Basic auth into url no longer works, breaks Rundeck
If I use https://login:password@myforeman.com/hosts?.… (from Rundeck
actually), I get
{"error":"Authentication error"}
It worked with 1.5, no longer with 1.8.2.
http://projects.theforeman.org/projects/foreman/wiki/Rundeck_Integration
> actually), I get
Rundeck integration has been moved to a plugin and is no longer part of
core, https://github.com/theforeman/foreman_host_rundeck , you should install
it in order to get Rundeck integration post 1.7
If you're on a Red Hat based OS:
yum install ruby193-rubygem-foreman_host_rundeck
If you're on a Debian based OS:
apt-get install ruby-foreman-host-rundeck
and restart the foreman service
service foreman restart or systemctl restart foreman
Find more info here http://www.theforeman.org/plugins/#2.Installation
This user had the same problem & blogged about it a while ago :slight_smile:
http://www.joshpreston.net/blog/2015/01/23/foreman-upgrade-to-1-dot-7-broke-my-rundeck-integration/
Hope this helped,
··· On 08/14, Vincent Miszczak wrote: > > > http://projects.theforeman.org/projects/foreman/wiki/Rundeck_Integration > > > > > > -- > You received this message because you are subscribed to the Google Groups "Foreman users" group. > To unsubscribe from this group and stop receiving emails from it, send an email to foreman-users+unsubscribe@googlegroups.com. > To post to this group, send email to foreman-users@googlegroups.com. > Visit this group at http://groups.google.com/group/foreman-users. > For more options, visit https://groups.google.com/d/optout.
Daniel Lobato Garcia
@eLobatoss
blog.daniellobato.me
daniellobato.me
Keybase: https://keybase.io/elobato
I installed the plugin, nothing else to do, it just works.
Thank you very much!
··· Le lundi 17 août 2015 10:15:02 UTC+2, Daniel Lobato a écrit : > > On 08/14, Vincent Miszczak wrote: > > If I use https://login:password@myforeman.com/hosts?... (from Rundeck > > actually), I get > > > > {"error":"Authentication error"} > > > > > > It worked with 1.5, no longer with 1.8.2. > > Rundeck integration has been moved to a plugin and is no longer part of > core, https://github.com/theforeman/foreman_host_rundeck , you should > install > it in order to get Rundeck integration post 1.7 > > If you're on a Red Hat based OS: > yum install ruby193-rubygem-foreman_host_rundeck > If you're on a Debian based OS: > apt-get install ruby-foreman-host-rundeck > and restart the foreman service > service foreman restart or systemctl restart foreman > > Find more info here http://www.theforeman.org/plugins/#2.Installation > > This user had the same problem & blogged about it a while ago :) > > http://www.joshpreston.net/blog/2015/01/23/foreman-upgrade-to-1-dot-7-broke-my-rundeck-integration/ > > > Hope this helped, > > > > > > http://projects.theforeman.org/projects/foreman/wiki/Rundeck_Integration > > > > > > > > > > > > -- > > You received this message because you are subscribed to the Google > Groups "Foreman users" group. > > To unsubscribe from this group and stop receiving emails from it, send > an email to foreman-user...@googlegroups.com . > > To post to this group, send email to forema...@googlegroups.com > . > > Visit this group at http://groups.google.com/group/foreman-users. > > For more options, visit https://groups.google.com/d/optout. > > > -- > Daniel Lobato Garcia > > @eLobatoss > blog.daniellobato.me > daniellobato.me > > GPG: http://keys.gnupg.net/pks/lookup?op=get&search=0x7A92D6DD38D6DE30 > Keybase: https://keybase.io/elobato >
