site for whole week, I >>>>> will carry on the week after. We need to solve this. >>>>> >>>>> On Wed, Apr 19, 2017 at 4:58 PM, Chad Schroeder < >>>>> chads.finis...@gmail.com> wrote: >>>>> >>>>>> I'm not sure I follow what your asking for Lukas. >>>>>> >>>>>> On Wednesday, April 19, 2017 at 8:50:21 AM UTC-5, Lukas Zapletal >>>>>> wrote: >>>>>>> >>>>>>> Jacek, I apologize but what I meant was: >>>>>>> >>>>>>> >>>>>>> http://projects.theforeman.org/projects/foreman/wiki/Troubleshooting#Enable-detailed-SQL-logger-for-orchestration-messages >>>>>>> >>>>>>> Chad, it looks like setting (a fake) domain did not help to Jacek, >>>>>>> can you try it? Did it help in your case? Associate Subnet with a Domain >>>>>>> and then set it in the Hostgroup. >>>>>>> >>>>>>> LZ >>>>>>> >>>>>>> On Wed, Apr 19, 2017 at 2:51 PM, Jacek Mierzwa >>>>>>> wrote: >>>>>>> >>>>>>>> And here is Foreman app debug-level log from 'successful' >>>>>>>> auto-provision (no PXE file appears). >>>>>>>> >>>>>>>> On Wed, Apr 19, 2017 at 2:13 PM, Jacek Mierzwa >>>>>>>> wrote: >>>>>>>> >>>>>>>>> Here's the SQL debug log from 'successful' auto-provision (no PXE >>>>>>>>> file appears). >>>>>>>>> Please find attached. >>>>>>>>> >>>>>>>>> Thanks/Regards >>>>>>>>> >>>>>>>>> On Wed, Apr 19, 2017 at 1:21 PM, Lukas Zapletal >>>>>>>>> wrote: >>>>>>>>> >>>>>>>>>> Ok I finally reproduced. >>>>>>>>>> >>>>>>>>>> When domain is blank, autoprovisioning fails for no apparent >>>>>>>>>> reason, >>>>>>>>>> logs are empty, something fails during orchestration and hosts are >>>>>>>>>> getting discovered again (which fails since managed host already >>>>>>>>>> exists). >>>>>>>>>> >>>>>>>>>> http://projects.theforeman.org/issues/19313 >>>>>>>>>> >>>>>>>>>> I will do my best to fix it this week, but I am on travel the week >>>>>>>>>> after, crossing my fingers. >>>>>>>>>> >>>>>>>>>> LZ >>>>>>>>>> >>>>>>>>>> On Thu, Apr 13, 2017 at 4:28 PM, Garreat >>>>>>>>>> wrote: >>>>>>>>>> > I experience this issue. >>>>>>>>>> > After clicking 'auto-provisioning' on a discovered host, the >>>>>>>>>> host entry is >>>>>>>>>> > created, the host reboots - but only to enter Foreman Discovery >>>>>>>>>> Image PXE >>>>>>>>>> > loop. >>>>>>>>>> > My TFTP proxy is in healthy status as I can recreate PXE >>>>>>>>>> default no prob. >>>>>>>>>> > >>>>>>>>>> > Now answering your checklist: >>>>>>>>>> > - host is managed - yes - OK >>>>>>>>>> > - provision method is "build" and not "image" - how to check >>>>>>>>>> this? I can't >>>>>>>>>> > see the 'build mode' checkbox for the newly created host >>>>>>>>>> > - host has operating system set - yes (inherited from host >>>>>>>>>> group) - OK >>>>>>>>>> > - host has pxe loader flag present (not set to blank or None) - >>>>>>>>>> how to check >>>>>>>>>> > this? >>>>>>>>>> > - host has one provisioning NIC with valid MAC address - yes it >>>>>>>>>> does - OK >>>>>>>>>> > - a subnet is associated with the provisioning NIC - it is, but >>>>>>>>>> it's a >>>>>>>>>> > subnet different than the one declared in machine's host group >>>>>>>>>> > - the subnet has TFTP feature turned on - it does, and it's the >>>>>>>>>> same TFTP >>>>>>>>>> > proxy as in the subnet that I wanted >>>>>>>>>> > >>>>>>>>>> > Also, the 'domain' is blank for the fresh created host. >>>>>>>>>> > The OS assigned to this host group has a valid PXElinux >>>>>>>>>> template selected. >>>>>>>>>> > >>>>>>>>>> > Assume I'm not making any manual changes: >>>>>>>>>> > - 'Build host' does nothing >>>>>>>>>> > - 'Rebuild config' creates a PXE mac-template on TFTP immediatly >>>>>>>>>> > >>>>>>>>>> > facter -j output attached >>>>>>>>>> > >>>>>>>>>> > Thanks / Regards / Greetings >>>>>>>>>> > >>>>>>>>>> > W dniu wtorek, 11 kwietnia 2017 10:28:17 UTC+2 użytkownik Lukas >>>>>>>>>> Zapletal >>>>>>>>>> > napisał: >>>>>>>>>> >> >>>>>>>>>> >> TFTP orchestration is not being triggered. It can be only >>>>>>>>>> performed >>>>>>>>>> >> when all of these conditions are met: >>>>>>>>>> >> >>>>>>>>>> >> - host is managed >>>>>>>>>> >> - provision method is "build" and not "image" >>>>>>>>>> >> - host has operating system set >>>>>>>>>> >> - host has pxe loader flag present (not set to blank or None) >>>>>>>>>> >> - host has one provisioning NIC with valid MAC address >>>>>>>>>> >> - a subnet is associated with the provisioning NIC >>>>>>>>>> >> - the subnet has TFTP feature turned on >>>>>>>>>> >> >>>>>>>>>> >> Visit a host which failed provisioning and do this checklist >>>>>>>>>> please. >>>>>>>>>> >> >>>>>>>>>> >> LZ >>>>>>>>>> >> >>>>>>>>>> >> >>>>>>>>>> > >>>>>>>>>> >>>>>>>>>> >>>>>>>>>> >>>>>>>>>> -- >>>>>>>>>> Later, >>>>>>>>>> Lukas @lzap Zapletal >>>>>>>>>> >>>>>>>>> >>>>>>>>> >>>>>>>>> >>>>>>>>> -- >>>>>>>>> >>>>>>>>> *Jacek Mierzwa* | Systems Integration Engineer >>>>>>>>> >>>>>>>>> Platform Management Division >>>>>>>>> >>>>>>>>> >>>>>>>>> >>>>>>>>> >>>>>>>> >>>>>>>> >>>>>>>> -- >>>>>>>> >>>>>>>> *Jacek Mierzwa* | Systems Integration Engineer >>>>>>>> >>>>>>>> Platform Management Division >>>>>>>> >>>>>>>> >>>>>>>> >>>>>>>> >>>>>>> >>>>>>> >>>>>>> -- >>>>>>> Later, >>>>>>> Lukas @lzap Zapletal >>>>>>> >>>>>> >>>>> >>>>> >>>>> -- >>>>> Later, >>>>> Lukas @lzap Zapletal >>>>> >>>> >>> >>> >>> -- >>> >>> *Jacek Mierzwa* | Systems Integration Engineer >>> >>> Platform Management Division >>> >>> >>> >>> >> >> >> -- >> Later, >> Lukas @lzap Zapletal >> > > > > -- > Later, > Lukas @lzap Zapletal >
Just for the record, no IPMI here.
  • hostname NOT reverted to default (macXXXXXXXXXX) <— only change
    here (bolded)
fixed in RC2:
On Fri, Apr 28, 2017 at 12:27 PM, Jacek Mierzwa jmierzwa@lbisa.com >>> wrote:
On Tue, Apr 25, 2017 at 6:40 PM, Chad Schroeder < >>>> chads.finishing.strong@gmail.com> wrote:
Lukas,
Hope this helps:
host.nil: false
host.managed: false
Hosts” menu:
host.nil: false
host.managed: false
submit:
host.nil: false
host.managed: true
managed: true
provision: true
pxe_build?: true
Chad
multiple lines and do some debug logger outputs of all individual
statements in there to see which does not trigger TFTP orchestration.
On Wed, Apr 19, 2017 at 4:58 PM, Chad Schroeder < >>>>>> chads.finis...@gmail.com> wrote:
On Wednesday, April 19, 2017 at 8:50:21 AM UTC-5, Lukas Zapletal >>>>>>> wrote:
LZ
On Wed, Apr 19, 2017 at 2:51 PM, Jacek Mierzwa jmie...@lbisa.com >>>>>>>> wrote:
On Wed, Apr 19, 2017 at 2:13 PM, Jacek Mierzwa jmie...@lbisa.com >>>>>>>>> wrote:
file appears).
Thanks/Regards
On Wed, Apr 19, 2017 at 1:21 PM, Lukas Zapletal <lz...@redhat.com >>>>>>>>>> > wrote:
reason,
are
exists).
week
LZ
On Thu, Apr 13, 2017 at 4:28 PM, Garreat jmie...@fgtsa.com >>>>>>>>>>> wrote:
host entry is
Discovery Image PXE
loop.
default no prob.
    this? I can’t
    group) - OK
  • how to check
this?
    it does - OK
    but it’s a
    the same TFTP
template selected.
    immediatly
Lukas Zapletal
performed
  • host is managed
please.
LZ
Later,
Later,
Later,
Later,
Later,
Working on it, no ETA but my priority for these days.
LZ
··· On Fri, May 12, 2017 at 2:21 PM, Chad Schroeder < chads.finishing.strong@gmail.com> wrote:
fixed in RC2:
On Tue, Apr 25, 2017 at 6:40 PM, Chad Schroeder < >>>> chads.finis...@gmail.com> wrote:
Lukas,
Hope this helps:
host.nil: false
host.managed: false
Hosts” menu:
host.nil: false
host.managed: false
submit:
host.nil: false
host.managed: true
managed: true
provision: true
pxe_build?: true
Chad
LZ
file appears).
Thanks/Regards
reason,
are
exists).
week
LZ
host entry is
Discovery Image PXE
loop.
default no prob.
    this? I can’t
    group) - OK
  • how to check
this?
    it does - OK
    but it’s a
    the same TFTP
template selected.
    immediatly
Lukas Zapletal
performed
  • host is managed
please.
LZ
Later,
Later,
Later,
Later,
Later,
Later,
Chad,
when a host is discovered, it should be discovered in a subnet. This is
shown on the list of discovered hosts. Do you see those set correctly?
Workaround is to have such a subnet defined so it is assigned during
discovery.
fixed in RC2:
Lukas,
Hope this helps:
host.nil: false
host.managed: false
Hosts” menu:
host.nil: false
host.managed: false
submit:
host.nil: false
host.managed: true
managed: true
provision: true
pxe_build?: true
Chad
LZ
file appears).
Thanks/Regards
reason,
are
exists).
week
LZ
host entry is
Discovery Image PXE
loop.
default no prob.
    this? I can’t
    group) - OK
  • how to check
this?
    it does - OK
    but it’s a
    the same TFTP
template selected.
    immediatly
Lukas Zapletal
performed
  • host is managed
please.
LZ
Later,
Later,
Later,
Later,
Later,
Later,
FDI image 3.4.0 (4291ca7)
Sorry for multi posts…
    here (bolded)
fixed in RC2:
On Fri, Apr 28, 2017 at 12:27 PM, Jacek Mierzwa jmierzwa@lbisa.com >>>> wrote:
On Tue, Apr 25, 2017 at 6:40 PM, Chad Schroeder < >>>>> chads.finishing.strong@gmail.com> wrote:
Lukas,
Hope this helps:
host.nil: false
host.managed: false
Hosts” menu:
host.nil: false
host.managed: false
submit:
host.nil: false
host.managed: true
managed: true
provision: true
pxe_build?: true
Chad
On Wed, Apr 19, 2017 at 4:58 PM, Chad Schroeder < >>>>>>> chads.finis...@gmail.com> wrote:
On Wednesday, April 19, 2017 at 8:50:21 AM UTC-5, Lukas Zapletal >>>>>>>> wrote:
LZ
On Wed, Apr 19, 2017 at 2:51 PM, Jacek Mierzwa jmie...@lbisa.com >>>>>>>>> wrote:
On Wed, Apr 19, 2017 at 2:13 PM, Jacek Mierzwa <jmie...@lbisa.com >>>>>>>>>> > wrote:
PXE file appears).
Thanks/Regards
On Wed, Apr 19, 2017 at 1:21 PM, Lukas Zapletal < >>>>>>>>>>> lz...@redhat.com> wrote:
reason,
are
exists).
week
LZ
On Thu, Apr 13, 2017 at 4:28 PM, Garreat jmie...@fgtsa.com >>>>>>>>>>>> wrote:
host entry is
Discovery Image PXE
loop.
default no prob.
    this? I can’t
    group) - OK
  • how to check
this?
    it does - OK
    but it’s a
    the same TFTP
template selected.
    immediatly
Lukas Zapletal
performed
  • host is managed
please.
LZ
Later,
Later,
Later,
Later,
Later,
Chad, one more question - what subnet the primary interface of your
discovered node is connected to, what IP address it was assigned and what
subnet have you set in the hostgroup?
These three must match, can you check this?
LZ
··· On Sun, May 14, 2017 at 8:43 PM, Lukas Zapletal wrote:
Chad,
discovery.
On Fri, May 12, 2017 at 2:21 PM, Chad Schroeder < > chads.finishing.strong@gmail.com> wrote:
fixed in RC2:
On Fri, Apr 28, 2017 at 12:27 PM, Jacek Mierzwa jmie...@lbisa.com >>>> wrote:
On Tue, Apr 25, 2017 at 6:40 PM, Chad Schroeder < >>>>> chads.finis...@gmail.com> wrote:
Lukas,
Hope this helps:
host.nil: false
host.managed: false
Hosts” menu:
host.nil: false
host.managed: false
submit:
host.nil: false
host.managed: true
managed: true
provision: true
pxe_build?: true
Chad
LZ
PXE file appears).
Thanks/Regards
reason,
are
exists).
week
LZ
host entry is
Discovery Image PXE
loop.
default no prob.
    this? I can’t
    group) - OK
  • how to check
this?
    it does - OK
    but it’s a
    the same TFTP
template selected.
    immediatly
Lukas Zapletal
performed
  • host is managed
please.
LZ
Later,
Later,
Later,
Later,
Later,
Later,
Later,
This is for my case:
  • subnet assigned to the host group
​- discovered host has primary NIC in the subnet (it's the only subnet I
have defined)
  • however, 'subnet' field is indeed clear:
LZ
On Sun, May 14, 2017 at 8:43 PM, Lukas Zapletal lzap@redhat.com wrote:
Chad,
discovery.
On Fri, May 12, 2017 at 2:21 PM, Chad Schroeder < >> chads.finishing.strong@gmail.com> wrote:
been fixed in RC2:
primary/provisioning NIC? Is TFTP associated with this subnet?
can you try with older version?
assumption.
On Fri, Apr 28, 2017 at 12:27 PM, Jacek Mierzwa jmie...@lbisa.com >>>>> wrote:
On Tue, Apr 25, 2017 at 6:40 PM, Chad Schroeder < >>>>>> chads.finis...@gmail.com> wrote:
Lukas,
Hope this helps:
host.nil: false
host.managed: false
Hosts” menu:
host.nil: false
host.managed: false
submit:
host.nil: false
host.managed: true
managed: true
provision: true
pxe_build?: true
Chad
getting orchestrated at all. I suspect that this returns false:
happen as well. Are NICs created correctly? Is there a subnet set?
On Wed, Apr 19, 2017 at 4:58 PM, Chad Schroeder < >>>>>>>> chads.finis...@gmail.com> wrote:
On Wednesday, April 19, 2017 at 8:50:21 AM UTC-5, Lukas Zapletal >>>>>>>>> wrote:
Jacek, can you try it? Did it help in your case? Associate Subnet with a
Domain and then set it in the Hostgroup.
LZ
On Wed, Apr 19, 2017 at 2:51 PM, Jacek Mierzwa <jmie...@lbisa.com >>>>>>>>>> > wrote:
On Wed, Apr 19, 2017 at 2:13 PM, Jacek Mierzwa < >>>>>>>>>>> jmie...@lbisa.com> wrote:
PXE file appears).
Thanks/Regards
On Wed, Apr 19, 2017 at 1:21 PM, Lukas Zapletal < >>>>>>>>>>>> lz...@redhat.com> wrote:
reason,
are
already
exists).
week
LZ
On Thu, Apr 13, 2017 at 4:28 PM, Garreat jmie...@fgtsa.com >>>>>>>>>>>>> wrote:
host entry is
Discovery Image PXE
loop.
default no prob.
    this? I can’t
    group) - OK
    None) - how to check
    this?
    it does - OK
    but it’s a
    group
    the same TFTP
template selected.
    immediatly
Lukas Zapletal
performed
  • host is managed
    None)
checklist please.
LZ
Later,
Later,
Later,
Later,
Later,
Later,
Later,
