We get the bellow error when we try to run db:seed. Anyone knows how to fix
it?
[root@puppet ~]# foreman-rake db:seed --trace
Performance on MRI may be improved with the concurrent-ruby-ext gem. Please
see http://concurrent-ruby.com
** Invoke db:seed (first_time)
** Execute db:seed
** Invoke db:abort_if_pending_migrations (first_time)
** Execute environment
** Invoke db:load_config (first_time)
** Execute db:load_config
** Execute db:abort_if_pending_migrations
Seeding /usr/share/foreman/db/seeds.d/03-auth_sources.rb
Seeding /usr/share/foreman/db/seeds.d/03-permissions.rb
Seeding /usr/share/foreman/db/seeds.d/03-roles.rb
Seeding /usr/share/foreman/db/seeds.d/04-admin.rb
Seeding /usr/share/foreman/db/seeds.d/05-taxonomies.rb
Seeding /usr/share/foreman/db/seeds.d/06-architectures.rb
Seeding /usr/share/foreman/db/seeds.d/07-provisioning_templates.rb
Seeding /usr/share/foreman/db/seeds.d/08-partition_tables.rb
Seeding /usr/share/foreman/db/seeds.d/10-installation_media.rb
Seeding /usr/share/foreman/db/seeds.d/11-smart_proxy_features.rb
Seeding /usr/share/foreman/db/seeds.d/13-compute_profiles.rb
Seeding /usr/share/foreman/db/seeds.d/15-bookmarks.rb
Seeding /usr/share/foreman/db/seeds.d/16-mail_notifications.rb
Seeding
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-0.7.6/db/seeds.d/20-foreman_tasks_permissions.rb
Seeding
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman_bootdisk-6.0.0/db/seeds.d/50-bootdisk_templates.rb
Seeding
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-0.7.6/db/seeds.d/60-dynflow_proxy_feature.rb
Seeding
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-0.7.6/db/seeds.d/61-foreman_tasks_bookmarks.rb
Seeding
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman_abrt-0.0.6/db/seeds.d/75-abrt-seeds.rb
Seeding
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman_openscap-0.4.3/db/seeds.d/openscap_feature.rb
Seeding
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman_openscap-0.4.3/db/seeds.d/openscap_scap_default.rb
All seed files executed
rake aborted!
404 Resource Not Found
/opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-1.6.7/lib/restclient/abstract_response.rb:48:in
return!' /opt/theforeman/tfm/root/usr/share/gems/gems/runcible-1.3.5/lib/runcible/base.rb:92:in
block in get_response'
/opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-1.6.7/lib/restclient/request.rb:228:in
call' /opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-1.6.7/lib/restclient/request.rb:228:in
process_result'
/opt/theforeman/tfm/root/usr/share/gems/gems/rbovirt-0.0.35/lib/restclient_ext/request.rb:50:in
block in transmit' /opt/rh/ruby193/root/usr/share/ruby/net/http.rb:746:in
start'
/opt/theforeman/tfm/root/usr/share/gems/gems/rbovirt-0.0.35/lib/restclient_ext/request.rb:44:in
transmit' /opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-1.6.7/lib/restclient/request.rb:64:in
execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-1.6.7/lib/restclient/request.rb:33:in
execute' /opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-1.6.7/lib/restclient/resource.rb:51:in
get'
/opt/theforeman/tfm/root/usr/share/gems/gems/runcible-1.3.5/lib/runcible/base.rb:91:in
get_response' /opt/theforeman/tfm/root/usr/share/gems/gems/runcible-1.3.5/lib/runcible/base.rb:79:in
call'
/opt/theforeman/tfm/root/usr/share/gems/gems/runcible-1.3.5/lib/runcible/resources/event_notifier.rb:71:in
list' /opt/theforeman/tfm/root/usr/share/gems/gems/katello-2.4.0/app/models/katello/glue/pulp/repo.rb:33:in
ensure_sync_notification'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-2.4.0/db/seeds.rb:31:in
<top (required)>' /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/dependencies.rb:245:in
load'
block in load' /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/dependencies.rb:236:in
load_dependency'
load' /opt/rh/ruby193/root/usr/share/gems/gems/railties-3.2.8/lib/rails/engine.rb:520:in
load_seed'
/opt/rh/ruby193/root/usr/share/gems/gems/railties-3.2.8/lib/rails/railtie/configurable.rb:30:in
method_missing' /opt/theforeman/tfm/root/usr/share/gems/gems/katello-2.4.0/lib/katello/engine.rb:192:in
block (2 levels) in <class:Engine>'
/opt/rh/ruby193/root/usr/share/ruby/rake/task.rb:205:in call' /opt/rh/ruby193/root/usr/share/ruby/rake/task.rb:205:in
block in execute'
/opt/rh/ruby193/root/usr/share/ruby/rake/task.rb:200:in each' /opt/rh/ruby193/root/usr/share/ruby/rake/task.rb:200:in
execute'
/opt/rh/ruby193/root/usr/share/ruby/rake/task.rb:158:in block in invoke_with_call_chain' /opt/rh/ruby193/root/usr/share/ruby/monitor.rb:211:in
mon_synchronize'
/opt/rh/ruby193/root/usr/share/ruby/rake/task.rb:151:in
invoke_with_call_chain' /opt/rh/ruby193/root/usr/share/ruby/rake/task.rb:144:in
invoke'
/opt/rh/ruby193/root/usr/share/ruby/rake/application.rb:116:in invoke_task' /opt/rh/ruby193/root/usr/share/ruby/rake/application.rb:94:in
block (2
levels) in top_level'
/opt/rh/ruby193/root/usr/share/ruby/rake/application.rb:94:in each' /opt/rh/ruby193/root/usr/share/ruby/rake/application.rb:94:in
block in
top_level'
/opt/rh/ruby193/root/usr/share/ruby/rake/application.rb:133:in
standard_exception_handling' /opt/rh/ruby193/root/usr/share/ruby/rake/application.rb:88:in
top_level'
/opt/rh/ruby193/root/usr/share/ruby/rake/application.rb:66:in block in run' /opt/rh/ruby193/root/usr/share/ruby/rake/application.rb:133:in
/opt/rh/ruby193/root/usr/share/ruby/rake/application.rb:63:in run' /opt/rh/ruby193/root/usr/bin/rake:32:in
<main>'
Tasks: TOP => db:seed
#<SystemExit: exit>
