I’m having trouble syncing Main Katello/Foreman Server with smart proxies. When I try to do it, it immediately stops, and I’m receiving the following in Task logs:
Action:
Actions::Pulp::Consumer::SyncCapsule
Input:
{"capsule_id"=>5, "repo_pulp_id"=>"1-CCV-Base-Prod-442f1b77-9255-4a50-ae3d-f111ade4a5e0", "sync_options"=>{"remove_missing"=>true}, "remote_user"=>"admin", "remote_cp_user"=>"admin"}
Output:
Exception:
RestClient::InternalServerError: 500 Internal Server Error
BackTrace:
/opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-2.0.1/lib/restclient/abstract_response.rb:223:in `exception_with_response'
/opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-2.0.1/lib/restclient/abstract_response.rb:103:in `return!'
/opt/theforeman/tfm/root/usr/share/gems/gems/runcible-2.5.0/lib/runcible/base.rb:81:in `block in get_response'
/opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-2.0.1/lib/restclient/request.rb:807:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-2.0.1/lib/restclient/request.rb:807:in `process_result'
/opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-2.0.1/lib/restclient/request.rb:725:in `block in transmit'
/opt/rh/rh-ruby22/root/usr/share/ruby/net/http.rb:853:in `start'
/opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-2.0.1/lib/restclient/request.rb:715:in `transmit'
/opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-2.0.1/lib/restclient/request.rb:145:in `execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-2.0.1/lib/restclient/request.rb:52:in `execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-2.0.1/lib/restclient/resource.rb:67:in `post'
/opt/theforeman/tfm/root/usr/share/gems/gems/runcible-2.5.0/lib/runcible/base.rb:80:in `get_response'
/opt/theforeman/tfm/root/usr/share/gems/gems/runcible-2.5.0/lib/runcible/base.rb:68:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/runcible-2.5.0/lib/runcible/resources/repository.rb:98:in `sync'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.5.1.1/app/lib/actions/pulp/consumer/sync_capsule.rb:16:in `invoke_external_task'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.30/lib/dynflow/action/polling.rb:83:in `initiate_external_action'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.30/lib/dynflow/action/polling.rb:18:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.30/lib/dynflow/action/cancellable.rb:13:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.5.1.1/app/lib/actions/pulp/abstract_async_task.rb:45:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.30/lib/dynflow/action.rb:513:in `block (3 levels) in execute_run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.30/lib/dynflow/middleware/stack.rb:26:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.30/lib/dynflow/middleware/stack.rb:26:in `pass'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.30/lib/dynflow/middleware.rb:17:in `pass'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.30/lib/dynflow/middleware.rb:30:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.30/lib/dynflow/middleware/stack.rb:22:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.5.1.1/app/lib/actions/middleware/remote_action.rb:16:in `block in run'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.5.1.1/app/lib/actions/middleware/remote_action.rb:40:in `block in as_remote_user'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.5.1.1/app/models/katello/concerns/user_extensions.rb:21:in `cp_config'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.5.1.1/app/lib/actions/middleware/remote_action.rb:27:in `as_cp_user'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.5.1.1/app/lib/actions/middleware/remote_action.rb:39:in `as_remote_user'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.5.1.1/app/lib/actions/middleware/remote_action.rb:16:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.30/lib/dynflow/action/progress.rb:30:in `with_progress_calculation'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.30/lib/dynflow/action/progress.rb:16:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.5.1.1/app/lib/actions/middleware/keep_locale.rb:11:in `block in run'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.5.1.1/app/lib/actions/middleware/keep_locale.rb:22:in `with_locale'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.5.1.1/app/lib/actions/middleware/keep_locale.rb:11:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.30/lib/dynflow/middleware/world.rb:30:in `execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.30/lib/dynflow/action.rb:512:in `block (2 levels) in execute_run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.30/lib/dynflow/action.rb:511:in `catch'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.30/lib/dynflow/action.rb:511:in `block in execute_run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.30/lib/dynflow/action.rb:426:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.30/lib/dynflow/action.rb:426:in `block in with_error_handling'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.30/lib/dynflow/action.rb:426:in `catch'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.30/lib/dynflow/action.rb:426:in `with_error_handling'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.30/lib/dynflow/action.rb:506:in `execute_run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.30/lib/dynflow/action.rb:267:in `execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.30/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:9:in `block (2 levels) in execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.30/lib/dynflow/execution_plan/steps/abstract.rb:155:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.30/lib/dynflow/execution_plan/steps/abstract.rb:155:in `with_meta_calculation'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.30/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:8:in `block in execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.30/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:22:in `open_action'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.30/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:7:in `execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.30/lib/dynflow/director.rb:42:in `execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.30/lib/dynflow/executors/parallel/worker.rb:11:in `on_message'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.3/lib/concurrent/actor/context.rb:46:in `on_envelope'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.3/lib/concurrent/actor/behaviour/executes_context.rb:7:in `on_envelope'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.3/lib/concurrent/actor/behaviour/abstract.rb:25:in `pass'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.30/lib/dynflow/actor.rb:26:in `on_envelope'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.3/lib/concurrent/actor/behaviour/awaits.rb:15:in `on_envelope'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.3/lib/concurrent/actor/behaviour/sets_results.rb:14:in `on_envelope'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.3/lib/concurrent/actor/behaviour/buffer.rb:38:in `process_envelope'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.3/lib/concurrent/actor/behaviour/buffer.rb:31:in `process_envelopes?'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.3/lib/concurrent/actor/behaviour/buffer.rb:20:in `on_envelope'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.3/lib/concurrent/actor/behaviour/termination.rb:55:in `on_envelope'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.3/lib/concurrent/actor/behaviour/removes_child.rb:10:in `on_envelope'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.3/lib/concurrent/actor/core.rb:161:in `process_envelope'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.3/lib/concurrent/actor/core.rb:95:in `block in on_envelope'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.3/lib/concurrent/actor/core.rb:118:in `block (2 levels) in schedule_execution'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.0.3/lib/concurrent/synchronization/mri_lockable_object.rb:38:in `block in synchronize'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.0.3/lib/concurrent/synchronization/mri_lockable_object.rb:38:in `synchronize'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.3/lib/concurrent/actor/core.rb:115:in `block in schedule_execution'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.0.3/lib/concurrent/executor/serialized_execution.rb:18:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.0.3/lib/concurrent/executor/serialized_execution.rb:96:in `work'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.0.3/lib/concurrent/executor/serialized_execution.rb:77:in `block in call_job'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.0.3/lib/concurrent/executor/ruby_thread_pool_executor.rb:348:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.0.3/lib/concurrent/executor/ruby_thread_pool_executor.rb:348:in `run_task'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.0.3/lib/concurrent/executor/ruby_thread_pool_executor.rb:337:in `block (3 levels) in create_worker'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.0.3/lib/concurrent/executor/ruby_thread_pool_executor.rb:320:in `loop'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.0.3/lib/concurrent/executor/ruby_thread_pool_executor.rb:320:in `block (2 levels) in create_worker'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.0.3/lib/concurrent/executor/ruby_thread_pool_executor.rb:319:in `catch'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.0.3/lib/concurrent/executor/ruby_thread_pool_executor.rb:319:in `block in create_worker'
/opt/theforeman/tfm/root/usr/share/gems/gems/logging-1.8.2/lib/logging/diagnostic_context.rb:323:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/logging-1.8.2/lib/logging/diagnostic_context.rb:323:in `block in create_with_logging_context'
That block repeats itself multiple times.
Both Forman and proxies are at level 1.16.0
Katello is version 3.5.1.1
On the proxy, in /var/log/httpd/pulp-https_error_ssl.log
there is a repeating warning: AH02227: Failed to set r->user to 'SSL_CLIENT_S_DN_CN'
