After upgrading to 1.17, I get the following error:
VM should be provisioned on vsphere
I didn’t have this problem on 1.16.
Please attach production log
Would be good to open a bug report on https://projects.theforeman.org/projects/foreman/issues
Here is the production log. Note, I shutdown foreman and then cleared the log. I started foreman back up and then tried to create a vsphere vm. This should help when looking through the attached log.
production.log.tar (70 KB)
It fails here
# === Power on
# Foreman will try and start this vm after clone in a seperate request.
def clone_vm(raw_args)
args = parse_args(raw_args)
opts = {
"datacenter" => datacenter,
"template_path" => args[:image_id],
"dest_folder" => args[:path],
"power_on" => false,
"start" => args[:start],
"name" => args[:name],
"numCPUs" => args[:cpus],
"numCoresPerSocket" => args[:corespersocket],
"memoryMB" => args[:memory_mb],
"datastore" => args[:volumes].first[:datastore],
"storage_pod" => args[:volumes].first[:storage_pod],
"resource_pool" => [args[:cluster], args[:resource_pool]],
"boot_order" => [:disk],
on the datastore line. I think this indicates that args[:volumes] is returning as undef right?
vsphere version: VMware ESXi, 6.0.0, 4600944
Created a bug report here: Bug #23342: vsphere - failed to create resource - undefined method first - Foreman
