Facts are not uploading and visible in foreman
There are no facts in foreman post completion of "puppet agent -t". It's
the same behavior from all the nodes.
I have checked /var/log/foreman/production.log and no instances of
successful or error messages regarding facts, where as i can see successful
report submissions in the same log.
Plz help.
-Harish
I had this issue with foreman deployed hosts, problem was the build state
of the system did not change to "installed" after installing
running
wget -q -O /dev/null --no-check-certificate https://foreman/unattended/built
after installation solved this problem for me
cheers
Funksen
··· Am Samstag, 11. März 2017 12:17:21 UTC+1 schrieb Harish Kothuri: > > Hi, > > There are no facts in foreman post completion of "puppet agent -t". It's > the same behavior from all the nodes. > > I have checked /var/log/foreman/production.log and no instances of > successful or error messages regarding facts, where as i can see successful > report submissions in the same log. > > Plz help. > > -Harish > > >
