Trying to update a setting in the Discovery tab, I get an error relating to “Setting::Discovered is not a subclass of Setting”
Be able to set the setting properly
Foreman 3.3
foreman_discovery-21.0.1
CentOS 7
Any of the values I try to give this error
So, I figured out more info on this, but wanted to still make the ticket. It appears it’s an issue with the file /opt/theforeman/tfm/root/usr/share/gems/gems/foreman_discovery-21.0.1/app/models/setting/discovered.rb
By changing “class Setting::Discovered” to be “class Setting::Discovered < ::Setting” and restarting foreman it seems to fix the issue.
What the hell… Same problem here… I don’t understand bugs like this… Changing settings should be tested before releasing a new version. Thanks btoneill for the solution! Is working!
