Discovery pxe less no ip
booting vm from fdi iso does not configure any ip address on vm
discovery procedure starts
rubygem-foreman_discovery-25.0.0-1.fm3_13.el9.noarch
rubygem-smart_proxy_discovery-1.0.5-10.fm3_11.el9.noarch
Both the foreman as the vm booting from the iso are on the same libvirt host. Both are on the same libvirt network (default). The foreman gets an ip address from the local dnsmasq service, the discovery iso does not.
It stops at the dracut shell.
I want to test a pxe less discovery
Tcpdump on the libvirt hypervisor on the discovery vm only shows stp traffic
in the dracut shell, if I run dhclient I get an ip address.
It appears I am hitting Custom RHEL 7 Installation ISO/DVD fails with "Warning: dracut-initqueue timeout - starting timeout scripts" - Red Hat Customer Portal
I need to check it tomorrow
ah, no, it turns out that if using cockpit instead of virt-manager, then the cdrom is not properly seen as a cdrom. It works now
