Hey,
I'm seeing an issue in foreman (1.6.3) where host group parameters are
correctly passed via YAML but when I make a call to the API (both v1 or v2)
the parameters section only contains the parameters directly assigned to
the host.
i.e
YAML:
--- classes: base: parameters: puppetmaster: foreman.<> hostgroup: Base-S/Network-S/Security-S location: <> organization: <> root_pw: <> puppet_ca: foreman.<> foreman_env: staging owner_name: Admin User owner_email: chris.gibbs@<> ip: rdpport: '3389' sshport: '22' environment: stagingAPI:
{“name”:“svr10”,“id”:32,“ip”:null,“environment_id”:2,“environment_name”:“staging”,“last_report”:null,“mac”:“10:00:00:00:00:00”,“realm_id”:null,“realm_name”:null,“sp_mac”:null,“sp_ip”:null,“sp_name”:null,“domain_id”:1,“domain_name”:"<>",“architecture_id”:1,“architecture_name”:“x86_64”,“operatingsystem_id”:4,“operatingsystem_name”:“Windows 2008 R2”,“subnet_id”:1,“subnet_name”:“Provisioning”,“sp_subnet_id”:null,“ptable_id”:11,“ptable_name”:“Windows”,“medium_id”:9,“medium_name”:“Windows2008r2”,“build”:true,“comment”:"",“disk”:"",“installed_at”:null,“model_id”:null,“model_name”:null,“hostgroup_id”:9,“hostgroup_name”:“Base-S/Network-S/Security-S”,“owner_id”:3,“owner_type”:“User”,“enabled”:true,“puppet_ca_proxy_id”:1,“managed”:true,“use_image”:null,“image_file”:"",“uuid”:null,“compute_resource_id”:null,“compute_resource_name”:null,“compute_profile_id”:null,“compute_profile_name”:null,“capabilities”:[“build”],“provision_method”:“build”,“puppet_proxy_id”:1,“certname”:“svr10.<>”,“image_id”:null,“image_name”:null,“created_at”:“2014-12-08T00:50:11Z”,“updated_at”:“2014-12-08T00:50:11Z”,“last_compile”:null,“last_freshcheck”:null,“serial”:null,“source_file_id”:null,“puppet_status”:0,“organization_id”:2,“organization_name”:“Company”,“location_id”:8,“location_name”:"<>",“all_puppetclasses”:[{“id”:126,“name”:“base”,“module_name”:“sau_basepackages”}],“parameters”:[{“id”:266,“name”:“sshport”,“value”:“22”}],“interfaces”:[],“puppetclasses”:[],“config_groups”:[]}
Should I be recursively looking up the hostgroup for parameters that are applied there?
Kind of defeats the point as then i would also need to program the inheritance order of priority. Feature?
