I am following the Foreman 2.1 upgrade guide at Foreman :: Manual
Packages update just fine, but when I do a “foreman-rake db:migrate”, here’s what happens:
[root@foreman2 ~]# foreman-rake db:migrate
API controllers newer than Apipie cache! Run apipie:cache rake task to regenerate cache.
rake aborted!
PG::ConnectionBad: fe_sendauth: no password supplied
/opt/theforeman/tfm/root/usr/share/gems/gems/pg-1.1.4/lib/pg.rb:56:in initialize' /opt/theforeman/tfm/root/usr/share/gems/gems/pg-1.1.4/lib/pg.rb:56:in
new’
/opt/theforeman/tfm/root/usr/share/gems/gems/pg-1.1.4/lib/pg.rb:56:in connect' /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.1/lib/active_record/connection_adapters/postgresql_adapter.rb:46:in
postgresql_connection’
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:887:in new_connection' /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:931:in
checkout_new_connection’
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:910:in try_to_checkout_new_connection' /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:871:in
acquire_connection’
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:593:in checkout' /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:437:in
connection’
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:1119:in retrieve_connection' /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.1/lib/active_record/connection_handling.rb:221:in
retrieve_connection’
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.1/lib/active_record/connection_handling.rb:189:in connection' /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.1/lib/active_record/tasks/database_tasks.rb:238:in
migrate’
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.1/lib/active_record/railties/databases.rake:86:in block (3 levels) in <top (required)>' /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.1/lib/active_record/railties/databases.rake:84:in
each’
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.1/lib/active_record/railties/databases.rake:84:in block (2 levels) in <top (required)>' /opt/rh/rh-ruby25/root/usr/share/gems/gems/rake-12.3.0/exe/rake:27:in
<top (required)>’
Tasks: TOP => db:migrate
No errors
Foreman 2.0
CentOS 7.8
I am running the upgrade as “root.” Which pgsql credentials are missing? I checked file /etc/foreman/database.yml and no user/password is specified there. Is that normal?
