2015-12-16T11:50:54 [app] [W] Error has occurred while listing VMs on my_cluster (VMware)
> Nokogiri::XML::XPath::SyntaxError: Undefined namespace prefix: //soapenv:Body/*
> /usr/share/foreman/vendor/ruby/2.1.0/gems/nokogiri-1.5.11/lib/nokogiri/xml/node.rb:159:in `evaluate'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/nokogiri-1.5.11/lib/nokogiri/xml/node.rb:159:in `block in xpath'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/nokogiri-1.5.11/lib/nokogiri/xml/node.rb:150:in `map'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/nokogiri-1.5.11/lib/nokogiri/xml/node.rb:150:in `xpath'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/rbvmomi-1.8.2/lib/rbvmomi/trivial_soap.rb:112:in `request'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/rbvmomi-1.8.2/lib/rbvmomi/connection.rb:87:in `call'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/rbvmomi-1.8.2/lib/rbvmomi/basic_types.rb:205:in `_call'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/rbvmomi-1.8.2/lib/rbvmomi/basic_types.rb:74:in `block (2 levels) in init'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/rbvmomi-1.8.2/lib/rbvmomi/basic_types.rb:183:in `_get_property'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/rbvmomi-1.8.2/lib/rbvmomi/basic_types.rb:35:in `block (2 levels) in init'
> /usr/share/foreman/app/services/fog_extensions/vsphere/mini_servers.rb:26:in `block in allvmsbyfolder'
> /usr/share/foreman/app/services/fog_extensions/vsphere/mini_servers.rb:22:in `each'
> /usr/share/foreman/app/services/fog_extensions/vsphere/mini_servers.rb:22:in `allvmsbyfolder'
> /usr/share/foreman/app/services/fog_extensions/vsphere/mini_servers.rb:24:in `block in allvmsbyfolder'
> /usr/share/foreman/app/services/fog_extensions/vsphere/mini_servers.rb:12:in `all'
> /usr/share/foreman/app/controllers/compute_resources_vms_controller.rb:4:in `index'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/actionpack-3.2.21/lib/action_controller/metal/implicit_render.rb:4:in `send_action'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/actionpack-3.2.21/lib/abstract_controller/base.rb:167:in `process_action'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/actionpack-3.2.21/lib/action_controller/metal/rendering.rb:10:in `process_action'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/actionpack-3.2.21/lib/abstract_controller/callbacks.rb:18:in `block in process_action'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/activesupport-3.2.21/lib/active_support/callbacks.rb:638:in `block (4 levels) in _run__2960124317673198887__process_action__2942039079704387319__callbacks'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/activesupport-3.2.21/lib/active_support/callbacks.rb:215:in `block in _conditional_callback_around_8091'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/activesupport-3.2.21/lib/active_support/callbacks.rb:326:in `around'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/activesupport-3.2.21/lib/active_support/callbacks.rb:310:in `_callback_around_1877'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/activesupport-3.2.21/lib/active_support/callbacks.rb:214:in `_conditional_callback_around_8091'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/activesupport-3.2.21/lib/active_support/callbacks.rb:637:in `block (3 levels) in _run__2960124317673198887__process_action__2942039079704387319__callbacks'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/activesupport-3.2.21/lib/active_support/callbacks.rb:215:in `block in _conditional_callback_around_8090'
> /usr/share/foreman/app/controllers/concerns/application_shared.rb:13:in `set_timezone'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/activesupport-3.2.21/lib/active_support/callbacks.rb:214:in `_conditional_callback_around_8090'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/activesupport-3.2.21/lib/active_support/callbacks.rb:636:in `block (2 levels) in _run__2960124317673198887__process_action__2942039079704387319__callbacks'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/activesupport-3.2.21/lib/active_support/callbacks.rb:215:in `block in _conditional_callback_around_8089'
> /usr/share/foreman/app/models/concerns/foreman/thread_session.rb:32:in `clear_thread'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/activesupport-3.2.21/lib/active_support/callbacks.rb:214:in `_conditional_callback_around_8089'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/activesupport-3.2.21/lib/active_support/callbacks.rb:448:in `block in _run__2960124317673198887__process_action__2942039079704387319__callbacks'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/activesupport-3.2.21/lib/active_support/callbacks.rb:215:in `block in _conditional_callback_around_8088'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/activesupport-3.2.21/lib/active_support/callbacks.rb:310:in `_callback_around_13'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/activesupport-3.2.21/lib/active_support/callbacks.rb:214:in `_conditional_callback_around_8088'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/activesupport-3.2.21/lib/active_support/callbacks.rb:414:in `_run__2960124317673198887__process_action__2942039079704387319__callbacks'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/activesupport-3.2.21/lib/active_support/callbacks.rb:405:in `__run_callback'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/activesupport-3.2.21/lib/active_support/callbacks.rb:385:in `_run_process_action_callbacks'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/activesupport-3.2.21/lib/active_support/callbacks.rb:81:in `run_callbacks'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/actionpack-3.2.21/lib/abstract_controller/callbacks.rb:17:in `process_action'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/actionpack-3.2.21/lib/action_controller/metal/rescue.rb:29:in `process_action'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/actionpack-3.2.21/lib/action_controller/metal/instrumentation.rb:30:in `block in process_action'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/activesupport-3.2.21/lib/active_support/notifications.rb:123:in `block in instrument'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/activesupport-3.2.21/lib/active_support/notifications/instrumenter.rb:20:in `instrument'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/activesupport-3.2.21/lib/active_support/notifications.rb:123:in `instrument'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/actionpack-3.2.21/lib/action_controller/metal/instrumentation.rb:29:in `process_action'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/actionpack-3.2.21/lib/action_controller/metal/params_wrapper.rb:207:in `process_action'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/activerecord-3.2.21/lib/active_record/railties/controller_runtime.rb:18:in `process_action'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/actionpack-3.2.21/lib/abstract_controller/base.rb:121:in `process'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/actionpack-3.2.21/lib/abstract_controller/rendering.rb:45:in `process'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/actionpack-3.2.21/lib/action_controller/metal.rb:203:in `dispatch'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/actionpack-3.2.21/lib/action_controller/metal/rack_delegation.rb:14:in `dispatch'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/actionpack-3.2.21/lib/action_controller/metal.rb:246:in `block in action'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/actionpack-3.2.21/lib/action_dispatch/routing/route_set.rb:73:in `call'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/actionpack-3.2.21/lib/action_dispatch/routing/route_set.rb:73:in `dispatch'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/actionpack-3.2.21/lib/action_dispatch/routing/route_set.rb:36:in `call'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/journey-1.0.4/lib/journey/router.rb:68:in `block in call'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/journey-1.0.4/lib/journey/router.rb:56:in `each'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/journey-1.0.4/lib/journey/router.rb:56:in `call'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/actionpack-3.2.21/lib/action_dispatch/routing/route_set.rb:608:in `call'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/apipie-rails-0.2.6/lib/apipie/static_dispatcher.rb:65:in `call'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/apipie-rails-0.2.6/lib/apipie/extractor/recorder.rb:97:in `call'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/apipie-rails-0.2.6/lib/apipie/middleware/checksum_in_headers.rb:27:in `call'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/actionpack-3.2.21/lib/action_dispatch/middleware/best_standards_support.rb:17:in `call'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/rack-1.4.7/lib/rack/etag.rb:23:in `call'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/rack-1.4.7/lib/rack/conditionalget.rb:25:in `call'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/actionpack-3.2.21/lib/action_dispatch/middleware/head.rb:14:in `call'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/actionpack-3.2.21/lib/action_dispatch/middleware/params_parser.rb:21:in `call'
> /usr/share/foreman/lib/middleware/catch_json_parse_errors.rb:9:in `call'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/actionpack-3.2.21/lib/action_dispatch/middleware/flash.rb:242:in `call'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/rack-1.4.7/lib/rack/session/abstract/id.rb:210:in `context'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/rack-1.4.7/lib/rack/session/abstract/id.rb:205:in `call'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/actionpack-3.2.21/lib/action_dispatch/middleware/cookies.rb:341:in `call'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/activerecord-3.2.21/lib/active_record/query_cache.rb:64:in `call'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/activerecord-3.2.21/lib/active_record/connection_adapters/abstract/connection_pool.rb:479:in `call'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/actionpack-3.2.21/lib/action_dispatch/middleware/callbacks.rb:28:in `block in call'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/activesupport-3.2.21/lib/active_support/callbacks.rb:405:in `_run__4007361381951050747__call__2415978747642726864__callbacks'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/activesupport-3.2.21/lib/active_support/callbacks.rb:385:in `_run_call_callbacks'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/actionpack-3.2.21/lib/action_dispatch/middleware/callbacks.rb:27:in `call'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/actionpack-3.2.21/lib/action_dispatch/middleware/remote_ip.rb:31:in `call'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/actionpack-3.2.21/lib/action_dispatch/middleware/debug_exceptions.rb:16:in `call'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/actionpack-3.2.21/lib/action_dispatch/middleware/show_exceptions.rb:56:in `call'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/railties-3.2.21/lib/rails/rack/logger.rb:32:in `call_app'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/railties-3.2.21/lib/rails/rack/logger.rb:18:in `call'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/actionpack-3.2.21/lib/action_dispatch/middleware/request_id.rb:22:in `call'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/rack-1.4.7/lib/rack/methodoverride.rb:21:in `call'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/rack-1.4.7/lib/rack/runtime.rb:17:in `call'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/activesupport-3.2.21/lib/active_support/cache/strategy/local_cache.rb:72:in `call'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/rack-1.4.7/lib/rack/lock.rb:15:in `call'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/actionpack-3.2.21/lib/action_dispatch/middleware/static.rb:83:in `call'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/rack-cache-1.2/lib/rack/cache/context.rb:136:in `forward'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/rack-cache-1.2/lib/rack/cache/context.rb:245:in `fetch'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/rack-cache-1.2/lib/rack/cache/context.rb:185:in `lookup'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/rack-cache-1.2/lib/rack/cache/context.rb:66:in `call!'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/rack-cache-1.2/lib/rack/cache/context.rb:51:in `call'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/railties-3.2.21/lib/rails/engine.rb:484:in `call'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/railties-3.2.21/lib/rails/application.rb:231:in `call'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/railties-3.2.21/lib/rails/railtie/configurable.rb:30:in `method_missing'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/rack-1.4.7/lib/rack/builder.rb:134:in `call'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/rack-1.4.7/lib/rack/urlmap.rb:64:in `block in call'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/rack-1.4.7/lib/rack/urlmap.rb:49:in `each'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/rack-1.4.7/lib/rack/urlmap.rb:49:in `call'
> /usr/lib/ruby/vendor_ruby/phusion_passenger/rack/thread_handler_extension.rb:74:in `process_request'
> /usr/lib/ruby/vendor_ruby/phusion_passenger/request_handler/thread_handler.rb:141:in `accept_and_process_next_request'
> /usr/lib/ruby/vendor_ruby/phusion_passenger/request_handler/thread_handler.rb:109:in `main_loop'
> /usr/lib/ruby/vendor_ruby/phusion_passenger/request_handler.rb:455:in `block (3 levels) in start_threads'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/logging-2.0.0/lib/logging/diagnostic_context.rb:448:in `call'
> /usr/share/foreman/vendor/ruby/2.1.0/gems/logging-2.0.0/lib/logging/diagnostic_context.rb:448:in `block in create_with_logging_context'
Could someone help me ? vCenter = 5.5.0, 218311
