Hi
I’m trying to sync a repository containing only Errata information (no RPM) (something provided by @vulnersCom ) documentation is here : Install relevant security updates for CentOS with Errata plugin from Vulners – Vulners Blog
However, when trying to sync It I receive a : “Could not parse repository metadata”
The URL for the repostory is :
https://< redacted api key >@vulners.com/errata/centos/7/
so I’m wondering if the “@” doesn’t cause trouble.
Running a Curl : curl https://@vulners.com/errata/centos/7/repodata/repomd.xml
Gives me a correct XML file.
Configuring the repostory in a .repo file for yum.conf works properly and I’m able to see the errata
No issues
katello 3.18.2.1
CentOS 7
The full error in dynflow is :
pulp_tasks:
- exception:
task_type: pulp.server.managers.repo.sync.sync
_href: "/pulp/api/v2/tasks/d9914806-6e36-4fe2-93f6-51551b5d0084/"
task_id: d9914806-6e36-4fe2-93f6-51551b5d0084
tags:
- pulp:repository:0f63907b-a33f-46bc-aa65-db0f4671ba47
- pulp:action:sync
finish_time: '2021-07-02T15:54:46Z'
_ns: task_status
start_time: '2021-07-02T15:54:41Z'
traceback: |
File "/usr/lib/python2.7/site-packages/celery/app/trace.py", line 367, in trace_task
R = retval = fun(*args, **kwargs)
File "/usr/lib/python2.7/site-packages/pulp/server/async/tasks.py", line 688, in __call__
return super(Task, self).__call__(*args, **kwargs)
File "/usr/lib/python2.7/site-packages/pulp/server/async/tasks.py", line 110, in __call__
return super(PulpTask, self).__call__(*args, **kwargs)
File "/usr/lib/python2.7/site-packages/celery/app/trace.py", line 622, in __protected_call__
return self.run(*args, **kwargs)
File "/usr/lib/python2.7/site-packages/pulp/server/controllers/repository.py", line 802, in sync
sync_report = sync_repo(transfer_repo, conduit, call_config)
File "/usr/lib/python2.7/site-packages/pulp/server/async/tasks.py", line 905, in wrap_f
return f(*args, **kwargs)
File "/usr/lib/python2.7/site-packages/pulp_rpm/plugins/importers/yum/importer.py", line 84, in sync_repo
report = self._current_sync.run()
File "/usr/lib/python2.7/site-packages/pulp_rpm/plugins/importers/yum/sync.py", line 285, in run
metadata_files = self.check_metadata(url)
File "/usr/lib/python2.7/site-packages/pulp_rpm/plugins/importers/yum/sync.py", line 443, in check_metadata
raise PulpCodedException(error_code=error_codes.RPM1006)
PulpCodedException: Could not parse repository metadata
spawned_tasks: []
progress_report:
yum_importer:
content:
items_total: 0
state: NOT_STARTED
error_details: []
details:
rpm_total: 0
rpm_done: 0
drpm_total: 0
drpm_done: 0
size_total: 0
size_left: 0
items_left: 0
comps:
state: NOT_STARTED
purge_duplicates:
state: NOT_STARTED
distribution:
items_total: 0
state: NOT_STARTED
error_details: []
items_left: 0
modules:
state: NOT_STARTED
errata:
state: NOT_STARTED
metadata:
state: FAILED
error: Could not parse repository metadata
queue: reserved_resource_worker-2@master-repo.dq2
state: error
worker_name: reserved_resource_worker-2@master-repo
result:
error:
code: RPM1006
data: {}
description: Could not parse repository metadata
sub_errors: []
_id:
"$oid": 60df36c1ea87eefc30e62509
contents_changed: true
poll_attempts:
total: 8
failed: 1
thank you
