Environments not working! Please help
Hi all!,
I just updated to Foreman 1.7.2 and since then my puppet agents are picking
up "wrong" environments :confused:
running on the client I get
root@unstable:~# puppet agent --configprint environment
production
however the client is set to "development" in Foreman…
Any clue?
Best Regards
Siggi
I believe that configprint just echoes the environment given in
/etc/puppet/puppet.conf. If foreman is sending a different environment,
puppet should print a warning at the beginning of the puppet run, and use
the environment given by foreman instead. I recommend adding a rule to
update puppet.conf with the current environment. You can check the yaml
output of foreman to see what environment foreman is actually sending the
node.
Ā·Ā·Ā· On Thu, Jan 29, 2015 at 10:04 AM, Sigurdur Bjarnason < sigurdurfbjarnason@gmail.com> wrote:
Hi all!,
picking up ā€œwrongā€ environments :confused:
production
however the client is set to ā€œdevelopmentā€ in Foreman…
Any clue?
Best Regards
Siggi
"Foreman users" group.
