Hello
I have this in my manifest file:
$udp_send_channel = [
{ mcast_join => '239.2.11.71', port => 8649, ttl => 1 }
$udp_recv_channel = [
{ mcast_join => '239.2.11.71', port => 8649, bind => '239.2.11.71' }
$tcp_accept_channel = [ { port => 8649 } ],
When I override it value like this:
[{"port"=>8649, "bind"=>"239.2.11.71", "mcast_join"=>"239.2.11.71"}]
The foreman will report error message: (<unknown>): did not find
expected ',' or '}' while parsing a flow mapping at line 1 column 2
But when I set value is [ { port => 8649 } ]
Then the foreman will change the value to: [{"port=>8649"=>nil}]
How to override this kind of array value?
Best Regards
Xiaofei
Hello
I override the value of "udp_recv_channel" to this:
- {port: 8649, mcast_join: "239.2.11.71", bind: "239.2.11.71"}
The data type can be array or yaml.
Then submit successfully. But I look into the value changed to :
If I submit again it will show the array message : (<unknown>): did not
find expected ',' or '}' while parsing a flow mapping at line 1 column 2
If I want to change the value I must change it to yaml first.
Is this a bug or not.
Xiaofei
On Tuesday, March 11, 2014 4:52:31 PM UTC+8, Yan Xiaofei wrote:
> Hello
> The foreman will report error message: (): did not find
> Best Regards
> Xiaofei
Hello
When I override the smart variables's value to this:
type: yaml
value: - {port=>8649, mcast_join=>239.2.11.71, bind=>239.2.11.71}
Then I can submit it, but after submit the value type change to array. And
the value change back to : [{"port"=>8649, "bind"=>"239.2.11.71",
Why it change back the value?
My foreman version is 1.3.0-1.
Xiaofei
On Tuesday, March 11, 2014 3:21:27 PM UTC+4, Yan Xiaofei wrote:
> Hello
> If I submit again it will show the array message : (): did not
> Xiaofei
>> Hello
>> Best Regards
>> Xiaofei
You might be seeing a combination of two bugs.
Bug #2726: Smart Class Parameter - over-ride match value unable to set yaml - Foreman which was fixed in Foreman
1.4.1 and prevented the smart variable being saved due to bad validation.
Bug #4639: Syntax of arrays in parameters changed when edit is changed. - Foreman which isn't fixed, where the
syntax is being shown with "=>" which aren't valid JSON or YAML (it's
Ruby syntax). Sounds like your original reported issue.
Dominic Cleal
Red Hat Engineering
On 14/03/14 06:37, Yan Xiaofei wrote:
Hello
When I override the smart variables’s value to this:
type: yaml
And the value change back to : [{“port”=>8649, “bind”=>“239.2.11.71”,
“mcast_join”=>“239.2.11.71”}]
Xiaofei
Hello
not find expected ',' or '}' while parsing a flow mapping at line 1
column 2
Xiaofei
Hello
'239.2.11.71' }
column 2
Best Regards
Xiaofei
Groups “Foreman users” group.
an email to foreman-users+unsubscribe@googlegroups.com
Hello Dominic,
I use json format resolve this problem.
Here is what i set :
[{"port":"8649","mcast_join":"239.2.11.71","bind":"239.2.11.71"}]
> http://projects.theforeman.org/issues/2726 which was fixed in Foreman
> http://projects.theforeman.org/issues/4639 which isn't fixed, where the
