Hello, Friends
I have set up provison mode correctly, And I want to install Centos7 on
VMware.
Everything seems to be OK, I New a Host and The DHCP, TFTP is also work
well, But Every time, It blocked on the install,
The kickstart is default and I didn't changed anything about it.
I suspect does the ks file has something wrong?
The ks file contents:
kind: provision
oses:
- CentOS 4
- CentOS 5
- CentOS 6
- CentOS 7
- Fedora 16
- Fedora 17
- Fedora 18
- Fedora 19
- Fedora 20
This template accepts the following parameters: - lang: string (default="en_US.UTF-8")
- keyboard: string (default="us")
- time-zone: string (default="UTC")
- http-proxy: string (default="")
- http-proxy-port: string (default="")
- force-puppet: boolean (default=false)
- enable-puppetlabs-repo: boolean (default=false)
- salt_master: string (default=undef)
- ntp-server: string (default="0.fedora.pool.ntp.org")
rhel_compatible = @host.operatingsystem.family == 'Redhat' &&
@host.operatingsystem.name != 'Fedora'
os_major = @host.operatingsystem.major.to_i
realm_compatible = (@host.operatingsystem.name == 'Fedora' && os_major >=
- || (rhel_compatible && os_major >= 7)
safemode renderer does not support unary negation
proxy_string = @host.params['http-proxy'] ? "
–proxy=http://#{@host.params['http-proxy']}:#{@host.params['http-proxy-port']}"
puppet_enabled = pm_set || @host.params['force-puppet'] &&
@host.params['force-puppet'] == 'true'
salt_enabled = @host.params['salt_master'] ? true : false
chef_enabled = @host.respond_to?(:chef_proxy) && @host.chef_proxy
section_end = (rhel_compatible && os_major <= 5) ? '' : '%end'
install
<%= @mediapath %><%= proxy_string %>
lang <%= @host.params['lang'] || 'en_US.UTF-8' %>
selinux --enforcing
keyboard <%= @host.params['keyboard'] || 'us' %>
skipx
<% subnet = @host.subnet -%>
<% if subnet.respond_to?(:dhcp_boot_mode?) -%>
<% dhcp = subnet.dhcp_boot_mode? && !@static -%>
<% else -%>
<% dhcp = !@static -%>
<% end -%>
network --bootproto <%= dhcp ? 'dhcp' : "static --ip=#{@host.ip}
–netmask=#{subnet.mask} --gateway=#{subnet.gateway}
–nameserver=#{[subnet.dns_primary,
subnet.dns_secondary].select(&:present?).join(',')}" %> --device=<%=
@host.mac -%> --hostname <%= @host %>
rootpw --iscrypted <%= root_pass %>
firewall --<%= os_major >= 6 ? 'service=' : '' %>ssh
authconfig --useshadow --passalgo=sha256 --kickstart
timezone --utc <%= @host.params['time-zone'] || 'UTC' %>
<% if rhel_compatible && os_major > 4 -%>
services --disabled
gpm,sendmail,cups,pcmcia,isdn,rawdevices,hpoj,bluetooth,openibd,avahi-daemon,avahi-dnsconfd,hidd,hplip,pcscd
<% end -%>
<% if realm_compatible && @host.info['parameters']['realm'] && @host.otp &&
@host.realm && @host.realm.realm_type == 'Active Directory' -%>
realm join --one-time-password='<%= @host.otp %>' <%= @host.realm %>
<% end -%>
<% if @host.operatingsystem.name == 'Fedora' -%>
repo --name=fedora-everything
–mirrorlist=https://mirrors.fedoraproject.org/metalink?repo=fedora-<%=
@host.operatingsystem.major %>&arch=<%= @host.architecture %><%=
proxy_string %>
<% if puppet_enabled && @host.params['enable-puppetlabs-repo'] &&
@host.params['enable-puppetlabs-repo'] == 'true' -%>
repo --name=puppetlabs-products
–baseurl=http://yum.puppetlabs.com/fedora/f<%= @host.operatingsystem.major
%>/products/<%= @host.architecture %><%= proxy_string %>
repo --name=puppetlabs-deps --baseurl=http://yum.puppetlabs.com/fedora/f<%=
@host.operatingsystem.major %>/dependencies/<%= @host.architecture %><%=
proxy_string %>
<% end -%>
<% elsif rhel_compatible && os_major > 4 -%>
repo --name="EPEL"
–mirrorlist=https://mirrors.fedoraproject.org/metalink?repo=epel-<%=
proxy_string %>
repo --name=puppetlabs-products --baseurl=http://yum.puppetlabs.com/el/<%=
@host.operatingsystem.major %>/products/<%= @host.architecture %><%=
proxy_string %>
repo --name=puppetlabs-deps --baseurl=http://yum.puppetlabs.com/el/<%=
proxy_string %>
<% end -%>
<% end -%>
<% if @host.operatingsystem.name == 'Fedora' and os_major <= 16 -%>
Bootloader exception for Fedora 16:
bootloader --append="nofb quiet splash=quiet <%=ks_console%>" <%= grub_pass
part biosboot --fstype=biosboot --size=1
<% else -%>
bootloader --location=mbr --append="nofb quiet splash=quiet" <%= grub_pass
<% end -%>
<% if @dynamic -%>
%include /tmp/diskpart.cfg
<% else -%>
<%= @host.diskLayout %>
<% end -%>
text
reboot
%packages
yum
dhclient
ntp
wget
@Core
<% if os_major >= 6 -%>
redhat-lsb-core
<% end -%>
epel-release
<% end -%>
<% if puppet_enabled %>
puppet
<% if @host.params['enable-puppetlabs-repo'] &&
puppetlabs-release
<% end -%>
<% end -%>
<% if salt_enabled %>
salt-minion
<% end -%>
<%= section_end -%>
<% if @dynamic -%>
%pre
<%= section_end -%>
<% end -%>
%post --nochroot
exec < /dev/tty3 > /dev/tty3
#changing to VT 3 so that we can see whats going on…
/usr/bin/chvt 3
cp -va /etc/resolv.conf /mnt/sysimage/etc/resolv.conf
/usr/bin/chvt 1
) 2>&1 | tee /mnt/sysimage/root/install.postnochroot.log
<%= section_end -%>
%post
logger "Starting anaconda <%= @host %> postinstall"
/usr/bin/chvt 3
<%= snippet 'kickstart_networking_setup' %>
<% end -%>
#update local time
echo "updating system time"
/usr/sbin/ntpdate -sub <%= @host.params['ntp-server'] ||
'0.fedora.pool.ntp.org' %>
/usr/sbin/hwclock --systohc
<% if @host.info['parameters']['realm'] && @host.otp && @host.realm &&
@host.realm.realm_type == 'FreeIPA' -%>
<%= snippet 'freeipa_register' %>
<% end -%>
update all the base packages from the updates repository
yum -t -y -e 0 update
<% if chef_enabled %>
echo "Bootstraping chef"
<%= respond_to?(:chef_bootstrap) ? chef_bootstrap(@host) :
snippet_if_exists("chef-client omnibus bootstrap") %>
<% end%>
echo "Configuring puppet"
cat > /etc/puppet/puppet.conf << EOF
<%= snippet 'puppet.conf' %>
EOF
Setup puppet to run on system reboot
/sbin/chkconfig --level 345 puppet on
/usr/bin/puppet agent --config /etc/puppet/puppet.conf -o --tags
no_such_tag <%= @host.puppetmaster.blank? ? '' : "–server
#{@host.puppetmaster}" %> --no-daemonize
<% end -%>
cat > /etc/salt/minion << EOF
<%= snippet 'saltstack_minion' %>
EOF
Setup salt-minion to run on system reboot
/sbin/chkconfig --level 345 salt-minion on
Running salt-call to trigger key signing
salt-call --no-color --grains >/dev/null
<% end -%>
sync
Inform the build system that we are done.
echo "Informing Foreman that we are built"
wget -q -O /dev/null --no-check-certificate <%= foreman_url %>
) 2>&1 | tee /root/install.post.log
exit 0
<%= section_end -%>
It Blocked on this:
Thank you for give me some advice!
