I did a normal install of Foreman server. Foreman is running fine but my
commandline environment is broken. Bundle immediately returns "Could not
locate Gemfile"
Is there a low level environment setup I can run. Alternately can I safely
re-run install without losing my database content? What I'm actually
trying to do is move my database to another server. So the first command
(from your guide) is:
root# bundle exec rake db:migrate RAILS_ENV=production
Could not locate Gemfile
> locate Gemfile"
> safely re-run install without losing my database content? What I'm
> actually trying to do is move my database to another server. So the first
> command (from your guide) is:
try
su - foreman -s /bin/bash
then continue from there
Ohad
On Mon, Apr 22, 2013 at 2:26 AM, Larry Fast wrote:
"Foreman users" group.
Visit this group at http://groups.google.com/group/foreman-users?hl=en.
Thanks Ohad,
We disable login on service accounts by default so I didn't think of that.
Enabled the account and the database transfer went fine.
Now I assume I need to restart foreman after moving the database. What's
the restart process on a standard installation?
Cheers,
Larry
> Thanks Ohad,
> if you are using passenger (the default) then a simple touch on
~foreman/tmp/restart.txt or you could restart your entire web service (e.g.
service httpd restart).
Ohad
On Mon, Apr 22, 2013 at 8:13 PM, Larry Fast wrote:
Cheers,
Larry
Done! … and is there a config page where I can see that the new database
is active? Or do I just change something in the GUI and check the DB
manually.
Thanks again.
Oh-oh.
ERROR: duplicate key value violates unique constraint "audits_pkey" DETAIL:
Key (id)=(1) already exists.
I got this when I tried to change the Environment setting for a host.
FYI: I already ran the post-transfer-to-postgres sql script.
RESOLVED! It was a permissions problem during script execution.
Now that I had all the instructions down, I went back to the original
database and ran the migration steps again.
This time editing records is working fine … so far.
Cheers,
Larry
