Until a few months ago when I fatally update my systems from 6.3 to 6.4 I was happily building virtual hosts with Foreman. After doing this update I have not been able to build anything. When I create a host and use the default RAW storage type I get the following errors in /var/log/libvirt/qemu/hostname
2013-08-20 06:53:20.993+0000: starting up
LC_ALL=C PATH=/sbin:/usr/sbin:/bin:/usr/bin QEMU_AUDIO_DRV=none /usr/libexec/qemu-kvm -name akabane -S -M rhel6.4.0 -enable-kvm -m 1024 -smp 1,sockets=1,co
res=1,threads=1 -uuid 419b637f-4b86-92cb-bbba-71b9acbf4ec3 -nodefconfig -nodefaults -chardev socket,id=charmonitor,path=/var/lib/libvirt/qemu/akabane.monit
or,server,nowait -mon chardev=charmonitor,id=monitor,mode=control -rtc base=utc -no-shutdown -device piix3-usb-uhci,id=usb,bus=pci.0,addr=0x1.0x2 -drive file=/dev/KVM/ak
abane-disk1,if=none,id=drive-virtio-disk0,format=raw -device virtio-blk-pci,scsi=off,bus=pci.0,addr=0x4,drive=drive-virtio-disk0,id=virtio-disk0,bootindex=
2 -netdev tap,fd=29,id=hostnet0,vhost=on,vhostfd=30 -device virtio-net-pci,netdev=hostnet0,id=net0,mac=52:54:00:c3:67:1c,bus=pci.0,addr=0x3,bootindex=1 -chardev pty,id=c
harserial0 -device isa-serial,chardev=charserial0,id=serial0 -vnc unix:/var/lib/libvirt/qemu/akabane.vnc,password -vga cirrus -device virtio-balloon-pci,id
=balloon0,bus=pci.0,addr=0x5
char device redirected to /dev/pts/1
block I/O error in device 'drive-virtio-disk0': Input/output error (5)
qemu: terminating on signal 15 from pid 1626
2013-08-20 07:00:49.058+0000: shutting down
This happens with systems that were updated as well as those which were fresh installed with 6.4 . I am pretty certain this is libvirt related but curious if anyone has tripped across this error at all.
Regards,
