I've setup a repo in foreman on the same host as forman, but with a
different port (8080). When I assign an os using this installation media,
build fails with the following error:
Failed to enable client.test.com for installation: Failed to fetch boot
files: invalid medium for CentOS 5.6
The logs do not show what it is trying to fetch or what the actual failure
is. Why does this happen and how do I find out what it was trying to fetch?
Look at the proxy log files.
Ohad
On Thu, Sep 1, 2011 at 9:46 PM, lavaman wrote:
> "Foreman users" group.
> To unsubscribe from this group, send email to
> foreman-users+unsubscribe@googlegroups.com.
> For more options, visit this group at
> http://groups.google.com/group/foreman-users?hl=en.
I, [2011-08-31T21:58:21.013411 #8214] INFO – : TFTP: entry for
08:00:27:f5:5b:f3 created successfully
D, [2011-08-31T21:58:21.042760 #8214] DEBUG – : TFTP: entry for
08:00:27:f5:5b:f3 removed successfully
I’ve setup a repo in foreman on the same host as forman, but with a
media,
failure
fetch?
> All I see come up is this:
> This is what's in the foreman log:
> Processing HostsController#setBuild (for 192.168.2.4 at 2011-08-31 21:58:20)
> [GET]
> Parameters: {"action"=>"setBuild", "id"=>"client.test.com",
> "controller"=>"hosts"}
> Add the TFTP configuration for client.test.com
> Fetching required TFTP boot files for client.test.com
> Failed to fetch boot files: invalid medium for CentOS 5.6
> Delete the TFTP configuration for client.test.com
> Redirected to http://192.168.2.14/hosts/client.test.com
> Completed in 169ms (DB: 49) | 302 Found
> [http://192.168.2.14/hosts/client.test.com/setBuild]
Hmm… according to the code, your media does not belong to the OS in
question, I guess you removed one of the check boxes.
Ohad
>> > media,
>> > failure
>> > fetch?
>> Ohad
>> > Groups
media,
boot
failure
fetch?
> It's checked and it's the only media checked on the os page…
You should double check, the code simply check if the media select
belongs to the OS allowed mediums… whicn in you case does not.
(e…g it make no sense to deploy Ubuntu with a suse media).
Ohad
>> > I, [2011-08-31T21:58:21.013411 #8214] INFO -- : TFTP: entry for
>> > D, [2011-08-31T21:58:21.042760 #8214] DEBUG -- : TFTP: entry for
>> > 21:58:20)
>> > [GET]
>> Hmm.. according to the code, your media does not belong to the OS in
>> Ohad
>> >> > media,
>> >> > boot
>> >> > failure
>> >> > fetch?
>> >> Ohad
>> >> > Groups
>> >> Groups
>> > Groups
If I edit the installation media, the proper OS is checked (I only have one
OS configured). If I edit the OS, the proper media is checked (and it's the
only one checked).
media,
boot
failure
to
fetch?
Ohad
Groups
It looks like I might have found a bug. It would seem that if the
installation media is created after the OS is created, the OS cannot use
it. If you create the OS after the installation media is created, it
doesn't complain…
OS configured). If I edit the OS, the proper media is checked (and it’s the
only one checked).
a
installation
media,
fetch
boot
failure
to
fetch?
Ohad
Groups
Groups
> doesn't complain…
I just tried and I cant reproduce this… can you provide a step by
step example of how it fails?
thanks,
Ohad
>> one OS configured). If I edit the OS, the proper media is checked (and it's
>> the only one checked).
>>> > It's checked and it's the only media checked on the os page...
>>> belongs to the OS allowed mediums... whicn in you case does not.
>>> (e..g it make no sense to deploy Ubuntu with a suse media).
>>> Ohad
>>> >> > 21:58:20)
>>> >> > [GET]
>>> >> Ohad
>>> >> >> > a
>>> >> >> > installation
>>> >> >> > media,
>>> >> >> > fetch
>>> >> >> > boot
>>> >> >> > actual
>>> >> >> > failure
>>> >> >> > trying to
>>> >> >> > fetch?
>>> >> >> Ohad
>>> >> >> > Google
>>> >> >> > Groups
>>> >> >> Groups
>>> >> > Groups
>>> >> Groups
>>> > Groups
Well, whatever was happening I can't reproduce in any way now. Now any
sensible combination of install media and os works fine. Not sure what was
going on.
I am running into another issue occasionally, which is sometimes when I try
to save a host (usually after changing the os setting), it tells me that the
puppetmaster must be puppet or an fqdn and won't recognize the proxy that is
set. If i manually enter puppet it will save and if i go back and change it
back to the proxy (without changing anything else) it will save fine. Any
idea why that happens?
doesn’t complain…
Groups
Groups
