I have an outstanding request for container image repositories to be able to configure a proxy per repository. I think @Justin_Sherrill did some work in this area? Are there docs for what is possible in current and future releases of foreman?
I think the user story is that syncing from some external registries will require a proxy while other registries won’t.
Some work has been done in this area but not per-proxy repository yet.
You can now tell a repository to ‘ignore’ the globally set katello proxy
We’ve created an ‘http proxy’ object now that you can define in the UI
(Under infrastructure). This can only be used with a compute resource
currently. The goal was to extend this to support repositories in the
future, but hasn’t happened yet
Justin
