Alguém poderia me ajudar?
Durante a instalação do foreman+Puppet, no CentOS, após executar o
foreman-installer apareceram estes erros:
Could not set home on user[foreman]: Execution of '/usr/sbin/usermod -d
/usr/share/foreman foreman' returned 8: usermod: user foreman is currently
used by process 2150
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util/execution.rb:235:in
execute' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/provider.rb:101:in
execute'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/provider/nameservice.rb:286:in
set' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/provider/nameservice.rb:73:in
block (2 levels) in resource_type='
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/property.rb:194:in
call_provider' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/property.rb:501:in
set'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/property.rb:561:in sync' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/resource_harness.rb:236:in
sync'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/resource_harness.rb:134:in
sync_if_needed' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/resource_harness.rb:88:in
block in perform_changes'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/resource_harness.rb:87:in
each' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/resource_harness.rb:87:in
perform_changes'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/resource_harness.rb:21:in
evaluate' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:230:in
apply'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:246:in
eval_resource' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:163:in
call'
block (2 levels) in evaluate' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:387:in
block in
thinmark'
/opt/puppetlabs/puppet/lib/ruby/2.1.0/benchmark.rb:294:in realtime' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:386:in
thinmark'
block in evaluate' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/graph/relationship_graph.rb:118:in
traverse'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:154:in
evaluate' /usr/share/gems/gems/kafo-1.0.5/modules/kafo_configure/lib/puppet/parser/functions/add_progress.rb:30:in
evaluate_with_trigger'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/resource/catalog.rb:222:in
block in apply' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util/log.rb:155:in
with_destination'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/report.rb:142:in
as_logging_destination' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/resource/catalog.rb:221:in
apply'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:171:in
block in apply_catalog' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:224:in
block in
benchmark'
/opt/puppetlabs/puppet/lib/ruby/2.1.0/benchmark.rb:294:in realtime' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:223:in
benchmark'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:170:in
apply_catalog' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:343:in
run_internal'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:221:in
block in run' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/context.rb:65:in
override'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet.rb:294:in override' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:195:in
run'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application/apply.rb:350:in
apply_catalog' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application/apply.rb:274:in
block in main'
override' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet.rb:294:in
override'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application/apply.rb:225:in
main' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application/apply.rb:170:in
run_command'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application.rb:358:in
block in run' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:542:in
exit_on_fail'
run' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util/command_line.rb:132:in
run'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util/command_line.rb:72:in
execute' /opt/puppetlabs/puppet/bin/puppet:5:in
<main>'
/Stage[main]/Foreman::Config/User[foreman]/home: change from /home/foreman
to /usr/share/foreman failed: Could not set home on user[foreman]:
Execution of '/usr/sbin/usermod -d /usr/share/foreman foreman' returned 8:
usermod: user foreman is currently used by process 2150
Regards,
