Firstly, I've very much like to thank the dev team and all contributors for
making Foreman the excellent piece of software it has become today.
I'd very much like to see a simple checkbox feature included where you can
enable/disable visibility of all smart class parameters of each attached
parametised class to a hostgroup which is separate and doesn't require
setting override on the parameter itself.
The reasoning behind this - it's much easier (and in my opinion tidier) to
have all default parameters visible and set overrides from the hostgroup
parameter view when you attach a class. Setting "override all parameters"
on a base class, which is the only way full visibility of all parameters
can be achieved at the hostgroup/parameters view at present, can yield
unexpected behavior and evaluation errors when you have class variables set
up with inheritance.
Kind regards,
A.S
