> Someone know if is possible to use MS DHCP when the smart-proxy is
> installed on linux "centos7' OS?
> I have already foreman & puppet infrastructure installed on linux and i
> whant to use a already MS DHCP service.
> Somebody have a same experience?
Hopefully in foreman you are not limited to one Smart proxy, just install a
second one on a Windows machine with the good rights for managing dhcp and you
are done.
Regards,
Claer
On Tue, Jan 26 2016 at 13:03, Aristophane Z wrote:
thank you for your answer, i will try it.
Regards,
Aristophane Z
Le mardi 26 janvier 2016 12:48:07 UTC+1, Aristophane Z a écrit :
> Hello guys,
> Thanks a lot
> Regards
> Aristophane Z
>> Hello guys,
> Hello,
The provider relies on netsh.exe; it will only work on windows.
> are done.
Indeed, just add a new smart proxy on a Windows machine; not even
necessarily the the DHCP server. In this case, make sure the smart proxy
runs as under an user account with enough privileges.
Installation on Windows is gem/bundler only but works quite well if you
follow the instructions [here].
