Both the ruby193-ruby and ruby193-rubygems are not available in the
foreman 1.5 or the EPEL repo:
yum install ruby193-ruby ruby193-rubygems
Loaded plugins: fastestmirror
Loading mirror speeds from cached hostfile
Setting up Install Process
No package ruby193-ruby available.
No package ruby193-rubygems available.
Error: Nothing to do
Strange part is the packages are also not available in the 1.4 repo but
in my katello install these are fetched from the katello repo…
The text in the install doc is not entirely clear as I interpreted it as
"only on RHEL 6"
3.1.1 Supported Platforms
The following operating systems are supported by the installer,
have packages and are tested for deploying Foreman:
* Red Hat Enterprise Linux 6 and derivatives (CentOS, Scientific
Linux)
* EPEL is required
* On RHEL 6, additionally the Optional and RHSCL 1.0
repositories/channels:
* yum-config-manager --enable
rhel-6-server-optional-rpms
rhel-server-rhscl-6-rpms
Later things are more clear:
3.3.1 RPM Packages
Pre-requisites
All RHEL and derivatives require Red Hat Software Collections
(RHSCL) 1.0 or rebuild, e.g. Software Collections for CentOS.
RHSCL is available to RHEL customers as a separate repository or
child channel. More information on Software Collections for
CentOS is available here and for Scientific Linux it is
available here.
On Tue, 2014-05-06 at 09:54 +0200, Lukas Zapletal wrote:
you are likely missing CentOS SCL 1.0 repository. What is your
yum repolist
output?
On Tue, May 06, 2014 at 08:16:14AM +0200, Jorick Astrego wrote:
When I try to install one of the foreman plugins in 1.5 RC2 on Centos
6.5, I get a dependency problem:
Sorry for the confusion - the intention was to avoiding confusing users
who were using the installer. The installer's capable of configuring
the CentOS and Scientific Linux SCL repos, but not RHSCL for RHEL itself.
If you're using the installer then the expectation is you'll see 3.1.1
and not add it manually, but then if you're installing just from
packages then you would.
Dominic Cleal
Red Hat Engineering
On 06/05/14 17:09, Jorick Astrego wrote:
Ah, thanks!
"only on RHEL 6"
*3.1.1 Supported Platforms*
The following operating systems are supported by the installer, have
Red Hat Enterprise Linux 6 and derivatives (CentOS, Scientific Linux)
o EPEL http://fedoraproject.org/wiki/EPEL is required
o On RHEL 6, additionally the Optional and RHSCL 1.0
+ yum-config-manager --enable rhel-6-server-optional-rpms
*3.3.1 RPM Packages*
*Pre-requisites*
*All RHEL and derivatives require Red Hat Software Collections
(RHSCL) 1.0 or rebuild, e.g. Software Collections for CentOS.* RHSCL
is available to RHEL customers as a separate repository or child
channel. More information on Software Collections for CentOS is
available here
<http://wiki.centos.org/AdditionalResources/Repositories/SCL> and
for Scientific Linux it is available here
<http://ftp.scientificlinux.org/linux/scientific/6/x86_64/external_products/softwarecollections/>.
yum repolist
output?
Ah ok, I wanted to use foreman installer but wanted to save some time on
this run by using the foreman_setup plugin:
foreman_setup https://github.com/theforeman/foreman_setup
It helps set
up
provisioning
in two parts
using a
wizard: a)
helps you
enter network
info and then
tells you how
to run Foreman
installer to
set up DHCP
and DNS
management, b)
sets up an OS
with
templates,
installation
media and
everything you
need
yes
yes
So I just added the repo manually.
Kind regards,
Jorick Astrego
who were using the installer. The installer’s capable of configuring
If you’re using the installer then the expectation is you’ll see 3.1.1
and not add it manually, but then if you’re installing just from
Dominic Cleal
Red Hat Engineering
Ah, thanks!
“only on RHEL 6”
*Pre-requisites*
available here
yum repolist
output?
I get it now, first install foreman and then use the setup plugin to
configure dns/dhcp
on this run by using the foreman_setup plugin:
It helps set
up
provisioning
in two parts
using a
wizard: a)
helps you
enter network
info and then
tells you how
to run Foreman
installer to
set up DHCP
and DNS
management, b)
sets up an OS
with
templates,
installation
media and
everything you
need
yes
yes
Kind regards,
Jorick Astrego
