Hi all,
i'm facing that Problem in Foreman 13.2, 1.14.3 and 1.15.1.
On Some Hosts we need to change the Interface that will be used to
establish the connections.
So when i try to do the change with Host --> edit --> interface --> edit
–> select remote execution , the selection will not be saved after I
pressed submit.
Even if i get the Warning that another Interface is already configured and
i am sure to do this.Try also to de-configure the former interface is not
working.
It only works when the host is the first time provisioned/saved. Afterwards
the change is not possible anymore…
So we have a different Interfaces for Provisioning and Remote Execution.
But both are Managed. The Remote Execution is also the Primary and a
virtual one with VLAN Tag.
Maybe i do something wrong or it is really a bug.
Thanks for your help.
Regards
Susanne
