When using foreman-installer in a vagrant created vbox, I found that the default DNS address was being assigned to the wrong interface for my LAB.
I wanted the domain on the host-only interface or bridge interface, not the vagrant NAT one.
While the system still worked sort of , I found I was getting issues around CA’s and kept getting the dreaded.
On the master:
puppet cert clean
On the Agent
clear PUPPET/ssl
Not to have to clear the certs down.
Foreman and Proxy versions: 1.15, havent tested 1.16 yet
I wrote this little shell function to help me juggle the names around. I am posting this here because I could nt find very many good examples to do this.
#/bin/bash
vbox_sort_interfaces() {
F_HOST=$1
PREFIX="v"
HOST_ID=$(sudo -E hammer host list |grep ${F_HOST} |cut -f 1 -d ' ')
sudo -E hammer host interface list --host-id ${HOST_ID} |grep ${PREFIX}${F_HOST}
if [[ $? -eq 0 ]]
then
echo "Already been juggled around"
else
echo "Needs to be juggled"
sudo -E hammer host interface update --host-id 1 --id 1 --name ${PREFIX}${F_HOST}
sudo -E hammer host interface update --host-id 1 --id 2 --name ${F_HOST} --primary --provision
fi
vbox_sort_interfaces example.com
This juggles the Service DNS name to another interface.
