Backtrace for 'key not found: 2' error (ActionView::Template::Error): key not found: 2
I’ve received the below error intermittently when attempting remote executions, I can’t find any rhyme or reason to reproduce the issue, but when it happens I get a dialog in Foreman (snapshot attached) immediately following a remote execution job. When navigating to the jobs page, I’m seeing the actual job that produced the error running as it normally should.
Any ideas?
No errors
Details below
Details below
CentOS Linux release 7.9.2009 (Core)
# foreman-rake errors:fetch_log request_id=1347a996
2023-02-15T10:17:31 [I|app|1347a996] Started GET "/job_invocations/936" for 10.0.0.1 at 2023-02-15 10:17:31 -0600
2023-02-15T10:17:31 [I|app|1347a996] Processing by JobInvocationsController#show as HTML
2023-02-15T10:17:31 [I|app|1347a996]   Parameters: {"id"=>"936"}
2023-02-15T10:17:31 [I|app|1347a996]   Rendering /opt/theforeman/tfm/root/usr/share/gems/gems/foreman_remote_execution-7.1.1/app/views/job_invocations/show.html.erb within layouts/application
2023-02-15T10:17:31 [I|app|1347a996]   Rendered /opt/theforeman/tfm/root/usr/share/gems/gems/foreman_remote_execution-7.1.1/app/views/job_invocations/_card_results.html.erb (Duration: 6.4ms | Allocations: 5652)
2023-02-15T10:17:31 [I|app|1347a996]   Rendered /opt/theforeman/tfm/root/usr/share/gems/gems/foreman_remote_execution-7.1.1/app/views/job_invocations/_card_schedule.html.erb (Duration: 9.0ms | Allocations: 6094)
2023-02-15T10:17:31 [I|app|1347a996]   Rendered /opt/theforeman/tfm/root/usr/share/gems/gems/foreman_remote_execution-7.1.1/app/views/job_invocations/_card_target_hosts.html.erb (Duration: 23.1ms | Allocations: 6531)
2023-02-15T10:17:31 [I|app|1347a996]   Rendered /opt/theforeman/tfm/root/usr/share/gems/gems/foreman_remote_execution-7.1.1/app/views/job_invocations/_card_user_input.html.erb (Duration: 8.5ms | Allocations: 6110)
2023-02-15T10:17:31 [I|app|1347a996]   Rendered /opt/theforeman/tfm/root/usr/share/gems/gems/foreman_remote_execution-7.1.1/app/views/job_invocations/_tab_hosts.html.erb (Duration: 5.2ms | Allocations: 5606)
2023-02-15T10:17:31 [I|app|1347a996]   Rendered /opt/theforeman/tfm/root/usr/share/gems/gems/foreman_remote_execution-7.1.1/app/views/job_invocations/_tab_overview.html.erb (Duration: 99.1ms | Allocations: 41132)
2023-02-15T10:17:31 [I|app|1347a996]   Rendered /opt/theforeman/tfm/root/usr/share/gems/gems/foreman_remote_execution-7.1.1/app/views/job_invocations/_user_input.html.erb (Duration: 23.4ms | Allocations: 7943)
2023-02-15T10:17:31 [I|app|1347a996]   Rendered /opt/theforeman/tfm/root/usr/share/gems/gems/foreman_remote_execution-7.1.1/app/views/job_invocations/_tab_preview_templates.html.erb (Duration: 54.9ms | Allocations: 16180)
2023-02-15T10:17:31 [I|app|1347a996]   Rendered /opt/theforeman/tfm/root/usr/share/gems/gems/foreman_remote_execution-7.1.1/app/views/job_invocations/show.html.erb within layouts/application (Duration: 201.4ms | Allocations: 72972)
2023-02-15T10:17:31 [W|app|1347a996] key not found: 2
2023-02-15T10:17:31 [I|app|1347a996] Backtrace for 'key not found: 2' error (ActionView::Template::Error): key not found: 2
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/execution_plan/steps/plan_step.rb:28:in `fetch'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/execution_plan/steps/plan_step.rb:28:in `block in planned_steps'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/execution_plan/steps/plan_step.rb:28:in `map'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/execution_plan/steps/plan_step.rb:28:in `planned_steps'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/action.rb:233:in `planned_actions'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/action.rb:243:in `all_planned_actions'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/execution_plan.rb:517:in `actions'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/foreman_remote_execution-7.1.1/app/helpers/remote_execution_helper.rb:243:in `load_template_from_task'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/foreman_remote_execution-7.1.1/app/helpers/remote_execution_helper.rb:165:in `preview_box'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/foreman_remote_execution-7.1.1/app/views/job_invocations/_user_input.html.erb:2:in `_3f6d62e092d96bfa3ed7d6f4e4a30d6a'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionview-6.0.4.7/lib/action_view/base.rb:274:in `_run'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionview-6.0.4.7/lib/action_view/template.rb:185:in `block in render'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.4.7/lib/active_support/notifications.rb:182:in `instrument'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionview-6.0.4.7/lib/action_view/template.rb:385:in `instrument_render_template'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionview-6.0.4.7/lib/action_view/template.rb:183:in `render'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/deface-1.5.3/lib/deface/action_view_extensions.rb:43:in `render'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionview-6.0.4.7/lib/action_view/renderer/partial_renderer.rb:357:in `block in render_partial'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionview-6.0.4.7/lib/action_view/renderer/abstract_renderer.rb:88:in `block in instrument'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.4.7/lib/active_support/notifications.rb:180:in `block in instrument'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.4.7/lib/active_support/notifications/instrumenter.rb:24:in `instrument'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.4.7/lib/active_support/notifications.rb:180:in `instrument'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionview-6.0.4.7/lib/action_view/renderer/abstract_renderer.rb:87:in `instrument'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionview-6.0.4.7/lib/action_view/renderer/partial_renderer.rb:346:in `render_partial'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionview-6.0.4.7/lib/action_view/renderer/partial_renderer.rb:317:in `render'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionview-6.0.4.7/lib/action_view/renderer/renderer.rb:65:in `render_partial_to_object'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionview-6.0.4.7/lib/action_view/renderer/renderer.rb:27:in `render_to_object'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionview-6.0.4.7/lib/action_view/renderer/renderer.rb:22:in `render'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionview-6.0.4.7/lib/action_view/helpers/rendering_helper.rb:34:in `block in render'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionview-6.0.4.7/lib/action_view/base.rb:304:in `in_rendering_context'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionview-6.0.4.7/lib/action_view/helpers/rendering_helper.rb:30:in `render'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/foreman_remote_execution-7.1.1/app/helpers/job_invocations_helper.rb:36:in `block in preview_hosts'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/foreman_remote_execution-7.1.1/app/helpers/job_invocations_helper.rb:34:in `map'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/foreman_remote_execution-7.1.1/app/helpers/job_invocations_helper.rb:34:in `preview_hosts'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/foreman_remote_execution-7.1.1/app/views/job_invocations/_tab_preview_templates.html.erb:15:in `_86549db1dec2a59487cc501ebbd13c3e'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionview-6.0.4.7/lib/action_view/renderer/renderer.rb:53:in `render_partial'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionview-6.0.4.7/lib/action_view/helpers/rendering_helper.rb:38:in `render'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/foreman_remote_execution-7.1.1/app/views/job_invocations/show.html.erb:33:in `_f9997d623f240d176df4d01135909326'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionview-6.0.4.7/lib/action_view/renderer/template_renderer.rb:58:in `block (2 levels) in render_template'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionview-6.0.4.7/lib/action_view/renderer/template_renderer.rb:57:in `block in render_template'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionview-6.0.4.7/lib/action_view/renderer/template_renderer.rb:65:in `render_with_layout'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionview-6.0.4.7/lib/action_view/renderer/template_renderer.rb:56:in `render_template'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionview-6.0.4.7/lib/action_view/renderer/template_renderer.rb:13:in `render'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionview-6.0.4.7/lib/action_view/renderer/renderer.rb:61:in `render_template_to_object'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionview-6.0.4.7/lib/action_view/renderer/renderer.rb:29:in `render_to_object'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionview-6.0.4.7/lib/action_view/rendering.rb:117:in `block in _render_template'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionview-6.0.4.7/lib/action_view/rendering.rb:116:in `_render_template'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_controller/metal/streaming.rb:218:in `_render_template'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionview-6.0.4.7/lib/action_view/rendering.rb:103:in `render_to_body'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_controller/metal/rendering.rb:52:in `render_to_body'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_controller/metal/renderers.rb:142:in `render_to_body'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/abstract_controller/rendering.rb:25:in `render'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_controller/metal/rendering.rb:36:in `render'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_controller/metal/instrumentation.rb:44:in `block (2 levels) in render'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.4.7/lib/active_support/core_ext/benchmark.rb:14:in `block in ms'
 1347a996 | /opt/rh/rh-ruby27/root/usr/share/ruby/benchmark.rb:308:in `realtime'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.4.7/lib/active_support/core_ext/benchmark.rb:14:in `ms'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_controller/metal/instrumentation.rb:44:in `block in render'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_controller/metal/instrumentation.rb:84:in `cleanup_view_runtime'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.4.7/lib/active_record/railties/controller_runtime.rb:34:in `cleanup_view_runtime'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_controller/metal/instrumentation.rb:43:in `render'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_controller/metal/implicit_render.rb:35:in `default_render'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_controller/metal/basic_implicit_render.rb:6:in `block in send_action'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_controller/metal/basic_implicit_render.rb:6:in `tap'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/abstract_controller/base.rb:195:in `process_action'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_controller/metal/rendering.rb:30:in `process_action'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/abstract_controller/callbacks.rb:42:in `block in process_action'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.4.7/lib/active_support/callbacks.rb:112:in `block in run_callbacks'
 1347a996 | /usr/share/foreman/app/controllers/concerns/foreman/controller/timezone.rb:10:in `set_timezone'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.4.7/lib/active_support/callbacks.rb:121:in `block in run_callbacks'
 1347a996 | /usr/share/foreman/app/models/concerns/foreman/thread_session.rb:32:in `clear_thread'
 1347a996 | /usr/share/foreman/app/controllers/concerns/foreman/controller/topbar_sweeper.rb:12:in `set_topbar_sweeper_controller'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/audited-4.9.0/lib/audited/sweeper.rb:14:in `around'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.4.7/lib/active_support/callbacks.rb:139:in `run_callbacks'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/abstract_controller/callbacks.rb:41:in `process_action'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_controller/metal/rescue.rb:22:in `process_action'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_controller/metal/instrumentation.rb:33:in `block in process_action'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_controller/metal/instrumentation.rb:32:in `process_action'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_controller/metal/params_wrapper.rb:245:in `process_action'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.4.7/lib/active_record/railties/controller_runtime.rb:27:in `process_action'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/abstract_controller/base.rb:136:in `process'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionview-6.0.4.7/lib/action_view/rendering.rb:39:in `process'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_controller/metal.rb:190:in `dispatch'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_controller/metal.rb:254:in `dispatch'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_dispatch/routing/route_set.rb:50:in `dispatch'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_dispatch/routing/route_set.rb:33:in `serve'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_dispatch/journey/router.rb:49:in `block in serve'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_dispatch/journey/router.rb:32:in `each'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_dispatch/journey/router.rb:32:in `serve'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_dispatch/routing/route_set.rb:834:in `call'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.5.0/lib/katello/middleware/organization_created_enforcer.rb:18:in `call'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.5.0/lib/katello/middleware/event_daemon.rb:10:in `call'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_dispatch/middleware/static.rb:126:in `call'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/apipie-dsl-2.4.0/lib/apipie_dsl/static_dispatcher.rb:67:in `call'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/apipie-rails-0.5.17/lib/apipie/static_dispatcher.rb:66:in `call'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/apipie-rails-0.5.17/lib/apipie/extractor/recorder.rb:137:in `call'
 1347a996 | /usr/share/foreman/lib/foreman/middleware/libvirt_connection_cleaner.rb:9:in `call'
 1347a996 | /usr/share/foreman/lib/foreman/middleware/telemetry.rb:10:in `call'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/apipie-rails-0.5.17/lib/apipie/middleware/checksum_in_headers.rb:27:in `call'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/tempfile_reaper.rb:15:in `call'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/etag.rb:27:in `call'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/conditional_get.rb:27:in `call'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/head.rb:12:in `call'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_dispatch/http/content_security_policy.rb:18:in `call'
 1347a996 | /usr/share/foreman/lib/foreman/middleware/logging_context_session.rb:22:in `call'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/session/abstract/id.rb:266:in `context'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/session/abstract/id.rb:260:in `call'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_dispatch/middleware/cookies.rb:654:in `call'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_dispatch/middleware/callbacks.rb:27:in `block in call'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.4.7/lib/active_support/callbacks.rb:101:in `run_callbacks'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_dispatch/middleware/callbacks.rb:26:in `call'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_dispatch/middleware/actionable_exceptions.rb:18:in `call'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_dispatch/middleware/debug_exceptions.rb:32:in `call'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_dispatch/middleware/show_exceptions.rb:33:in `call'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/railties-6.0.4.7/lib/rails/rack/logger.rb:37:in `call_app'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/railties-6.0.4.7/lib/rails/rack/logger.rb:28:in `call'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/sprockets-rails-3.2.1/lib/sprockets/rails/quiet_assets.rb:13:in `call'
 1347a996 | /usr/share/foreman/lib/foreman/middleware/logging_context_request.rb:11:in `call'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_dispatch/middleware/remote_ip.rb:81:in `call'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_dispatch/middleware/request_id.rb:27:in `call'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.5.0/lib/katello/prevent_json_parsing.rb:12:in `call'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/method_override.rb:24:in `call'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/runtime.rb:22:in `call'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.4.7/lib/active_support/cache/strategy/local_cache_middleware.rb:29:in `call'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_dispatch/middleware/executor.rb:14:in `call'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/sendfile.rb:110:in `call'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_dispatch/middleware/ssl.rb:74:in `call'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.4.7/lib/action_dispatch/middleware/host_authorization.rb:97:in `call'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/secure_headers-6.3.0/lib/secure_headers/middleware.rb:11:in `call'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/railties-6.0.4.7/lib/rails/engine.rb:527:in `call'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/railties-6.0.4.7/lib/rails/railtie.rb:190:in `public_send'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/railties-6.0.4.7/lib/rails/railtie.rb:190:in `method_missing'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/urlmap.rb:74:in `block in call'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/urlmap.rb:58:in `each'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/urlmap.rb:58:in `call'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/puma-5.6.2/lib/puma/configuration.rb:252:in `call'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/puma-5.6.2/lib/puma/request.rb:77:in `block in handle_request'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/puma-5.6.2/lib/puma/thread_pool.rb:340:in `with_force_shutdown'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/puma-5.6.2/lib/puma/request.rb:76:in `handle_request'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/puma-5.6.2/lib/puma/server.rb:441:in `process_client'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/puma-5.6.2/lib/puma/thread_pool.rb:147:in `block in spawn_thread'
 1347a996 | /opt/theforeman/tfm/root/usr/share/gems/gems/logging-2.3.0/lib/logging/diagnostic_context.rb:474:in `block in create_with_logging_context'
2023-02-15T10:17:31 [I|app|1347a996]   Rendering common/500.html.erb within layouts/application
2023-02-15T10:17:31 [I|app|1347a996]   Rendered common/500.html.erb within layouts/application (Duration: 2.1ms | Allocations: 812)
2023-02-15T10:17:31 [I|app|1347a996]   Rendered layouts/_application_content.html.erb (Duration: 5.4ms | Allocations: 5596)
2023-02-15T10:17:31 [I|app|1347a996]   Rendering layouts/base.html.erb
2023-02-15T10:17:31 [I|app|1347a996]   Rendered layouts/base.html.erb (Duration: 8.3ms | Allocations: 7858)
2023-02-15T10:17:31 [I|app|1347a996] Completed 500 Internal Server Error in 267ms (Views: 24.9ms | ActiveRecord: 100.1ms | Allocations: 101650)
Foreman version: 3.3.0
Plugins:
 - foreman-tasks 6.0.2
 - foreman_ansible 7.1.2
 - foreman_puppet 4.0.1
 - foreman_remote_execution 7.1.1
 - katello 4.5.0
Yeah, this is something that I’ve seen happen on and off but never really bothered to look into it as it always went away with just a refresh. I took a stab at putting together a fix Fixes #36114 - Prevent accessing dynflow internals until ready by adamruzicka · Pull Request #787 · theforeman/foreman_remote_execution · GitHub . Would you be willing to take it for a spin?
@aruzicka sure, I can apply it. Do you know of a way to easily reproduce it? If not, I’ll report back in a few weeks and let you know if I’m still experiencing it or not.
Not really. It is a sort of a race condition and just happens if things get ordered a specific way, which is not something one can control from the outside
@aruzicka I can confirm over a production patching cycle this month that after applying the fix I’m no experiencing this issue. I see that from the looks of it the fix was already merged in, do you know if this fix will be pushed in the Foreman 3.3 branch for EL7?
Considering only last two versions of foreman are supported, which at this time is 3.6 and 3.5, I’d be inclined to say no.
