Hi All,
I'm trying to create structures like this:
Environment A Environment B
Apache MySQL Varnish Apache MySQL
Hostgroup Hostgroup Hostgroup Hostgroup Hostgroup
Frontend Database Cache Frontend Database
server server server server server
Naturally, each of these servers then needs access to a global set of
environment variables to be used for configuration. (eg, cache server needs
to know where its apache servers are)
There are a number of ways something like this could be achieved, but none
of them feel like Best Practice:
- Create multiple Environments, clone hostgroups, and assign the
related environments. This is not DRY.
- Use domains to differentiate environments, which *can have *variables
attached.
- Clone hostgroups, assign a custom module to a common parent
hostgroup, override smart params for host lookup. Again, not DRY.
most of my issue here is with why environments cant have variables, and why
hostgroups need to be bound to environments - shouldn't they be independent?
Chef can do this with environment definitions, which can also be duplicated
easily, and are independent of roles (hostgroups), surely Puppet and
Foreman can do something similar?
I feel like I'm missing something obvious here.
any commentary would be greatly appreciated!
> Hi All,
> 1. Create multiple Environments, clone hostgroups, and assign the
> 2. Use domains to differentiate environments, which *can have *variables
> attached.
> 3. Clone hostgroups, assign a custom module to a common parent
> why hostgroups need to be bound to environments - shouldn't they be
> independent?
> duplicated easily, and are independent of roles (hostgroups), surely Puppet
> and Foreman can do something similar?
Did you consider having a smart var for this?
you could do a match order based on a combination, e.g. hostgroup,
environment
then
match is environment = A, hostgroup = mysql
value …
Ohad
On Fri, Feb 14, 2014 at 9:43 AM, Rowcliffe Browne wrote:
"Foreman users" group.
That would make sense, but my question is, as best practice, where do you
put it?
on a hostgroup, and your cloning and parenting to make your smart vars
available to all servers?
on a domain?
Neither feel like work arounds, not the correct solution.
rowy.
On Saturday, February 15, 2014 5:24:27 AM UTC+8, ohad wrote:
> On Fri, Feb 14, 2014 at 9:43 AM, Rowcliffe Browne <rbkb...@gmail.com > > wrote:
>> Hi All,
>> none of them feel like Best Practice:
>> attached.
>> independent?
> environment
> then
> value ...
> Ohad
>> Visit this group at http://groups.google.com/group/foreman-users.
