CentOS7 Ansible problem
Loaded plugins: fastestmirror
Loading mirror speeds from cached hostfile
 * base: mirror.corbina.net
 * epel: epel.scopesky.iq
 * extras: mirror.corbina.net
 * updates: mirror.corbina.net
Resolving Dependencies
--> Running transaction check
---> Package foreman-installer.noarch 1:1.9.3-1.el7 will be installed
--> Processing Dependency: rubygem-kafo >= 0.6.5 for package: 1:foreman-installer-1.9.3-1.el7.noarch
--> Processing Dependency: rubygem-apipie-bindings >= 0.0.6 for package: 1:foreman-installer-1.9.3-1.el7.noarch
--> Processing Dependency: puppet >= 2.7.0 for package: 1:foreman-installer-1.9.3-1.el7.noarch
--> Processing Dependency: rubygem-highline for package: 1:foreman-installer-1.9.3-1.el7.noarch
--> Processing Dependency: foreman-selinux for package: 1:foreman-installer-1.9.3-1.el7.noarch
---> Package foreman-selinux.noarch 0:1.9.3-1.el7 will be installed
--> Processing Dependency: policycoreutils-python for package: foreman-selinux-1.9.3-1.el7.noarch
--> Processing Dependency: /usr/sbin/semanage for package: foreman-selinux-1.9.3-1.el7.noarch
---> Package puppet-agent.x86_64 0:5.5.0-1.el7 will be installed
---> Package rubygem-apipie-bindings.noarch 0:0.0.13-1.el7 will be installed
--> Processing Dependency: rubygem(rest-client) < 1.8.0 for package: rubygem-apipie-bindings-0.0.13-1.el7.noarch
--> Processing Dependency: rubygem(rest-client) >= 1.6.5 for package: rubygem-apipie-bindings-0.0.13-1.el7.noarch
--> Processing Dependency: rubygem(oauth) for package: rubygem-apipie-bindings-0.0.13-1.el7.noarch
--> Processing Dependency: rubygem(awesome_print) for package: rubygem-apipie-bindings-0.0.13-1.el7.noarch
---> Package rubygem-highline.noarch 0:1.6.21-2.el7 will be installed
---> Package rubygem-kafo.noarch 0:0.6.11-1.el7 will be installed
--> Processing Dependency: rubygem(logging) < 2.0.0 for package: rubygem-kafo-0.6.11-1.el7.noarch
--> Processing Dependency: puppet < 4.0.0 for package: rubygem-kafo-0.6.11-1.el7.noarch
Package puppet is obsoleted by puppet-agent, but obsoleting package does not provide for requirements
--> Processing Dependency: rubygem(clamp) >= 0.6.2 for package: rubygem-kafo-0.6.11-1.el7.noarch
--> Processing Dependency: rubygem(powerbar) for package: rubygem-kafo-0.6.11-1.el7.noarch
--> Processing Dependency: rubygem(kafo_parsers) for package: rubygem-kafo-0.6.11-1.el7.noarch
---> Package policycoreutils-python.x86_64 0:2.5-17.1.el7 will be installed
--> Processing Dependency: setools-libs >= 3.3.8-1 for package: policycoreutils-python-2.5-17.1.el7.x86_64
--> Processing Dependency: libsemanage-python >= 2.5-5 for package: policycoreutils-python-2.5-17.1.el7.x86_64
--> Processing Dependency: audit-libs-python >= 2.1.3-4 for package: policycoreutils-python-2.5-17.1.el7.x86_64
--> Processing Dependency: python-IPy for package: policycoreutils-python-2.5-17.1.el7.x86_64
--> Processing Dependency: libqpol.so.1(VERS_1.4)(64bit) for package: policycoreutils-python-2.5-17.1.el7.x86_64
--> Processing Dependency: libqpol.so.1(VERS_1.2)(64bit) for package: policycoreutils-python-2.5-17.1.el7.x86_64
--> Processing Dependency: libcgroup for package: policycoreutils-python-2.5-17.1.el7.x86_64
--> Processing Dependency: libapol.so.4(VERS_4.0)(64bit) for package: policycoreutils-python-2.5-17.1.el7.x86_64
--> Processing Dependency: checkpolicy for package: policycoreutils-python-2.5-17.1.el7.x86_64
--> Processing Dependency: libqpol.so.1()(64bit) for package: policycoreutils-python-2.5-17.1.el7.x86_64
--> Processing Dependency: libapol.so.4()(64bit) for package: policycoreutils-python-2.5-17.1.el7.x86_64
---> Package rubygem-awesome_print.noarch 0:1.0.2-10.el7 will be installed
---> Package rubygem-clamp.noarch 0:1.0.0-1.el7 will be installed
---> Package rubygem-kafo_parsers.noarch 0:0.0.5-1.el7 will be installed
---> Package rubygem-logging.noarch 0:1.8.2-1.el7 will be installed
--> Processing Dependency: rubygem(multi_json) >= 1.8.4 for package: rubygem-logging-1.8.2-1.el7.noarch
--> Processing Dependency: rubygem(little-plugger) >= 1.1.3 for package: rubygem-logging-1.8.2-1.el7.noarch
---> Package rubygem-oauth.noarch 0:0.4.7-6.el7 will be installed
---> Package rubygem-powerbar.noarch 0:1.0.11-8.el7 will be installed
--> Processing Dependency: rubygem(ansi) < 1.5.0 for package: rubygem-powerbar-1.0.11-8.el7.noarch
--> Processing Dependency: rubygem(hashie) >= 1.1.0 for package: rubygem-powerbar-1.0.11-8.el7.noarch
--> Processing Dependency: rubygem(ansi) >= 1.4.0 for package: rubygem-powerbar-1.0.11-8.el7.noarch
---> Package rubygem-rest-client.noarch 0:1.6.7-4.el7 will be installed
--> Processing Dependency: rubygem(mime-types) >= 1.16 for package: rubygem-rest-client-1.6.7-4.el7.noarch
--> Processing Dependency: rubygem(netrc) for package: rubygem-rest-client-1.6.7-4.el7.noarch
---> Package audit-libs-python.x86_64 0:2.7.6-3.el7 will be installed
---> Package checkpolicy.x86_64 0:2.5-4.el7 will be installed
---> Package libcgroup.x86_64 0:0.41-13.el7 will be installed
---> Package libsemanage-python.x86_64 0:2.5-8.el7 will be installed
---> Package python-IPy.noarch 0:0.75-6.el7 will be installed
---> Package rubygem-ansi.noarch 0:1.4.3-2.el7 will be installed
---> Package rubygem-hashie.noarch 0:2.0.5-1.el7 will be installed
---> Package rubygem-little-plugger.noarch 0:1.1.3-18.el7 will be installed
---> Package rubygem-mime-types.noarch 0:1.19-3.el7 will be installed
---> Package rubygem-multi_json.noarch 0:1.10.1-1.el7 will be installed
---> Package rubygem-netrc.noarch 0:0.7.7-5.el7 will be installed
---> Package setools-libs.x86_64 0:3.3.8-1.1.el7 will be installed
--> Finished Dependency Resolution
           Available: puppet-agent-1.8.1-1.el7.x86_64 (puppetlabs-pc1)
               puppet >= 4.0.0-1.el7
           Available: puppet-agent-1.8.2-1.el7.x86_64 (puppetlabs-pc1)
           Available: puppet-agent-1.8.3-1.el7.x86_64 (puppetlabs-pc1)
           Available: puppet-agent-1.9.0-1.el7.x86_64 (puppetlabs-pc1)
           Available: puppet-agent-1.9.1-1.el7.x86_64 (puppetlabs-pc1)
           Available: puppet-agent-1.9.2-1.el7.x86_64 (puppetlabs-pc1)
           Available: puppet-agent-1.9.3-1.el7.x86_64 (puppetlabs-pc1)
           Available: puppet-agent-1.10.0-1.el7.x86_64 (puppetlabs-pc1)
           Available: puppet-agent-1.10.1-1.el7.x86_64 (puppetlabs-pc1)
           Available: puppet-agent-1.10.2-1.el7.x86_64 (puppetlabs-pc1)
           Available: puppet-agent-1.10.3-1.el7.x86_64 (puppetlabs-pc1)
           Available: puppet-agent-1.10.4-1.el7.x86_64 (puppetlabs-pc1)
           Available: puppet-agent-1.10.5-1.el7.x86_64 (puppetlabs-pc1)
           Available: puppet-agent-1.10.6-1.el7.x86_64 (puppetlabs-pc1)
           Available: puppet-agent-1.10.7-1.el7.x86_64 (puppetlabs-pc1)
           Available: puppet-agent-1.10.8-1.el7.x86_64 (puppetlabs-pc1)
           Available: puppet-agent-1.10.9-1.el7.x86_64 (puppetlabs-pc1)
           Available: puppet-agent-1.10.10-1.el7.x86_64 (puppetlabs-pc1)
           Available: puppet-agent-5.0.0-1.el7.x86_64 (puppet5)
           Available: puppet-agent-5.0.1-1.el7.x86_64 (puppet5)
           Available: puppet-agent-5.1.0-1.el7.x86_64 (puppet5)
           Available: puppet-agent-5.2.0-1.el7.x86_64 (puppet5)
           Available: puppet-agent-5.3.1-1.el7.x86_64 (puppet5)
           Available: puppet-agent-5.3.2-1.el7.x86_64 (puppet5)
           Available: puppet-agent-5.3.3-1.el7.x86_64 (puppet5)
           Available: puppet-agent-5.3.4-1.el7.x86_64 (puppet5)
           Available: puppet-agent-5.3.5-1.el7.x86_64 (puppet5)
           Available: puppet-agent-5.4.0-1.el7.x86_64 (puppet5)
           Installing: puppet-agent-5.5.0-1.el7.x86_64 (puppet5)
You are trying to install Foreman 1.9.3. This is an ancient version which is no longer supported. I’d highly recommend using the latest released version.
