Extending Foreman /Ruby help
So I'm very new to Ruby, but am trying to learn it using Foreman as my
guide as I'd like to work on extending Foreman a bit. I'm attempting
to add a new UnattendedHelper function to return the information for a
host's subnet so that something like this can be included a kickstart
file
network --bootproto=static --ip=<%= @host.ip %>
–netmask=<%= @host.subnet.netmask %> --gateway=<%=
@host.subnet.gateway %>
–dns=<%= @host.subnet.dns %>
The intention is to allow for dynamic IP use by the host being
provisioned and still allow the kickstart to set a static IP so that
on first boot it's already set.
What I'm having trouble with is figuring out how to add a method to
app/helpers/unattended_helper.rb (if that's indeed the correct place
to do this). Additionally where to look in the code to add a field to
the Subnet form to define at least one DNS IP.
Maybe a quick example of how to pull in the "subnet_id" value for a
host would help. I can then call DHCP.subnet(id) to pull in the
host's assigned subnet information? Any advice or help would be
greatly appreciated.
Thanks
  • Trey
> file
> --netmask=<%= @host.subnet.netmask %> --gateway=<%=
> --dns=<%= @host.subnet.dns %>
I think you are doing it correctly, but probably blocked by the safe
rendering, try disable it (more --> settings) then you should be able
to access the subnet model.
one good way to experiment, is using rails console
You generally need to add a rails migration, try googling for that, we
can try to help you further on irc?
Ohad
··· On Thu, Nov 10, 2011 at 8:41 PM, treydock wrote: > > Thanks > - Trey > > -- > You received this message because you are subscribed to the Google Groups "Foreman users" group. > To post to this group, send email to foreman-users@googlegroups.com. > To unsubscribe from this group, send email to foreman-users+unsubscribe@googlegroups.com. > For more options, visit this group at http://groups.google.com/group/foreman-users?hl=en. > >
Hi Trey
Now that i finally found time to play around with Foreman this is the
exact thing that i am missing as well. Would be great so see it in one
of the future Foreman Releases.
Markus
··· On Thu, Nov 10, 2011 at 7:41 PM, treydock wrote: > I'm attempting > to add a new UnattendedHelper function to return the information for a > host's subnet so that something like this can be included a kickstart > file > > network --bootproto=static --ip=<%= @host.ip %> \ > --netmask=<%= @host.subnet.netmask %> --gateway=<%= > @host.subnet.gateway %> \ > --dns=<%= @host.subnet.dns %> > > The intention is to allow for dynamic IP use by the host being > provisioned and still allow the kickstart to set a static IP so that > on first boot it's already set.
I forgot to mention, but its possible to achieve the same thing by
using foreman smart variables.
they would be available in your template as @host.params["var"] or
simply $var in your puppet code.
You could define attributes in the scope of your subnet etc.
Ohad
··· On Fri, Nov 18, 2011 at 1:01 PM, Markus Nussdorfer wrote: > On Thu, Nov 10, 2011 at 7:41 PM, treydock wrote: >> I'm attempting >> to add a new UnattendedHelper function to return the information for a >> host's subnet so that something like this can be included a kickstart >> file >> >> network --bootproto=static --ip=<%= @host.ip %> \ >> --netmask=<%= @host.subnet.netmask %> --gateway=<%= >> @host.subnet.gateway %> \ >> --dns=<%= @host.subnet.dns %> >> >> The intention is to allow for dynamic IP use by the host being >> provisioned and still allow the kickstart to set a static IP so that >> on first boot it's already set. > > Hi Trey > > Now that i finally found time to play around with Foreman this is the > exact thing that i am missing as well. Would be great so see it in one > of the future Foreman Releases. > > Markus > > -- > You received this message because you are subscribed to the Google Groups "Foreman users" group. > To post to this group, send email to foreman-users@googlegroups.com. > To unsubscribe from this group, send email to foreman-users+unsubscribe@googlegroups.com. > For more options, visit this group at http://groups.google.com/group/foreman-users?hl=en. > >
That would work too. I've got something working, using the existing
subnets to define the IPs. Unfortunately I don't think my approach is
very "ruby-ish".
I was wanting to have things accessed like so <%= @subnet.ip %>, but
am I correct that this would require modifying the subnet model with
something like "alias_attribute :ip" ?
What I have is this in app/helpers/unattended_helper.rb
def subnet
subnet = Subnet.find(@host.subnet_id)
{:gateway =&gt; subnet.gateway , :mask =&gt; subnet.mask, :dns =&gt;
subnet.dns }
end
And the values are used like this from the kickstart template
network --bootproto static --hostname <%= @host.name %> --ip=<%=
@host.ip %>
–netmask=<%= subnet[:mask] %> --gateway=<%= subnet[:gateway] %> –
nameserver=<%= subnet[:dns] %>
To facilitate the use of "gateway" and "dns" I added those two fields
to the subnets form and DB
Is that approach acceptable and in line with how Foreman is modeled ?
Thanks
  • Trey
··· On Nov 21, 1:31 am, Ohad Levy wrote: > I forgot to mention, but its possible to achieve the same thing by > using foreman smart variables. > they would be available in your template as @host.params["var"] or > simply $var in your puppet code. > > You could define attributes in the scope of your subnet etc. > > Ohad > > On Fri, Nov 18, 2011 at 1:01 PM, Markus Nussdorfer > > > > > > > > wrote: > > On Thu, Nov 10, 2011 at 7:41 PM, treydock wrote: > >> I'm attempting > >> to add a new UnattendedHelper function to return the information for a > >> host's subnet so that something like this can be included a kickstart > >> file > > >> network --bootproto=static --ip=<%= @host.ip %> \ > >> --netmask=<%= @host.subnet.netmask %> --gateway=<%= > >> @host.subnet.gateway %> \ > >> --dns=<%= @host.subnet.dns %> > > >> The intention is to allow for dynamic IP use by the host being > >> provisioned and still allow the kickstart to set a static IP so that > >> on first boot it's already set. > > > Hi Trey > > > Now that i finally found time to play around with Foreman this is the > > exact thing that i am missing as well. Would be great so see it in one > > of the future Foreman Releases. > > > Markus > > > -- > > You received this message because you are subscribed to the Google Groups "Foreman users" group. > > To post to this group, send email to foreman-users@googlegroups.com. > > To unsubscribe from this group, send email to foreman-users+unsubscribe@googlegroups.com. > > For more options, visit this group athttp://groups.google.com/group/foreman-users?hl=en.
> very "ruby-ish".
> def subnet
> {:gateway => subnet.gateway , :mask => subnet.mask, :dns =>
> subnet.dns }
> end
> @host.ip %>
> --netmask=<%= subnet[:mask] %> --gateway=<%= subnet[:gateway] %> –
Your approch is sane, and I would be happy for such a patch, but I
think that its a very specific solution.
imho, the smart variables exposes a greater option for everyone to add
the attributes (and values) they need, rather then force it into
foreman code.
Ohad
··· On Wed, Nov 23, 2011 at 12:35 AM, treydock wrote: > > Thanks > - Trey > > > On Nov 21, 1:31 am, Ohad Levy wrote: >> I forgot to mention, but its possible to achieve the same thing by >> using foreman smart variables. >> they would be available in your template as @host.params["var"] or >> simply $var in your puppet code. >> >> You could define attributes in the scope of your subnet etc. >> >> Ohad >> >> On Fri, Nov 18, 2011 at 1:01 PM, Markus Nussdorfer >> >> >> >> >> >> >> >> wrote: >> > On Thu, Nov 10, 2011 at 7:41 PM, treydock wrote: >> >> I'm attempting >> >> to add a new UnattendedHelper function to return the information for a >> >> host's subnet so that something like this can be included a kickstart >> >> file >> >> >> network --bootproto=static --ip=<%= @host.ip %> \ >> >> --netmask=<%= @host.subnet.netmask %> --gateway=<%= >> >> @host.subnet.gateway %> \ >> >> --dns=<%= @host.subnet.dns %> >> >> >> The intention is to allow for dynamic IP use by the host being >> >> provisioned and still allow the kickstart to set a static IP so that >> >> on first boot it's already set. >> >> > Hi Trey >> >> > Now that i finally found time to play around with Foreman this is the >> > exact thing that i am missing as well. Would be great so see it in one >> > of the future Foreman Releases. >> >> > Markus >> >> > -- >> > You received this message because you are subscribed to the Google Groups "Foreman users" group. >> > To post to this group, send email to foreman-users@googlegroups.com. >> > To unsubscribe from this group, send email to foreman-users+unsubscribe@googlegroups.com. >> > For more options, visit this group athttp://groups.google.com/group/foreman-users?hl=en. > > -- > You received this message because you are subscribed to the Google Groups "Foreman users" group. > To post to this group, send email to foreman-users@googlegroups.com. > To unsubscribe from this group, send email to foreman-users+unsubscribe@googlegroups.com. > For more options, visit this group at http://groups.google.com/group/foreman-users?hl=en. > >
I will try the smart variable approach and see how the work flow
differs. I'll submit my patch once I'm back at my office, just in
case there's additional interest or a future desire for this.
This is likely also a very specific use case, but all the items that
accept variables (hostgroups, environment, templates, OS, etc) are
used by all my servers in all subnets. So I would almost have to
specify these parameters on a per-host basis. Is there possibly a
better place I could add these items that would allow for efficient re-
use ?
Thanks
  • Trey
··· > > very "ruby-ish". > > > I was wanting to have things accessed like so <%= @subnet.ip %>, but > > am I correct that this would require modifying the subnet model with > > something like "alias_attribute :ip" ? > > > What I have is this in app/helpers/unattended_helper.rb > > > def subnet > > subnet = Subnet.find(@host.subnet_id) > > > {:gateway => subnet.gateway , :mask => subnet.mask, :dns => > > subnet.dns } > > end > > > And the values are used like this from the kickstart template > > > network --bootproto static --hostname <%= @host.name %> --ip=<%= > > @host.ip %> \ > > --netmask=<%= subnet[:mask] %> --gateway=<%= subnet[:gateway] %> -- > > nameserver=<%= subnet[:dns] %> > > > To facilitate the use of "gateway" and "dns" I added those two fields > > to the subnets form and DB > > > Is that approach acceptable and in line with how Foreman is modeled ? > > Your approch is sane, and I would be happy for such a patch, but I > think that its a very specific solution. > > imho, the smart variables exposes a greater option for everyone to add > the attributes (and values) they need, rather then force it into > foreman code. > > Ohad > > > > > > > > > > > Thanks > > - Trey > > > On Nov 21, 1:31 am, Ohad Levy wrote: > >> I forgot to mention, but its possible to achieve the same thing by > >> using foreman smart variables. > >> they would be available in your template as @host.params["var"] or > >> simply $var in your puppet code. > > >> You could define attributes in the scope of your subnet etc. > > >> Ohad > > >> On Fri, Nov 18, 2011 at 1:01 PM, Markus Nussdorfer > > >> wrote: > >> > On Thu, Nov 10, 2011 at 7:41 PM, treydock wrote: > >> >> I'm attempting > >> >> to add a new UnattendedHelper function to return the information for a > >> >> host's subnet so that something like this can be included a kickstart > >> >> file > > >> >> network --bootproto=static --ip=<%= @host.ip %> \ > >> >> --netmask=<%= @host.subnet.netmask %> --gateway=<%= > >> >> @host.subnet.gateway %> \ > >> >> --dns=<%= @host.subnet.dns %> > > >> >> The intention is to allow for dynamic IP use by the host being > >> >> provisioned and still allow the kickstart to set a static IP so that > >> >> on first boot it's already set. > > >> > Hi Trey > > >> > Now that i finally found time to play around with Foreman this is the > >> > exact thing that i am missing as well. Would be great so see it in one > >> > of the future Foreman Releases. > > >> > Markus > > >> > -- > >> > You received this message because you are subscribed to the Google Groups "Foreman users" group. > >> > To post to this group, send email to foreman-users@googlegroups.com. > >> > To unsubscribe from this group, send email to foreman-users+unsubscribe@googlegroups.com. > >> > For more options, visit this group athttp://groups.google.com/group/foreman-users?hl=en. > > > -- > > You received this message because you are subscribed to the Google Groups "Foreman users" group. > > To post to this group, send email to foreman-users@googlegroups.com. > > To unsubscribe from this group, send email to foreman-users+unsubscribe@googlegroups.com. > > For more options, visit this group athttp://groups.google.com/group/foreman-users?hl=en.
i am very interested in these patch.
rgds f0
··· On Nov 25, 6:50 am, treydock wrote: > I will try the smart variable approach and see how the work flow > differs. I'll submit my patch once I'm back at my office, just in > case there's additional interest or a future desire for this. > > This is likely also a very specific use case, but all the items that > accept variables (hostgroups, environment, templates, OS, etc) are > used by all my servers in all subnets. So I would almost have to > specify these parameters on a per-host basis. Is there possibly a > better place I could add these items that would allow for efficient re- > use ? > > Thanks > - Trey > > > > > > > > > > very "ruby-ish". > > > > I was wanting to have things accessed like so <%= @subnet.ip %>, but > > > am I correct that this would require modifying the subnet model with > > > something like "alias_attribute :ip" ? > > > > What I have is this in app/helpers/unattended_helper.rb > > > > def subnet > > > subnet = Subnet.find(@host.subnet_id) > > > > {:gateway => subnet.gateway , :mask => subnet.mask, :dns => > > > subnet.dns } > > > end > > > > And the values are used like this from the kickstart template > > > > network --bootproto static --hostname <%= @host.name %> --ip=<%= > > > @host.ip %> \ > > > --netmask=<%= subnet[:mask] %> --gateway=<%= subnet[:gateway] %> -- > > > nameserver=<%= subnet[:dns] %> > > > > To facilitate the use of "gateway" and "dns" I added those two fields > > > to the subnets form and DB > > > > Is that approach acceptable and in line with how Foreman is modeled ? > > > Your approch is sane, and I would be happy for such a patch, but I > > think that its a very specific solution. > > > imho, the smart variables exposes a greater option for everyone to add > > the attributes (and values) they need, rather then force it into > > foreman code. > > > Ohad > > > > Thanks > > > - Trey > > > > On Nov 21, 1:31 am, Ohad Levy wrote: > > >> I forgot to mention, but its possible to achieve the same thing by > > >> using foreman smart variables. > > >> they would be available in your template as @host.params["var"] or > > >> simply $var in your puppet code. > > > >> You could define attributes in the scope of your subnet etc. > > > >> Ohad > > > >> On Fri, Nov 18, 2011 at 1:01 PM, Markus Nussdorfer > > > >> wrote: > > >> > On Thu, Nov 10, 2011 at 7:41 PM, treydock wrote: > > >> >> I'm attempting > > >> >> to add a new UnattendedHelper function to return the information for a > > >> >> host's subnet so that something like this can be included a kickstart > > >> >> file > > > >> >> network --bootproto=static --ip=<%= @host.ip %> \ > > >> >> --netmask=<%= @host.subnet.netmask %> --gateway=<%= > > >> >> @host.subnet.gateway %> \ > > >> >> --dns=<%= @host.subnet.dns %> > > > >> >> The intention is to allow for dynamic IP use by the host being > > >> >> provisioned and still allow the kickstart to set a static IP so that > > >> >> on first boot it's already set. > > > >> > Hi Trey > > > >> > Now that i finally found time to play around with Foreman this is the > > >> > exact thing that i am missing as well. Would be great so see it in one > > >> > of the future Foreman Releases. > > > >> > Markus > > > >> > -- > > >> > You received this message because you are subscribed to the Google Groups "Foreman users" group. > > >> > To post to this group, send email to foreman-users@googlegroups.com. > > >> > To unsubscribe from this group, send email to foreman-users+unsubscribe@googlegroups.com. > > >> > For more options, visit this group athttp://groups.google.com/group/foreman-users?hl=en. > > > > -- > > > You received this message because you are subscribed to the Google Groups "Foreman users" group. > > > To post to this group, send email to foreman-users@googlegroups.com. > > > To unsubscribe from this group, send email to foreman-users+unsubscribe@googlegroups.com. > > > For more options, visit this group athttp://groups.google.com/group/foreman-users?hl=en.
> use ?
not sure if I follow, but you can avoid reentering data, thats the
whole idea, try out the smart vars and let us know how it worked out.
btw: I would love to see that patch.
thanks,
Ohad
··· On Fri, Nov 25, 2011 at 7:50 AM, treydock wrote: > > Thanks > - Trey > >> > very "ruby-ish". >> >> > I was wanting to have things accessed like so <%= @subnet.ip %>, but >> > am I correct that this would require modifying the subnet model with >> > something like "alias_attribute :ip" ? >> >> > What I have is this in app/helpers/unattended_helper.rb >> >> > def subnet >> > subnet = Subnet.find(@host.subnet_id) >> >> > {:gateway => subnet.gateway , :mask => subnet.mask, :dns => >> > subnet.dns } >> > end >> >> > And the values are used like this from the kickstart template >> >> > network --bootproto static --hostname <%= @host.name %> --ip=<%= >> > @host.ip %> \ >> > --netmask=<%= subnet[:mask] %> --gateway=<%= subnet[:gateway] %> -- >> > nameserver=<%= subnet[:dns] %> >> >> > To facilitate the use of "gateway" and "dns" I added those two fields >> > to the subnets form and DB >> >> > Is that approach acceptable and in line with how Foreman is modeled ? >> >> Your approch is sane, and I would be happy for such a patch, but I >> think that its a very specific solution. >> >> imho, the smart variables exposes a greater option for everyone to add >> the attributes (and values) they need, rather then force it into >> foreman code. >> >> Ohad >> >> >> >> >> >> >> >> >> >> > Thanks >> > - Trey >> >> > On Nov 21, 1:31 am, Ohad Levy wrote: >> >> I forgot to mention, but its possible to achieve the same thing by >> >> using foreman smart variables. >> >> they would be available in your template as @host.params["var"] or >> >> simply $var in your puppet code. >> >> >> You could define attributes in the scope of your subnet etc. >> >> >> Ohad >> >> >> On Fri, Nov 18, 2011 at 1:01 PM, Markus Nussdorfer >> >> >> wrote: >> >> > On Thu, Nov 10, 2011 at 7:41 PM, treydock wrote: >> >> >> I'm attempting >> >> >> to add a new UnattendedHelper function to return the information for a >> >> >> host's subnet so that something like this can be included a kickstart >> >> >> file >> >> >> >> network --bootproto=static --ip=<%= @host.ip %> \ >> >> >> --netmask=<%= @host.subnet.netmask %> --gateway=<%= >> >> >> @host.subnet.gateway %> \ >> >> >> --dns=<%= @host.subnet.dns %> >> >> >> >> The intention is to allow for dynamic IP use by the host being >> >> >> provisioned and still allow the kickstart to set a static IP so that >> >> >> on first boot it's already set. >> >> >> > Hi Trey >> >> >> > Now that i finally found time to play around with Foreman this is the >> >> > exact thing that i am missing as well. Would be great so see it in one >> >> > of the future Foreman Releases. >> >> >> > Markus >> >> >> > -- >> >> > You received this message because you are subscribed to the Google Groups "Foreman users" group. >> >> > To post to this group, send email to foreman-users@googlegroups.com. >> >> > To unsubscribe from this group, send email to foreman-users+unsubscribe@googlegroups.com. >> >> > For more options, visit this group athttp://groups.google.com/group/foreman-users?hl=en. >> >> > -- >> > You received this message because you are subscribed to the Google Groups "Foreman users" group. >> > To post to this group, send email to foreman-users@googlegroups.com. >> > To unsubscribe from this group, send email to foreman-users+unsubscribe@googlegroups.com. >> > For more options, visit this group athttp://groups.google.com/group/foreman-users?hl=en. > > -- > You received this message because you are subscribed to the Google Groups "Foreman users" group. > To post to this group, send email to foreman-users@googlegroups.com. > To unsubscribe from this group, send email to foreman-users+unsubscribe@googlegroups.com. > For more options, visit this group at http://groups.google.com/group/foreman-users?hl=en. > >
I've added an issue and attached the patch file
http://theforeman.org/issues/1361
··· On Nov 28, 3:04 am, Ohad Levy wrote: > On Fri, Nov 25, 2011 at 7:50 AM, treydock wrote: > > I will try the smart variable approach and see how the work flow > > differs. I'll submit my patch once I'm back at my office, just in > > case there's additional interest or a future desire for this. > > > This is likely also a very specific use case, but all the items that > > accept variables (hostgroups, environment, templates, OS, etc) are > > used by all my servers in all subnets. So I would almost have to > > specify these parameters on a per-host basis. Is there possibly a > > better place I could add these items that would allow for efficient re- > > use ? > > not sure if I follow, but you can avoid reentering data, thats the > whole idea, try out the smart vars and let us know how it worked out. > > btw: I would love to see that patch. > > thanks, > Ohad > > > > > > > > > > > Thanks > > - Trey > > >> > very "ruby-ish". > > >> > I was wanting to have things accessed like so <%= @subnet.ip %>, but > >> > am I correct that this would require modifying the subnet model with > >> > something like "alias_attribute :ip" ? > > >> > What I have is this in app/helpers/unattended_helper.rb > > >> > def subnet > >> > subnet = Subnet.find(@host.subnet_id) > > >> > {:gateway => subnet.gateway , :mask => subnet.mask, :dns => > >> > subnet.dns } > >> > end > > >> > And the values are used like this from the kickstart template > > >> > network --bootproto static --hostname <%= @host.name %> --ip=<%= > >> > @host.ip %> \ > >> > --netmask=<%= subnet[:mask] %> --gateway=<%= subnet[:gateway] %> -- > >> > nameserver=<%= subnet[:dns] %> > > >> > To facilitate the use of "gateway" and "dns" I added those two fields > >> > to the subnets form and DB > > >> > Is that approach acceptable and in line with how Foreman is modeled ? > > >> Your approch is sane, and I would be happy for such a patch, but I > >> think that its a very specific solution. > > >> imho, the smart variables exposes a greater option for everyone to add > >> the attributes (and values) they need, rather then force it into > >> foreman code. > > >> Ohad > > >> > Thanks > >> > - Trey > > >> > On Nov 21, 1:31 am, Ohad Levy wrote: > >> >> I forgot to mention, but its possible to achieve the same thing by > >> >> using foreman smart variables. > >> >> they would be available in your template as @host.params["var"] or > >> >> simply $var in your puppet code. > > >> >> You could define attributes in the scope of your subnet etc. > > >> >> Ohad > > >> >> On Fri, Nov 18, 2011 at 1:01 PM, Markus Nussdorfer > > >> >> wrote: > >> >> > On Thu, Nov 10, 2011 at 7:41 PM, treydock wrote: > >> >> >> I'm attempting > >> >> >> to add a new UnattendedHelper function to return the information for a > >> >> >> host's subnet so that something like this can be included a kickstart > >> >> >> file > > >> >> >> network --bootproto=static --ip=<%= @host.ip %> \ > >> >> >> --netmask=<%= @host.subnet.netmask %> --gateway=<%= > >> >> >> @host.subnet.gateway %> \ > >> >> >> --dns=<%= @host.subnet.dns %> > > >> >> >> The intention is to allow for dynamic IP use by the host being > >> >> >> provisioned and still allow the kickstart to set a static IP so that > >> >> >> on first boot it's already set. > > >> >> > Hi Trey > > >> >> > Now that i finally found time to play around with Foreman this is the > >> >> > exact thing that i am missing as well. Would be great so see it in one > >> >> > of the future Foreman Releases. > > >> >> > Markus > > >> >> > -- > >> >> > You received this message because you are subscribed to the Google Groups "Foreman users" group. > >> >> > To post to this group, send email to foreman-users@googlegroups.com. > >> >> > To unsubscribe from this group, send email to foreman-users+unsubscribe@googlegroups.com. > >> >> > For more options, visit this group athttp://groups.google.com/group/foreman-users?hl=en. > > >> > -- > >> > You received this message because you are subscribed to the Google Groups "Foreman users" group. > >> > To post to this group, send email to foreman-users@googlegroups.com. > >> > To unsubscribe from this group, send email to foreman-users+unsubscribe@googlegroups.com. > >> > For more options, visit this group athttp://groups.google.com/group/foreman-users?hl=en. > > > -- > > You received this message because you are subscribed to the Google Groups "Foreman users" group. > > To post to this group, send email to foreman-users@googlegroups.com. > > To unsubscribe from this group, send email to foreman-users+unsubscribe@googlegroups.com. > > For more options, visit this group athttp://groups.google.com/group/foreman-users?hl=en.
