Just that, I can still go to smart-proxy -> certificates and delete
certificate from there… but I would like foreman to automatically delete
it.
I tried this on fresh ubuntu and redhat installations
Versions:
puppet: 3.3.2
foreman: 1.4.1
Ubuntu: 12.04
Centos: 6.5
Foreman deletes the cert if Foreman created the cert. If you
provisioned these systems outside Foreman, then it doesn't try to
manage the cert. So the question is, did you provision these systems
with Foreman?
No I haven't… and that makes sense.
I did "manage host" and then delete it and that worked straight away.
Thanks for the tip!
Cheers
Juan
> with Foreman?
