https://docs.google.com/document/d/1StSf6700dvKMXLpgFsxQrq8yv3CI6MH_VI_8ucjs4og/edit
Remote Execution
Presented by Ivan
-Remove blue from documentation button
Could Search input field be converted to standard search query
Resolves to buttons are just icons without words… use word buttons,
preview and reload. -
Title case for labels, move help text to tooltip/icon help
Activation Keys.
- Removal of two-pane view would fix the inline messaging error found in
the left hand nav.
Providers and template - “ Providers and Templates
“Manual Selection using Static Query – change name to reflect previous
search input. -
In instances when the donut is not present the remaining text above the
donut is not obvious. -
Time stamps - Past a certain amount of days, just use the time stamp vs.
“5 days ago”. -
Succeeded blocks are blue - They should be green, Pending could be dark
grey, Total to remain blue. -
Change heading to “Job Invocations”
Toggle buttons into one multi-select, separate Task Details and Cancel
job. WIth breadcrumb interaction “Back to Job” will no longer be needed. -
Console grows as more lines are added. Limit growth area and add in
scroll vs. having the page grow uncontrollably.Add status for last occurrence
Change Cancelled icon to “pficon-error-circle-o” in red, Finished to
“pficon-ok” in green and Active to “fa-repeat” in blue.Change heading to “Recurring Logics”
Change these both to grey or choose which one is more important and only
have 1 blue button.Change “Effective user” to “Effective User”
Capitalize “F” in “failed” and make red.
Perhaps a larger discussion: See PatternFly Active Filters for handling
to status filters below search bar:
http://www.patternfly.org/pattern-library/forms-and-controls/filter/#/designMove help to label and remove blue explanation text next to icon.
Change X for Template Input to “Remove” button
Change “Template input” to “Template Input”
Ensure title casing is used for all headers.
