Error after running katello-installer --reset
Trying the reset function of katello-installer. The installer completes
without error but then displays the following page:
  Instrumentbräda Hittade inte
Var god och försök uppdatera din begäran
I don't know what language that is?
I got this one in another browser:
  Dashboard Not Found
Please try to update your request
production.log:
Processing by DashboardController#index as HTML
Redirected to https://foreman.test.nu
Filter chain halted as :require_ssl rendered or redirected
Completed 302 Found in 17ms (ActiveRecord: 0.0ms)
Client connected.
Connected to server.
Completed 302 Found in 18ms (ActiveRecord: 0.0ms)
   Rendered common/404.html.erb within layouts/application (7.3ms)
   Rendered layouts/base.html.erb (3.0ms)
Completed 404 Not Found in 517ms (Views: 507.5ms | ActiveRecord: 5.0ms)
Redirected to https://foreman.test.nu/users/extlogin
Filter chain halted as :require_login rendered or redirected
Completed 302 Found in 9ms (ActiveRecord: 1.9ms)
Client disconnected.
When checking for errors since startup, I see lots of Invalid
credentials errors:
Processing by Katello::Api::Rhsm::CandlepinProxiesController#get as JSON
   Parameters: {"id"=>"e40a006c-486d-4617-ba5f-08a6eedf3c4e"}
RestClient::Unauthorized: 401 Unauthorized
Body: {"displayMessage":"Invalid
credentials.","requestUuid":"f744aa38-a491-4d2e-96ef-ef7a8ed45688"}
credentials.","requestUuid":"485d37d4-1a32-49bd-81c5-2bfd51e10eb7"}
Shouldn't it be enough to reset the db and run katello installer again
(I kept the same answers.katello-installer.yaml)?
Or should I first run katello remove and reinstall? I only needed to
reset the database back to the starting point before I messed it up…
Kind regards,
Jorick Astrego
Met vriendelijke groet, With kind regards,
Jorick Astrego
Netbulae Virtualization Experts
Tel: 053 20 30 270 	info@netbulae.eu 	Staalsteden 4-3A 	KvK 08198180
Fax: 053 20 30 271 	www.netbulae.eu 	7547 TA Enschede 	BTW NL821234584B01
For the record, it's the IKEA language. Formally, I think, Swedish :slight_smile:
I'd try to close and open your browser, clean cookies.
