Cannot perform Remote Execution on migrated CentOS 7 Machines
Cannot send commands to a CentOS7 machine via Remote Execution. This machine was migrated from Spacewalk to foreman using the bootstrap script, and enrolled to foreman successfully. The public key from the foreman-proxy has been copied to ~/.ssh/authorized_keys properly, and I see no difference in its configuration compared to machines that have not been migrated.
However, when I try a simple yum command via Remote execution, I receive the following error message within the Foreman GUI:
Error initializing command: RuntimeError - Could not establish connection to remote host using any available authentication method, tried publickey
For Remote Execution to work as it does for machines that have been subscribed to foreman from the start
Remote Execution version 8
Almalinux 8.6
Please let me know if more information is needed.
Thank You
Hi, I’m not familiar with spacewalk at all so I can’t really speak to that, I can only pick on the bits you’ve told us.
To ~/.ssh/authorized_keys of what user? Are the permissions on that file correct?
If you bump log_level to DEBUG in /etc/foreman-proxy/settings.yml (or is it .yaml?), restart foreman-proxy and run a job again, /var/log/foreman-proxy/proxy.log will contain the exact ssh commands that are being executed so you can follow along and hopefully it will get you somewhere.
Hi @aruzicka, thanks for the quick response.
The public key was placed in the root users /.ssh/authorized_keys directory
The permissions appear to be correct, and are the same as what I see on a working machine
Thanks for the logging suggestion. I’m going to make that change and run the job again, hopefully more verbose logging will help me narrow this down
I set log_level to debug, restarted foreman-proxy, and attempted to run again.
I didn’t see anything different in the logs.
This is what shows up for me, I can’t make sense of it:
/usr/share/gems/gems/algebrick-0.7.5/lib/algebrick/matchers/abstract.rb:74:in assigns' /usr/share/gems/gems/algebrick-0.7.5/lib/algebrick/matching.rb:56:in match_value’
/usr/share/gems/gems/algebrick-0.7.5/lib/algebrick/matching.rb:36:in block in match?' /usr/share/gems/gems/algebrick-0.7.5/lib/algebrick/matching.rb:35:in each’
/usr/share/gems/gems/algebrick-0.7.5/lib/algebrick/matching.rb:35:in match?' /usr/share/gems/gems/algebrick-0.7.5/lib/algebrick/matching.rb:23:in match’
/usr/share/gems/gems/dynflow-1.6.7/lib/dynflow/execution_plan/steps/error.rb:13:in new' /usr/share/gems/gems/dynflow-1.6.7/lib/dynflow/action.rb:512:in set_error’
/usr/share/gems/gems/dynflow-1.6.7/lib/dynflow/action.rb:475:in error!' /usr/share/gems/gems/foreman_remote_execution-8.0.0/app/lib/actions/remote_execution/run_host_job.rb:101:in check_exit_status’
/usr/share/gems/gems/foreman_remote_execution-8.0.0/app/lib/actions/remote_execution/run_host_job.rb:72:in finalize' /usr/share/gems/gems/dynflow-1.6.7/lib/dynflow/action.rb:604:in block (2 levels) in execute_finalize’
/usr/share/gems/gems/dynflow-1.6.7/lib/dynflow/middleware/stack.rb:27:in pass' /usr/share/gems/gems/dynflow-1.6.7/lib/dynflow/middleware.rb:19:in pass’
/usr/share/gems/gems/dynflow-1.6.7/lib/dynflow/middleware.rb:40:in finalize' /usr/share/gems/gems/dynflow-1.6.7/lib/dynflow/middleware/stack.rb:23:in call’
/usr/share/gems/gems/foreman-tasks-7.0.0/app/lib/actions/middleware/rails_executor_wrap.rb:20:in block in finalize' /usr/share/gems/gems/activesupport-6.1.6.1/lib/active_support/execution_wrapper.rb:91:in wrap’
/usr/share/gems/gems/foreman-tasks-7.0.0/app/lib/actions/middleware/rails_executor_wrap.rb:19:in finalize' /usr/share/gems/gems/dynflow-1.6.7/lib/dynflow/middleware/stack.rb:23:in call’
/usr/share/gems/gems/dynflow-1.6.7/lib/dynflow/action/progress.rb:31:in with_progress_calculation' /usr/share/gems/gems/dynflow-1.6.7/lib/dynflow/action/progress.rb:23:in finalize’
/usr/share/gems/gems/dynflow-1.6.7/lib/dynflow/middleware/stack.rb:23:in call' /usr/share/gems/gems/dynflow-1.6.7/lib/dynflow/middleware/stack.rb:27:in pass’
/usr/share/gems/gems/dynflow-1.6.7/lib/dynflow/middleware.rb:19:in pass' /usr/share/gems/gems/foreman-tasks-7.0.0/app/lib/actions/middleware/load_setting_values.rb:25:in finalize’
/usr/share/gems/gems/dynflow-1.6.7/lib/dynflow/middleware.rb:19:in pass' /usr/share/gems/gems/foreman-tasks-7.0.0/app/lib/actions/middleware/keep_current_request_id.rb:19:in block in finalize’
/usr/share/gems/gems/foreman-tasks-7.0.0/app/lib/actions/middleware/keep_current_request_id.rb:52:in restore_current_request_id' /usr/share/gems/gems/foreman-tasks-7.0.0/app/lib/actions/middleware/keep_current_request_id.rb:19:in finalize’
/usr/share/gems/gems/dynflow-1.6.7/lib/dynflow/middleware.rb:19:in pass' /usr/share/gems/gems/foreman-tasks-7.0.0/app/lib/actions/middleware/keep_current_timezone.rb:19:in block in finalize’
/usr/share/gems/gems/foreman-tasks-7.0.0/app/lib/actions/middleware/keep_current_timezone.rb:44:in restore_curent_timezone' /usr/share/gems/gems/foreman-tasks-7.0.0/app/lib/actions/middleware/keep_current_timezone.rb:19:in finalize’
/usr/share/gems/gems/dynflow-1.6.7/lib/dynflow/middleware.rb:19:in pass' /usr/share/gems/gems/foreman-tasks-7.0.0/app/lib/actions/middleware/keep_current_user.rb:25:in block in finalize’
/usr/share/gems/gems/foreman-tasks-7.0.0/app/lib/actions/middleware/keep_current_user.rb:54:in restore_curent_user' /usr/share/gems/gems/foreman-tasks-7.0.0/app/lib/actions/middleware/keep_current_user.rb:25:in finalize’
/usr/share/gems/gems/dynflow-1.6.7/lib/dynflow/middleware.rb:19:in pass' /usr/share/gems/gems/foreman-tasks-7.0.0/app/lib/actions/middleware/keep_current_taxonomies.rb:19:in block in finalize’
/usr/share/gems/gems/foreman-tasks-7.0.0/app/lib/actions/middleware/keep_current_taxonomies.rb:45:in restore_current_taxonomies' /usr/share/gems/gems/foreman-tasks-7.0.0/app/lib/actions/middleware/keep_current_taxonomies.rb:19:in finalize’
/usr/share/gems/gems/dynflow-1.6.7/lib/dynflow/middleware/stack.rb:23:in call' /usr/share/gems/gems/dynflow-1.6.7/lib/dynflow/middleware/world.rb:31:in execute’
/usr/share/gems/gems/dynflow-1.6.7/lib/dynflow/action.rb:603:in block in execute_finalize' /usr/share/gems/gems/dynflow-1.6.7/lib/dynflow/action.rb:483:in block in with_error_handling’
/usr/share/gems/gems/dynflow-1.6.7/lib/dynflow/action.rb:483:in catch' /usr/share/gems/gems/dynflow-1.6.7/lib/dynflow/action.rb:483:in with_error_handling’
/usr/share/gems/gems/dynflow-1.6.7/lib/dynflow/action.rb:602:in execute_finalize' /usr/share/gems/gems/dynflow-1.6.7/lib/dynflow/action.rb:296:in execute’
/usr/share/gems/gems/dynflow-1.6.7/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:18:in block (2 levels) in execute' /usr/share/gems/gems/dynflow-1.6.7/lib/dynflow/execution_plan/steps/abstract.rb:167:in with_meta_calculation’
/usr/share/gems/gems/dynflow-1.6.7/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:17:in block in execute' /usr/share/gems/gems/dynflow-1.6.7/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:32:in open_action’
/usr/share/gems/gems/dynflow-1.6.7/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:16:in execute' /usr/share/gems/gems/dynflow-1.6.7/lib/dynflow/director/sequential_manager.rb:78:in run_step’
/usr/share/gems/gems/dynflow-1.6.7/lib/dynflow/director/sequential_manager.rb:63:in dispatch' /usr/share/gems/gems/dynflow-1.6.7/lib/dynflow/director/sequential_manager.rb:70:in block in run_in_sequence’
/usr/share/gems/gems/dynflow-1.6.7/lib/dynflow/director/sequential_manager.rb:70:in all?' /usr/share/gems/gems/dynflow-1.6.7/lib/dynflow/director/sequential_manager.rb:70:in run_in_sequence’
/usr/share/gems/gems/dynflow-1.6.7/lib/dynflow/director/sequential_manager.rb:59:in dispatch' /usr/share/gems/gems/dynflow-1.6.7/lib/dynflow/director/sequential_manager.rb:28:in block in finalize’
/usr/share/gems/gems/dynflow-1.6.7/lib/dynflow/middleware.rb:48:in finalize_phase' /usr/share/gems/gems/dynflow-1.6.7/lib/dynflow/middleware/stack.rb:23:in call’
/usr/share/gems/gems/foreman-tasks-7.0.0/app/lib/actions/middleware/keep_current_user.rb:29:in block in finalize_phase' /usr/share/gems/gems/foreman-tasks-7.0.0/app/lib/actions/middleware/keep_current_user.rb:54:in restore_curent_user’
/usr/share/gems/gems/foreman-tasks-7.0.0/app/lib/actions/middleware/keep_current_user.rb:29:in finalize_phase' /usr/share/gems/gems/dynflow-1.6.7/lib/dynflow/middleware/stack.rb:23:in call’
/usr/share/gems/gems/dynflow-1.6.7/lib/dynflow/middleware/world.rb:31:in execute' /usr/share/gems/gems/dynflow-1.6.7/lib/dynflow/director/sequential_manager.rb:27:in finalize’
/usr/share/gems/gems/dynflow-1.6.7/lib/dynflow/director.rb:143:in execute' /usr/share/gems/gems/dynflow-1.6.7/lib/dynflow/executors/sidekiq/worker_jobs.rb:11:in block (2 levels) in perform’
/usr/share/gems/gems/dynflow-1.6.7/lib/dynflow/executors.rb:18:in run_user_code' /usr/share/gems/gems/dynflow-1.6.7/lib/dynflow/executors/sidekiq/worker_jobs.rb:9:in block in perform’
/usr/share/gems/gems/dynflow-1.6.7/lib/dynflow/executors/sidekiq/worker_jobs.rb:25:in with_telemetry' /usr/share/gems/gems/dynflow-1.6.7/lib/dynflow/executors/sidekiq/worker_jobs.rb:8:in perform’
/usr/share/gems/gems/dynflow-1.6.7/lib/dynflow/executors/sidekiq/serialization.rb:27:in perform' /usr/share/gems/gems/sidekiq-5.2.10/lib/sidekiq/processor.rb:192:in execute_job’
/usr/share/gems/gems/sidekiq-5.2.10/lib/sidekiq/processor.rb:165:in block (2 levels) in process' /usr/share/gems/gems/sidekiq-5.2.10/lib/sidekiq/middleware/chain.rb:128:in block in invoke’
/usr/share/gems/gems/sidekiq-5.2.10/lib/sidekiq/middleware/chain.rb:133:in invoke' /usr/share/gems/gems/sidekiq-5.2.10/lib/sidekiq/processor.rb:164:in block in process’
/usr/share/gems/gems/sidekiq-5.2.10/lib/sidekiq/processor.rb:137:in block (6 levels) in dispatch' /usr/share/gems/gems/sidekiq-5.2.10/lib/sidekiq/job_retry.rb:109:in local’
/usr/share/gems/gems/sidekiq-5.2.10/lib/sidekiq/processor.rb:136:in block (5 levels) in dispatch' /usr/share/gems/gems/sidekiq-5.2.10/lib/sidekiq.rb:37:in block in module:Sidekiq
/usr/share/gems/gems/sidekiq-5.2.10/lib/sidekiq/processor.rb:132:in block (4 levels) in dispatch' /usr/share/gems/gems/sidekiq-5.2.10/lib/sidekiq/processor.rb:250:in stats’
/usr/share/gems/gems/sidekiq-5.2.10/lib/sidekiq/processor.rb:127:in block (3 levels) in dispatch' /usr/share/gems/gems/sidekiq-5.2.10/lib/sidekiq/job_logger.rb:8:in call’
/usr/share/gems/gems/sidekiq-5.2.10/lib/sidekiq/processor.rb:126:in block (2 levels) in dispatch' /usr/share/gems/gems/sidekiq-5.2.10/lib/sidekiq/job_retry.rb:74:in global’
/usr/share/gems/gems/sidekiq-5.2.10/lib/sidekiq/processor.rb:125:in block in dispatch' /usr/share/gems/gems/sidekiq-5.2.10/lib/sidekiq/logging.rb:48:in with_context’
/usr/share/gems/gems/sidekiq-5.2.10/lib/sidekiq/logging.rb:42:in with_job_hash_context' /usr/share/gems/gems/sidekiq-5.2.10/lib/sidekiq/processor.rb:124:in dispatch’
/usr/share/gems/gems/sidekiq-5.2.10/lib/sidekiq/processor.rb:163:in process' /usr/share/gems/gems/sidekiq-5.2.10/lib/sidekiq/processor.rb:83:in process_one’
/usr/share/gems/gems/sidekiq-5.2.10/lib/sidekiq/processor.rb:71:in run' /usr/share/gems/gems/sidekiq-5.2.10/lib/sidekiq/util.rb:16:in watchdog’
/usr/share/gems/gems/sidekiq-5.2.10/lib/sidekiq/util.rb:25:in block in safe_thread' /usr/share/gems/gems/logging-2.3.1/lib/logging/diagnostic_context.rb:474:in block in create_with_logging_context’
Those seem to be foreman logs, not foreman-proxy logs
I pulled these directly from /var/log/foreman-proxy/proxy.log
If that is the case then either then something fairly non standard is going on.
While those entries are in /var/log/foreman-proxy/proxy.log, I was able to see some new log entries when testing this morning that may give us more to work with:
2022-11-08T08:43:47 [D] refresh runner abbea0ac-7991-4a78-aea8-4aa73dff3bdc
2022-11-08T08:43:47 [D] refreshing runner
2022-11-08T08:43:47 [D] finish runner abbea0ac-7991-4a78-aea8-4aa73dff3bdc
2022-11-08T08:43:47 [D] closing session for command [abbea0ac-7991-4a78-aea8-4aa73dff3bdc],0 actors left
2022-11-08T08:43:47 [D] terminate abbea0ac-7991-4a78-aea8-4aa73dff3bdc
2022-11-08T08:43:47 [D] Step da4eabf5-5e4f-481a-af20-ca53752936bc: 3 got event #Proxy::Dynflow::Runner::Update:0x0000559f1f328728
2022-11-08T08:43:47 [D] Step da4eabf5-5e4f-481a-af20-ca53752936bc: 3 suspended >> running in phase Run Proxy::RemoteExecution::Ssh::Actions::ScriptRunner
2022-11-08T08:43:47 69cee379 [D] Step da4eabf5-5e4f-481a-af20-ca53752936bc: 3 running >> success in phase Run Proxy::RemoteExecution::Ssh::Actions::ScriptRunner
2022-11-08T08:43:47 [D] Step da4eabf5-5e4f-481a-af20-ca53752936bc: 6 pending >> running in phase Run Proxy::Dynflow::Callback::Action
2022-11-08T08:43:47 69cee379 [D] Step da4eabf5-5e4f-481a-af20-ca53752936bc: 6 running >> success in phase Run Proxy::Dynflow::Callback::Action
2022-11-08T08:43:47 [D] Step da4eabf5-5e4f-481a-af20-ca53752936bc: 4 pending >> running in phase Finalize Proxy::RemoteExecution::Ssh::Actions::ScriptRunner
2022-11-08T08:43:47 69cee379 [E] Script execution failed
2022-11-08T08:43:47 69cee379 [D] Step da4eabf5-5e4f-481a-af20-ca53752936bc: 4 running >> error in phase Finalize Proxy::RemoteExecution::Ssh::Actions::ScriptRunner
2022-11-08T08:43:47 [D] ExecutionPlan da4eabf5-5e4f-481a-af20-ca53752936bc running >> stopped
2022-11-08T08:43:53 [D] Executor heartbeat
2022-11-08T08:43:57 [D] Step 8fe61bbc-9ae3-4cda-8a9b-662cc7d550cf: 2 got event Dynflow::Action::WithPollingSubPlans::Poll
2022-11-08T08:43:57 [D] Step 8fe61bbc-9ae3-4cda-8a9b-662cc7d550cf: 2 suspended >> running in phase Run Proxy::Dynflow::Action::Batch
2022-11-08T08:43:57 69cee379 [E] A sub task failed
So I ended up finding the solution via another forum post here suggesting I try:
sudo -u foreman-proxy ssh root@foreman.example.com -i https://localhost:8443/ssh/pubkey
I received an immediate permission denied error
My permissions for ~/.ssh and ~/authorized_keys were correct, so I checked /etc/sshd/sshd_config and changed it to both allow root login and password authentication.
Remote execution via Foreman GUI was still not happy. I tested ssh again via Foreman shell, and monitored the status of sshd.service on the host I was trying to connect to.
I received a log stating “Authentication refused: bad ownership or modes for directory /root”
As it turns out, someone had changed permissions to the entire root directory on this particular CentOS 7 machine I migrated.
Once I changed ownership back to root on this directory, all was happy with remote execution from within the GUI.
If I had picked any other CentOS 7 to test, I probably wouldn’t have run into this issue :slight_smile:
On a sidenote, in case someone comes across this thread. The command you have given is not correct and it doesn’t make sense to use -i with that URL. I don’t even know if that’s possible to use an URL. Either way, loading a public key as identity is pointless. You need a private key, not a public key to connect. The server you connect to needs the public key in the authorized_keys file.
The correct command would be
sudo -u foreman-proxy ssh root@client.example.com -i /var/lib/foreman-proxy/ssh/id_rsa_foreman_proxy
That’s what remote execution runs (unless you have made some changes in settings, e.g. to use sudo on the client instead of direct root login)…
For testing, it’s usually a good idea to add -v to the ssh command to see what is going on exactly…
