is there a way to export Smart class configuration. It can be critical for my business to lose everything
Thank
Foreman 1.17.1
I do not think this feature exists, but perhaps you may be able to script something with hammer/API to back up your data. Do you have any specific export format in mind? I imagine a complimentary import feature would come in handy as well when you want to restore…
I never user hammer/API
For the first time, his just important to export data in any format. (txt, csv …)
Where data are stored ? in the database (table?)
Thanks
You can view the API documentation by navigating to https://$(hostname)/apidoc.html
on your foreman instance. Using hammer might be a bit more straightforward. You could be interested in the following commands:
hammer puppet-class
hammer smart-variable
hammer sc-param
You can also specify the output format: hammer --output csv
. The data are stored in database, you might also find general backup information useful.
Thank
I will explore this way
I find another solution but little complex :
Access on the old foreman bdd
Dump some table on the old foreman bdd
pg_dump foreman --column-inserts -a -t config_groups -t puppetclasses -t config_group_classes -t lookup_keys -t lookup_values -t environments \ -t environment_classes -t media -t operatingsystems -t media_operatingsystems \ -t template_kinds -t templates -t operatingsystems_provisioning_templates -t operatingsystems_ptables \ -t os_default_templates \ -t auth_sources -t users -t roles -t user_roles -t usergroups -t usergroup_members> /tmp/backup_for_foreman_config2019.sql
(2 Bis) I put you several tables that I restored for a new foreman, but in your case you only need :
pg_dump foreman --column-inserts -a -t config_groups -t puppetclasses -t config_group_classes -t lookup_keys -t lookup_values -t environments > /tmp/backup_for_foreman_config2019.sql
Restore the exported config on the new server
pg_restore /tmp/backup_for_foreman_config2019.sql -d foreman
you can contact me if you need help accessing the database or other
