Is there a way to run Foreman with distributed DHCP/PXE environments?
I want to use Foreman for bare metal builds. It is working great as a
single instance in my lab environment. This instance in my lab controls
all services - DHCP/TFTP, etc, which are all running on the same host.
This works for the lab, however I'm trying to figure out how to scale it.
We have dozens of datacenters which are dispersed geographically, and I
need to be able to build bare metal hosts in these locations with DHCP/PXE
as well.
Is Foreman able handle multiple DHCP/PXE servers? Is there another way to
accomplish what I'm trying to achieve? The goal is to have a single
Foreman instance which can control booting/installation of these bare metal
servers, no matter their geographic location.
Yes, the smart-proxy handles this. You will need a smart-proxy in each
datacenter or location to handle DHCP/TFTP. The smart-proxy will
communicate back to your main Foreman instance and allow you to provision
hosts in these remote locations.
Josh
This works for the lab, however I’m trying to figure out how to scale it.
as well.
accomplish what I’m trying to achieve? The goal is to have a single
> Josh
>> as well.
>> to accomplish what I'm trying to achieve? The goal is to have a single
>> Thanks.
>> "Foreman users" group.
>> Visit this group at http://groups.google.com/group/foreman-users.
how about the scalability of the configuration management part? each smart
proxy will be on puppet master, correct? or one can have more than one load
balanced smart proxy?? how many hosts one smart proxy can handle?
as well.
to accomplish what I’m trying to achieve? The goal is to have a single
A smart proxy may or may not contain a puppet master - for speed reasons it may be desirable to have a puppet master on each smart proxy and keep traffic local to each datacenter you can separate out the functionality and have two smart proxies per DC one for Puppet and one for builds but until your thinking of 4k+ hosts per DC I am not sure what this would buy you other than more servers to manage. I have heard anecdotal evidence that a single foreman server scales to 5000+ hosts
YMMV
Luke
> On Aug 23, 2015, at 2:09 AM, Walid wrote:
> Hi Josh,
> how about the scalability of the configuration management part? each smart proxy will be on puppet master, correct? or one can have more than one load balanced smart proxy?? how many hosts one smart proxy can handle?
> Yes, the smart-proxy handles this. You will need a smart-proxy in each datacenter or location to handle DHCP/TFTP. The smart-proxy will communicate back to your main Foreman instance and allow you to provision hosts in these remote locations.
> Josh
> I want to use Foreman for bare metal builds. It is working great as a single instance in my lab environment. This instance in my lab controls all services - DHCP/TFTP, etc, which are all running on the same host. This works for the lab, however I'm trying to figure out how to scale it. We have dozens of datacenters which are dispersed geographically, and I need to be able to build bare metal hosts in these locations with DHCP/PXE as well.
> Is Foreman able handle multiple DHCP/PXE servers? Is there another way to accomplish what I'm trying to achieve? The goal is to have a single Foreman instance which can control booting/installation of these bare metal servers, no matter their geographic location.
> Thanks.
