in Foreman a user can set a DNS proxy on a subnet and a Domain. I find
this confusing and hope somebody might share insight with me:
- What is the necessity to set a DNS proxy on a subnet?
- What could be the use case set a different DNS proxy on a subnet and a
Domain?
Thanks!
Daniel Helgenberger
Schivelbeiner Str. 46
10439 Berlin
> Hello,
It manages the reverse DNS zone, e.g. 100.168.192.in-addr.arpa.
> Domain?
Forward and reverse authoritative DNS might be managed by different
servers as subnet/domain may have different scopes (perhaps departmental
domains, but organisation-wide subnets etc.).
On 04/02/16 10:53, Daniel Helgenberger wrote:
Dominic Cleal
dominic@cleal.org
>> Hello,
Thanks Dominic, this makes absolutely sense of course. Now that you
mention it, the help text next to it reads:
> DNS Proxy to use within this subnet for managing PTR records
A clear case of RTFM on my side here. That said, maybe it is still a
good idea to rename the drop down label from:
> DNS Proxy
to
> Reverse DNS Proxy
What do you think, should I open an issue?
Domain?
Daniel Helgenberger
10439 Berlin
Sure, sounds helpful to me.
>>> Hello,
>> DNS Proxy
> to
>> Reverse DNS Proxy
Dominic Cleal
dominic@cleal.org
