when I do fresh foreman clone with clean Ruby version (tried 2.0.0 and
2.4.1), bundle install is not able to resolve dependencies and loops
forever. I am using latest stable bundler, tried also pre1 version.
Can someone confirm and provide a workaround? I think copying
Gemfile.lock from someone else should do it. Can someone attach a
pastebin me one? I currently have my workstation down (CPU in RMA) and
got clean setup.
If this is confirmed, it is quite an issue for newcomers. The second
command new developer is asked to execute fails hard. Any suggestions?
What errors are you seeing. I've tried with ruby 2.2.2, and 2.3.1
bundler 1.15.4, everything worked fine.
What gem --version do you have?
Anything in bundler.d/Gemfile.local.rb that could be causing this?
– Ivan
On Thu, Sep 14, 2017 at 3:13 PM, Lukas Zapletal wrote:
> Hey,
> got clean setup.
> LZ
> Later,
> Lukas @lzap Zapletal
> You received this message because you are subscribed to the Google Groups "foreman-dev" group.
> To unsubscribe from this group and stop receiving emails from it, send an email to foreman-dev+unsubscribe@googlegroups.com.
seems to have suffered from this today (Monday 1.15.4 tarballs were built
just fine)
Did you find any other way to fix this? Switching to 2.4 could be an
option, probably
putting a Gemfile.lock on every tagged release isn't a bad idea either.
On Thursday, September 14, 2017 at 3:13:29 PM UTC+2, Lukas Zapletal wrote:
> Hey,
> got clean setup.
> LZ
> Later,
The easiest way to get the recent Gemfile.lock is to look at the build
artifacts in jenkins jobs
(also useful when investigating sudden test failures):
> Anything in `bundler.d/Gemfile.local.rb` that could be causing this?
> -- Ivan
>> Hey,
>> got clean setup.
>> LZ
>> Later,
I just upgraded, but I think putting Gemfile.lock (even an older one
from 1.14 stable branch) could work. Weird really.
On Wed, Sep 20, 2017 at 6:57 PM, Daniel Lobato wrote:
> http://ci.theforeman.org/view/Release%20pipeline/job/release_tarballs
> just fine)
> Did you find any other way to fix this? Switching to 2.4 could be an option,
> probably
>> Hey,
>> got clean setup.
>> LZ
>> Later,
This is Intel NUC with 8 GB RAM, bundler runs for about a minute
before it takes whole memory and start swapping. Then I leave it for
another 5 minutes before bringing it down.
> http://ci.theforeman.org/job/test_develop/database=postgresql,ruby=2.4,slave=fast/
> -- Ivan
>> -- Ivan
>>> Hey,
>>> got clean setup.
>>> LZ
>>> Later,
Eventually I changed the release_tarballs to Ruby 2.4 and it went
through.
> > just fine)
> > probably
> >> Hey,
> >> got clean setup.
> >> LZ
> >> Later,
> Later,
I had all these same issues in a 16.04 Ubuntu LTS (on AWS) with Ruby 2.1
and 6.
There were a few hurdles after the upgrade/downgrade to 2.4 also.
I still have a JavaScript issue, as the pull downs don't render, so I am
rerunning tests.
I have modified Foreman to listen on all ports.
I have my history file from my install if you want to contact me directly.
> built
> > just fine)
> option,
> > probably
> > On Thursday, September 14, 2017 at 3:13:29 PM UTC+2, Lukas Zapletal > wrote:
> >> Hey,
> >> got clean setup.
> >> LZ
> >> Later,
> Groups
> an
> > email to foreman-dev...@googlegroups.com .
> Later,
Tried with rhel7 VM, same gem and ruby version as yours (2.0.0p648),
dependencies resolved just fine.
Failed later on installation of some gem (as it requires ruby 2.1+),
but the memory kept under 300MB
for all the time.
– Ivan
On Fri, Sep 15, 2017 at 9:08 AM, Lukas Zapletal wrote:
> Currently at bundler-1.15.4. Tried both with 2.0.0 from RHEL7 and
> latest stable Ruby.
> [root@nuc foreman]# gem --version
> 2.0.14.1
> [root@nuc foreman]# ruby --version
> ruby 2.0.0p648 (2015-12-16) [x86_64-linux]
> [root@nuc bubbles]# gem --version
> 2.6.13
> [root@nuc bubbles]# ruby --version
> ruby 2.4.2p198 (2017-09-14 revision 59899) [x86_64-linux]
>> -- Ivan
>>> -- Ivan
>>>> Hey,
>>>> got clean setup.
>>>> LZ
>>>> Later,
> Later,
Weird, I think the problem was that I was using CenOS 7.0 or 7.1
without any updates applied.
Anyway I tried again with rbenv Ruby 2.4 and this time it worked, I
had to be setting the version incorrectly.
Thanks for help.
> for all the time.
> -- Ivan
>> latest stable Ruby.
>> 2.0.14.1
>> 2.6.13
>>> -- Ivan
>>>> -- Ivan
>>>>> Hey,
>>>>> got clean setup.
>>>>> LZ
>>>>> Later,
>> Later,
