Hi
I'm running foreman 1.3.1 in a test environment (installed with
foreman-installer), with the aim of combining the custom parameters plugin
with the column view plugin. I've installed both from the foreman plugins
repository (alongside the foreman-hooks and foreman-templates) but I seem
to be getting a rails version error. See below
Gem loading error: Unable to activate foreman_custom_parameters-0.0.1,
because rails-3.2.8 conflicts with rails (~> 3.2.13) (RuntimeError)
/opt/rh/ruby193/root/usr/share/gems/gems/bundler_ext-0.3.0/lib/bundler_ext/bundler_ext.rb:30:in
strict_error' /opt/rh/ruby193/root/usr/share/gems/gems/bundler_ext-0.3.0/lib/bundler_ext/bundler_ext.rb:56:in
rescue in block in system_require'
/opt/rh/ruby193/root/usr/share/gems/gems/bundler_ext-0.3.0/lib/bundler_ext/bundler_ext.rb:37:in
block in system_require' /opt/rh/ruby193/root/usr/share/gems/gems/bundler_ext-0.3.0/lib/bundler_ext/bundler_ext.rb:35:in
each'
system_require' /usr/share/foreman/config/application.rb:11:in
<top (required)>'
/opt/rh/ruby193/root/usr/share/rubygems/rubygems/custom_require.rb:36:in
require' /opt/rh/ruby193/root/usr/share/rubygems/rubygems/custom_require.rb:36:in
require'
/usr/share/foreman/config/environment.rb:2:in <top (required)>' /opt/rh/ruby193/root/usr/share/rubygems/rubygems/custom_require.rb:36:in
require'
require' config.ru:3:in
block in <main>'
/opt/rh/ruby193/root/usr/share/gems/gems/rack-1.4.1/lib/rack/builder.rb:51:in
instance_eval' /opt/rh/ruby193/root/usr/share/gems/gems/rack-1.4.1/lib/rack/builder.rb:51:in
initialize'
config.ru:1:in new' config.ru:1:in
<main>'
/usr/lib/ruby/gems/1.8/gems/passenger-4.0.5/helper-scripts/rack-preloader.rb:82:in
eval' /usr/lib/ruby/gems/1.8/gems/passenger-4.0.5/helper-scripts/rack-preloader.rb:82:in
preload_app'
/usr/lib/ruby/gems/1.8/gems/passenger-4.0.5/helper-scripts/rack-preloader.rb:127:in
<module:App>' /usr/lib/ruby/gems/1.8/gems/passenger-4.0.5/helper-scripts/rack-preloader.rb:6:in
<module:PhusionPassenger>'
/usr/lib/ruby/gems/1.8/gems/passenger-4.0.5/helper-scripts/rack-preloader.rb:5:in
`<main>'
I think 3.2.8 is in your scl. Any suggestion for a way around this?
Charlie
It's a bug that's fixed already in the plugin's gemspec file, but it
needs releasing (Joseph?).
For now you could edit
/opt/rh/ruby193/root/usr/share/gems/specifications/foreman_custom_parameters-0.0.1.gemspec
and remove the rails 3.2.13 dependency lines.
On 08/12/13 16:41, Charlie Derwent wrote:
> Hi
> plugin with the column view plugin. I've installed both from the foreman
> plugins repository (alongside the foreman-hooks and foreman-templates)
> but I seem to be getting a rails version error. See below
> Gem loading error: Unable to activate foreman_custom_parameters-0.0.1, because rails-3.2.8 conflicts with rails (~> 3.2.13) (RuntimeError)
> /opt/rh/ruby193/root/usr/share/gems/gems/bundler_ext-0.3.0/lib/bundler_ext/bundler_ext.rb:30:in `strict_error'
> /opt/rh/ruby193/root/usr/share/gems/gems/bundler_ext-0.3.0/lib/bundler_ext/bundler_ext.rb:56:in `rescue in block in system_require'
> /opt/rh/ruby193/root/usr/share/gems/gems/bundler_ext-0.3.0/lib/bundler_ext/bundler_ext.rb:37:in `block in system_require'
> /opt/rh/ruby193/root/usr/share/gems/gems/bundler_ext-0.3.0/lib/bundler_ext/bundler_ext.rb:35:in `each'
> /opt/rh/ruby193/root/usr/share/gems/gems/bundler_ext-0.3.0/lib/bundler_ext/bundler_ext.rb:35:in `system_require'
> /usr/share/foreman/config/application.rb:11:in `'
> /opt/rh/ruby193/root/usr/share/rubygems/rubygems/custom_require.rb:36:in `require'
> /usr/share/foreman/config/environment.rb:2:in `'
> config.ru:3:in `block in '
> /opt/rh/ruby193/root/usr/share/gems/gems/rack-1.4.1/lib/rack/builder.rb:51:in `instance_eval'
> /opt/rh/ruby193/root/usr/share/gems/gems/rack-1.4.1/lib/rack/builder.rb:51:in `initialize'
> config.ru:1:in `new'
> config.ru:1:in `'
> /usr/lib/ruby/gems/1.8/gems/passenger-4.0.5/helper-scripts/rack-preloader.rb:82:in `eval'
> /usr/lib/ruby/gems/1.8/gems/passenger-4.0.5/helper-scripts/rack-preloader.rb:82:in `preload_app'
> /usr/lib/ruby/gems/1.8/gems/passenger-4.0.5/helper-scripts/rack-preloader.rb:127:in `'
> /usr/lib/ruby/gems/1.8/gems/passenger-4.0.5/helper-scripts/rack-preloader.rb:6:in `'
> /usr/lib/ruby/gems/1.8/gems/passenger-4.0.5/helper-scripts/rack-preloader.rb:5:in `'
Dominic Cleal
Red Hat Engineering
