Auto Synchronisation not working, manual does
Every morning I come in and check the ‘Sync Status’ page. Since updating I’ve noticed that the automatic overnight synchronisations no longer work.
I’ve not made any changes to the sync - the update was the only change.
From that same page I can manually sync all (‘select all, sync now’) and it just works.
I’ve seen the Proxy error faq but I’m confused since:
  • update to new version was the only change
  • it worked before and doesn’t work now
  • still works when performed manually
Overnight synchronisation works.
Katello 3.7.1
This is an example from a single failing.
Output:
Exception:
RestClient::NotFound: 404 Not Found
Backtrace:
/opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-2.0.1/lib/restclient/abstract_response.rb:223:in `exception_with_response'
/opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-2.0.1/lib/restclient/abstract_response.rb:103:in `return!'
/opt/theforeman/tfm/root/usr/share/gems/gems/runcible-2.8.1/lib/runcible/base.rb:93:in `block in get_response'
/opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-2.0.1/lib/restclient/request.rb:807:in `process_result'
/opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-2.0.1/lib/restclient/request.rb:725:in `block in transmit'
/opt/rh/rh-ruby24/root/usr/share/ruby/net/http.rb:877:in `start'
/opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-2.0.1/lib/restclient/request.rb:715:in `transmit'
/opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-2.0.1/lib/restclient/request.rb:145:in `execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-2.0.1/lib/restclient/request.rb:52:in `execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-2.0.1/lib/restclient/resource.rb:51:in `get'
/opt/theforeman/tfm/root/usr/share/gems/gems/runcible-2.8.1/lib/runcible/base.rb:92:in `get_response'
/opt/theforeman/tfm/root/usr/share/gems/gems/runcible-2.8.1/lib/runcible/base.rb:72:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/runcible-2.8.1/lib/runcible/resources/task.rb:18:in `poll'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.7.1.1/app/lib/actions/pulp/repository/sync.rb:17:in `invoke_external_task'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.1.0/lib/dynflow/action/polling.rb:83:in `initiate_external_action'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.1.0/lib/dynflow/action/polling.rb:18:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.1.0/lib/dynflow/action/cancellable.rb:13:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.7.1.1/app/lib/actions/pulp/abstract_async_task.rb:45:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.1.0/lib/dynflow/action.rb:538:in `block (3 levels) in execute_run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.1.0/lib/dynflow/middleware/stack.rb:26:in `pass'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.1.0/lib/dynflow/middleware.rb:18:in `pass'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.1.0/lib/dynflow/middleware.rb:31:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.1.0/lib/dynflow/middleware/stack.rb:22:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.7.1.1/app/lib/actions/middleware/remote_action.rb:16:in `block in run'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.7.1.1/app/lib/actions/middleware/remote_action.rb:40:in `block in as_remote_user'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.7.1.1/app/models/katello/concerns/user_extensions.rb:21:in `cp_config'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.7.1.1/app/lib/actions/middleware/remote_action.rb:27:in `as_cp_user'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.7.1.1/app/lib/actions/middleware/remote_action.rb:39:in `as_remote_user'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.7.1.1/app/lib/actions/middleware/remote_action.rb:16:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-0.13.4/app/lib/actions/middleware/rails_executor_wrap.rb:14:in `block in run'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activesupport-5.1.6/lib/active_support/execution_wrapper.rb:85:in `wrap'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-0.13.4/app/lib/actions/middleware/rails_executor_wrap.rb:13:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.1.0/lib/dynflow/action/progress.rb:30:in `with_progress_calculation'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.1.0/lib/dynflow/action/progress.rb:16:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.7.1.1/app/lib/actions/middleware/keep_locale.rb:11:in `block in run'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.7.1.1/app/lib/actions/middleware/keep_locale.rb:22:in `with_locale'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.7.1.1/app/lib/actions/middleware/keep_locale.rb:11:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-0.13.4/app/lib/actions/middleware/keep_current_user.rb:15:in `block in run'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-0.13.4/app/lib/actions/middleware/keep_current_user.rb:43:in `restore_curent_user'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-0.13.4/app/lib/actions/middleware/keep_current_user.rb:15:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.1.0/lib/dynflow/middleware/world.rb:30:in `execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.1.0/lib/dynflow/action.rb:537:in `block (2 levels) in execute_run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.1.0/lib/dynflow/action.rb:536:in `catch'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.1.0/lib/dynflow/action.rb:536:in `block in execute_run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.1.0/lib/dynflow/action.rb:451:in `block in with_error_handling'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.1.0/lib/dynflow/action.rb:451:in `catch'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.1.0/lib/dynflow/action.rb:451:in `with_error_handling'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.1.0/lib/dynflow/action.rb:531:in `execute_run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.1.0/lib/dynflow/action.rb:278:in `execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.1.0/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:17:in `block (2 levels) in execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.1.0/lib/dynflow/execution_plan/steps/abstract.rb:162:in `with_meta_calculation'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.1.0/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:16:in `block in execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.1.0/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:30:in `open_action'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.1.0/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:15:in `execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.1.0/lib/dynflow/director.rb:43:in `execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.1.0/lib/dynflow/executors/parallel/worker.rb:12:in `block in on_message'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.1.0/lib/dynflow/executors.rb:12:in `run_user_code'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.1.0/lib/dynflow/executors/parallel/worker.rb:11:in `on_message'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.4/lib/concurrent/actor/context.rb:46:in `on_envelope'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.4/lib/concurrent/actor/behaviour/executes_context.rb:7:in `on_envelope'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.4/lib/concurrent/actor/behaviour/abstract.rb:25:in `pass'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.1.0/lib/dynflow/actor.rb:26:in `on_envelope'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.4/lib/concurrent/actor/behaviour/awaits.rb:15:in `on_envelope'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.4/lib/concurrent/actor/behaviour/sets_results.rb:14:in `on_envelope'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.4/lib/concurrent/actor/behaviour/buffer.rb:38:in `process_envelope'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.4/lib/concurrent/actor/behaviour/buffer.rb:31:in `process_envelopes?'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.4/lib/concurrent/actor/behaviour/buffer.rb:20:in `on_envelope'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.4/lib/concurrent/actor/behaviour/termination.rb:55:in `on_envelope'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.4/lib/concurrent/actor/behaviour/removes_child.rb:10:in `on_envelope'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.4/lib/concurrent/actor/core.rb:161:in `process_envelope'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.4/lib/concurrent/actor/core.rb:95:in `block in on_envelope'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.4/lib/concurrent/actor/core.rb:118:in `block (2 levels) in schedule_execution'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/concurrent-ruby-1.0.5/lib/concurrent/synchronization/mri_lockable_object.rb:38:in `block in synchronize'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/concurrent-ruby-1.0.5/lib/concurrent/synchronization/mri_lockable_object.rb:38:in `synchronize'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.4/lib/concurrent/actor/core.rb:115:in `block in schedule_execution'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/concurrent-ruby-1.0.5/lib/concurrent/executor/serialized_execution.rb:18:in `call'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/concurrent-ruby-1.0.5/lib/concurrent/executor/serialized_execution.rb:96:in `work'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/concurrent-ruby-1.0.5/lib/concurrent/executor/serialized_execution.rb:77:in `block in call_job'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/concurrent-ruby-1.0.5/lib/concurrent/executor/ruby_thread_pool_executor.rb:348:in `run_task'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/concurrent-ruby-1.0.5/lib/concurrent/executor/ruby_thread_pool_executor.rb:337:in `block (3 levels) in create_worker'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/concurrent-ruby-1.0.5/lib/concurrent/executor/ruby_thread_pool_executor.rb:320:in `loop'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/concurrent-ruby-1.0.5/lib/concurrent/executor/ruby_thread_pool_executor.rb:320:in `block (2 levels) in create_worker'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/concurrent-ruby-1.0.5/lib/concurrent/executor/ruby_thread_pool_executor.rb:319:in `catch'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/concurrent-ruby-1.0.5/lib/concurrent/executor/ruby_thread_pool_executor.rb:319:in `block in create_worker'
Maybe it is this issue:
https://projects.theforeman.org/issues/22671
Target version for resolve is Katello 3.9
The named bug contains a solution that didn’t work for me. There is another bug linked and 22671 is considered a duplicate of it Bug #24083: Add an upgrade rake task for sync plans - Katello - Foreman
Yeah, I know that duplicate. Because of the similar description I linked the original issue to avoid confusion.
Did the changeset work for you?
I didn’t apply it. When a changeset requires changes to more than one file, I skip them and wait. The update shouldn’t be too far away. I did apply the change in #22671 but it didn’t work. When I looked at #24083 it was unclear what changes needed to be made (just the changes in that ticket, or the pulp one’s as well? How far from the distributed packages am I willing to go?) - I’m not a redmine native - and it’s not that hard a work around.
